Old May 01, 2005, 10:37 PM
bilbobaggins is offline
Find More Posts by bilbobaggins
bilbobaggins's Avatar
Norwich. England
Joined Mar 2005
Help with tow hook position
Hello everyone, I want to convert a 2 metre slope soarer to a flat field bungee launch but am unsure of where to put the tow hook. Can you help please.
Bilbo.
bilbobaggins is offline Find More Posts by bilbobaggins
Old May 01, 2005, 11:40 PM
Vince inTX. is offline
Find More Posts by Vince inTX.
Vince inTX.'s Avatar
Santa Fe, Texas
Joined Oct 2002
bilbobaggins,
12-15 degrees ahead of the CG. Measure this with the plane upside down. place a protractor on the bottom of the wing (now the top) and place the "focal" point of the protractor on the CG. Now draw a line on the side of the plane forward (towards the nose) 12-15 degrees from 90. Where that line crosses the bottom plane of the fuselage is where you put your tow hook. This method works nomatter how tall the fuselage is.
This is a good starting point and should get you straight and stable launches. If the launches are not steep enough for your liking you can do one of two things. either move the cg forward (easy but not recomended) or move the tow hook back. I would not move the tow hook back any more than 1/4 to 1/2 inch at a time. As the tow hook gets closer to the CG your launches will become steeper but they will also require you to be much more active on the sticks.
Vince
Vince inTX. is offline Find More Posts by Vince inTX.
Old May 02, 2005, 04:50 AM
Norwich. England
Joined Mar 2005
Hi Vince, many thanks for helping so soon.
Kind regards
Bilbo
Old May 02, 2005, 11:00 AM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
Note. some slope models the wing is very close to the bottom, and that can create a stability problem on launch.
Some people compensate with a "bridle" (2 hooks spaced out on the wings and about 2 ft of line with a snap-clip in center to lock the bridle onto the towline) The fixed distances of the 2 lines to the wngs formng a triangle adds a little roll stability.
You can also compensate by launching more level and letting the model build speed before pulling for climb. (usually they nose-up on thier own... but with a low wing, the hook may not be low enough to pull the nose up for you.)
Its simply that there's no distance between hook and center of drag to make the hook help control the aircraft's attitude. Bungee launching a Zagi for example is a "fun" project if you don't know to watch for this.
fhhuber506771 is offline Find More Posts by fhhuber506771
Discussion Need Help with tow hook on a easy glider guyg Slope 6 Nov 05, 2006 07:17 PM
Aerotow tow hook position? Soarbird Modeling Science 1 Oct 14, 2004 07:37 AM
Tow hook position relates to CG or to CL? gustabmo Thermal 5 Jun 03, 2004 10:02 PM
How can i connect two thing with the tow hook in afp ? lamborghini Simulators 5 May 23, 2004 03:27 AM
can anyone help me with Aspach GPS position?! henke Electric Plane Talk 5 May 27, 2002 11:41 AM
