Old Apr 08, 2002, 03:55 AM
Masterpiece is offline
Find More Posts by Masterpiece
Hervey Bay, Sunny Qld, Australia
Joined Jun 2001
Promax 4011 with 3.7:1 g/box in a HLG
Hi
Just a quick enquiry about if it's worthy of putting a promax 4011 in a HLG with a 3.7 : 1 gearbox swinging a 11 x 7 prop.
I have a Robbe planetary gearbox with the Robbe power 4.8 volt sp 400 motor, but I'm hoping to change the motor to a promax 4011 (since the mounting holes are the same as a sp 400) as mentioned by modifying the motor shaft pinion in the gearbox with a slightly larger hole to accomodate the 3.2mm shaft of the promax 4011.
Also being a HLG I'll want to keep things light, so what would be the best batteries with this motor set up. I believe that the 600maH batteries used for sp 400 won't handle the current draw. Is this true and if so what batteries would be better therefore?
G
Masterpiece is offline Find More Posts by Masterpiece
Sold Aveox 38/36/2 with 3.7:1 G.B. & SH-48 esc Rod Aircraft - Electric - Airplanes (FS/W) 12 Oct 11, 2005 11:49 AM
Ebay: Aveox 1415/3Y with 3.7:1 Gearbox, NIB soareyes Aircraft - Electric - Airplanes (FS/W) 0 May 29, 2004 09:32 AM
Rave Wtd: Planetary 3.7:1 gear box Lewis Adam Aircraft - Electric - Airplanes (FS/W) 0 Jan 27, 2004 08:46 PM
New - Hacker B50-11s Brusless Motor with 6.7:1 gear box! comes with Precision s Joe Pierson Aircraft - Electric - Airplanes (FS/W) 0 Mar 25, 2002 08:31 PM
Aveox 1406/2Y with 3.7:1 Planetary Gearbox (NIB) Ed Lyerly Aircraft - Electric - Airplanes (FS/W) 1 Jan 18, 2002 08:39 PM
