Apr 08, 2002, 06:05 PM
Palmdale, CA
Joined Oct 2000
Hold the tip of a torque rod equipped surface, and move the servo. The servo will move, the surface movement will diminish to zero at the tip.
This happens in flight to some extent.
Unless the surface is stiff along the hinge sxis of the torque rod, motion diminishes the further out from where the torque rod ends in the surface.
A direct connection is better.
Micro servos unless they're on steroids won't do much of anything on 30" span ailerons at speed, regardless of the type of connection.
