Old Apr 08, 2002, 03:28 PM
HavingFun2002 is offline
Find More Posts by HavingFun2002
HavingFun2002's Avatar
Reston, VA
Joined Feb 2002
Mini Tornado Build Questions
Iím building my Tornado now and noticed that the servo arms are somewhat exposed, and are on the bottom of the wing. The instructions where terrible, so Iím not sure if that they way they are suppose to be.
I buried the HS-55 servos in the foam as far as I could without going out the other side, but there is about 5 MM of arm expose. The pushrods are in a tub that you tuck into a slit in the wing.
What going to happen when I fly this bird? Are the servo arms going to sheer off on landing? Did I do this correctly? Should I put on some foam skids?
Thanks.
HavingFun2002 is offline Find More Posts by HavingFun2002
Old Apr 08, 2002, 03:49 PM
bozmonster is offline
Find More Posts by bozmonster
bozmonster's Avatar
St Paul, Mn
Joined Apr 2001
I was a bit concered about this as well. I built mine as stated, and it flies great. I've only flown it indoors so far, and the Astroturf is much harder than grass or dirt, and I've had no problems so I think you should be fine. Actually, I've only landed mine a few times, most of the time I prefer to catch it. Its so slow and tracks so true thats its not a problem, and if ya have a crowd watching they love it! And its all EPP so if ya miss and it hits you between the eyes it wont leave a mark!!!
Chris
bozmonster is offline Find More Posts by bozmonster
Old Apr 08, 2002, 09:21 PM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Mini T
Hi! I put some foam skids over the servo arms carved out so the arm is free to move. I fly the Mini T in parking lots at night and broke an arm on a servo after about 5 landings. If you stay in grass you should be OK if you set the servos in the wing as far as possible. Don't forget to cover the elevons with tape, they break!! Enjoy your Mini T it is my favorite plane and I fly it every day. It's a great size to keep in the car at all times and flys in wind quite well.
Regards.
Pete
peterv is offline Find More Posts by peterv
Old Apr 08, 2002, 11:40 PM
Reston, VA
Joined Feb 2002
What foam did you use?
Old Apr 09, 2002, 12:16 AM
peterv is offline
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Mini T
I just used some scrap EPP foam I had from some packing material. Put packing tape over the servos and glued the foam to the tape and over the servo arms. Also I made a cowl out of foam for the front part of the motor/geardrive as I ripped it off the mount landing on rough ice on the lake behind my house this winter. It acts like three landing skids and protects the servo arms and motor on landings on hard surfaces.
Good luck!
Pete
Mini Blade Build Questions/suggestions KingOfTheHill Slope 35 Aug 12, 2004 12:07 AM
Mini-Nyx Electric Build Questions Meneer High Performance 44 Jul 18, 2004 08:15 PM
Mini-Nyx Electric build questions Meneer Electric Sailplanes 0 Jun 10, 2004 02:42 PM
Mini Tornado build question Crashmaster Foamies (Kits) 1 Mar 26, 2002 08:38 PM
Build Questions for a HL Mini Tornado jah Foamies (Kits) 21 Jan 14, 2002 01:13 PM
