Old May 28, 2001, 01:27 AM
Jeremy_D is offline
Find More Posts by Jeremy_D
RC Addict
Jeremy_D's Avatar
Central Coast, Australia
Joined Jan 2001
need some help finishing my mini ifo.
Hi guys, well my mini ifo arrived in Aus today and 3 hours later the frame construction was complete. At this stage I will be using the gws setup, so my querie is...
what is the best way to mount the gws motor onto the frame. Also any other tips would be great.
Many thanks
Jeremy..
Jeremy_D is offline Find More Posts by Jeremy_D
Old May 28, 2001, 10:36 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
I put the motor on sideways then used a zip tie to keep it put.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old May 28, 2001, 02:38 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
I cyano a piece of 1/64 ply on the top of the frame in the motor location, followed by 3/32 balsa either side of the fuselage rod, followed by another piece of 1/64 ply, so that you have a platform sandwiching the rod.
I then cyano a rectangle of 3/32 balsa to the top of the GWS gearbox frame, followed by a rectangle of 1/64 ply. I soak the faces of the motor and fuselage platform ply in cyano to seal and stick the motor platform to the fuselage platform with servo tape. The latter gives slight shock absorbence which helps to keep the motor on if you hit the floor, wall or another Mini IFO!
I used to cyano the gearbox frame direct to a piece of 3/32 stuck to the airframe, but in every collision it used to come off. I now very rarely lose the motor.
We fly 6 Mini IFO's at a time in a 2/3 basket ball court and collisions are common. In two months, I have burnt out one motor, destroyed 3 gearbox frames, one prop shaft, 3 props and one plastic gear, so I should keep some spares
Mike Smart
Mike Smart is offline Find More Posts by Mike Smart
Old May 28, 2001, 05:24 PM
TTT is offline
TTT
Find More Posts by TTT
TTT
Toowoomba Qld Aust
Joined Jan 2001
HI Jeremy
how much did your kit cost including shipping?
What electronics are you using? and especially what flight pack?
I am wanting to go down same path if Mr Hadkins would answer his email so I could buy some carbon rod.
If anyone know of any one else who deals in C/F rod in Oz please let me know....
I know of one other dealer in Melbourne(Knut Newman) but he is 50% more expensive than the WES bits from Wayne
Where are you getting your GWS gear from and what is it costing you?
Terry
TTT is offline Find More Posts by TTT
Old May 28, 2001, 05:49 PM
Jeremy_D is offline
RC Addict
Jeremy_D's Avatar
Joined Jan 2001
Thanks for the replies Guys.
Jim,
I've done a similar thing to what you have done, see how it works.
Mike,
I like your idea,do you have a photo you could post or email me, it sounds the most efficient way to do it.
Terry,
Checkl your email.
Thanks for all your input.
Jeremy..
I need some help with my Pulsar Mixes mauiguy99 Electric Sailplanes 1 Dec 13, 2003 12:10 PM
need some help building my Rally XP Pics included kushal_22 Parkflyers 5 Jul 03, 2002 12:23 PM
Need some help with my GS400 ESC VWtechie Power Systems 0 Feb 18, 2002 12:51 PM
Need some help with my Starlite. Lucas in Alaska Parkflyers 10 Jan 30, 2002 10:45 AM
Need some help with my latest plane wim5150 Electric Plane Talk 2 Aug 08, 2001 04:29 AM
