Old May 03, 2005, 01:03 AM
igo is offline
igo
Find More Posts by igo
igo
Joined Apr 2004
2 buck chuck foamy build
hello All, i will be showing you how i built this plane which first appeared in this thread:
http://www.rcgroups.com/forums/showt...4&page=4&pp=15
in the two pix shown, one is the current configuration and the other shows it with one in stock form.
igo is offline Find More Posts by igo
Old May 03, 2005, 01:07 AM
igo is offline
igo
igo
Joined Apr 2004
trip to big lots
yup, i found one for $1.49!! and here's how much it weighs as is.
Old May 03, 2005, 01:10 AM
snolord1 is offline
Find More Posts by snolord1
Krued Up
snolord1's Avatar
United States, MA, Chicopee
Joined Jul 2004
i've got 2 of those.i will start on them tomorrow
snolord1 is offline Find More Posts by snolord1
Old May 03, 2005, 01:13 AM
igo is offline
igo
igo
Joined Apr 2004
cut the rudder
to do this, you need to draw a line that you will cut along. the line is parallel to the elevator as possible. if not, just trim it out during maiden.
Old May 03, 2005, 01:19 AM
igo is offline
igo
igo
Joined Apr 2004
new elevator build
i hope the pix show enough detail with the rulers for you to copy. the material is bluecor. the hinges are made from overhead transparency sheets you get at staples or any stationary store. you cut them into 3/4" x 1/2" strips. add lead in features like a chamfer so they slip into slits cut into the foam easier. i used contact cement from left over supply from a gws pico stick i bought a long time ago.
Old May 03, 2005, 01:23 AM
igo is offline
igo
igo
Joined Apr 2004
more on elevator build
make sure that before glue dries that you get enough pivot travel.
Old May 03, 2005, 01:27 AM
igo is offline
igo
igo
Joined Apr 2004
twin vertical fins
use stock elevator to make the twin vertical fins and to fill the stock elevator slit in foam.
Old May 03, 2005, 01:40 AM
igo is offline
igo
igo
Joined Apr 2004
wings
the wings are reinforced by a bamboo skewer. it's bbq season so you should have some laying around. trim to about 5-6 inches. make sure you don't trim off the pointy end. measure and mark center of bamboo skewer. carefully insert with a constant clockwise and counter clockwise twisting into the wing. do the same to the mating wing. this might take a few tries because it's not easy to get the wings to mate up properly. now apply epoxy on the stick as it goes into the premade holes. apply epoxy only to the top side of the wings and the joining surface. DO NOT PUT EPOXY ON THE BOTTOM SURFACE OF THE WINGS. insert one wing into the fuselage of the plane. then epoxy the other wing upper surface only and insert the wing into the fuselage to mate with the other wing half with bamboo skewer.
Old May 03, 2005, 01:43 AM
igo is offline
igo
igo
Joined Apr 2004
more on wings
when you get them right, they should mate with every surface lined up with each other.
Old May 03, 2005, 01:48 AM
igo is offline
igo
igo
Joined Apr 2004
now glue elevator and twin vertical fins
this is what it looks like when ready for test glide. weight at this point is 1.5 oz. it gained .1oz since stock form. CG is 2.25" from trailing edge. yes, i measured from trailing edge because the trailing edge is straight and not swept so the should be no confusion on my edge of reference.
Old May 03, 2005, 01:51 AM
igo is offline
igo
igo
Joined Apr 2004
and here's why you don't put epoxy on wing bottom
it's so you can cut this section clean off. with this bottom put aside, you can start to add servos, receiver and esc.
Old May 03, 2005, 01:54 AM
igo is offline
igo
igo
Joined Apr 2004
next time i will cover motor mount, motor mount cover plate, aileron...
Old May 03, 2005, 02:59 AM
highace1 is offline
Find More Posts by highace1
highace1's Avatar
Newcastle NSW
Joined May 2004
Only if i could get one of those here in Perth, Western Australia.
Alex
highace1 is offline Find More Posts by highace1
Old May 03, 2005, 10:30 AM
snolord1 is offline
Krued Up
snolord1's Avatar
Joined Jul 2004
i'll sell you one for 5.00,if you pay shipping
Old May 03, 2005, 11:21 AM
igo is offline
igo
igo
Joined Apr 2004
please note on post 11, how far back the elevator assembly was bonded on. the elevator hinge is about 1/2 inches away from the tip of the tail of the plane. this is so that the elevator hinge will pivot without bumping into anything.
Discussion SSDC: 2 Buck Chuck 100% folded airfoil foam sloper theBOZman Slope 9 Nov 12, 2009 11:17 PM
Land Lover Foamy Build andyg Foamies (Kits) 7 Jul 15, 2005 09:19 PM
Yippee! Mountain Toys Gentle Foamy Build & Fly! parrothead Thermal 46 Jun 28, 2005 07:25 PM
P-51 foamy build Tawg Slope 46 Feb 13, 2005 08:40 PM
2 Saabs I'd like to build kennypinkerton Electric Ducted Fan Jet Talk 7 Nov 13, 2002 07:35 PM
