Apr 11, 2002, 07:40 PM
TN
Joined Feb 2001
I may be telling something that most already know here but, from the comments I read about plans, it looks like many have trouble printing them from pdf files.
All you have to do to re-assemble them into complete plans is to open the file for your plane, go to TOOLS on the pdf reader, SELECT GRAPHICS then, one at the time for each page, under the EDIT menu, SELECT ALL then COPY. In a new window, open up your photo editing progam (I use Photoshop LE), start a NEW file, make the size about 25" wide by 18" high, 72dpi resolution and, from the EDIT menu, select PASTE. Page one will appear. Go back to the pdf reader, repeat the sequence for each page and import each one into your photo editor. I set the opacity for each new layer at 50% to help me move it to match up with the previous page then go back to 100% opacity. When you have all layers (pages) lined up, FLATTEN the image and save it with the name of the plane as a TIFF file. It's easy to re-size or manipulate TIFF files for any size plane you want. I also crop the image to just the size of the plan and change it to GRAYSCALE mode to make a smaller file.
IF your printer is a standard 8.5" width, select a portion of your plan that will fit the 8.5 width and save it as a separate file. Use paper long enough to hold the full length of your selection and print. I get my paper at an art supply house.
