Old Apr 30, 2005, 03:45 PM
MikeTwain is offline
Find More Posts by MikeTwain
MikeTwain's Avatar
Joined Sep 2003
Mountain Models Miniflash: Build question
I just received my Miniflash kit today and I started building the fuse. This thing is so easy to build I feel like I must be cheating or something! It's like working with legos
Anyway, I have a question about the build and I'm hoping somebody out there who has done the model can answer a question.
I'm confused about the "motor mount stick" in the instructions. They have you create a sort of a square tube from 4 interlocking pieces of plywood, and the instructions seem to indicate that this built up piece is the "motor mount stick" but there is a photo of the model that seems to show a solid balsa stick where the motor mount stick would go. My guess is that the solid balsa is from an earlier revision of the plane or something and that the new built-up piece is the new motor mount, but I want to be completely sure on this point before I glue.
Is the built up plywood piece the "motor mount stick" that gets glued into the motor mount plywood cross-pieces?
I guess I can always call MM on Monday but I was hoping to make some more progress this weekend.
MikeTwain is offline Find More Posts by MikeTwain
Old Apr 30, 2005, 04:11 PM
Brian Allen is offline
Find More Posts by Brian Allen
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
MIke
You are correct, the motor mount stick is built up from the four pieces of ply.
You can also use a solid stick which a lot of guys do. I am assuming that the photo in the manual shows a solid stick that Doug changed to the built up piece later on. You can drop him a note to comfirm this.
Hows the build going on? Almost like dropping a bottle of glue into the kit box, shaking it around and out pops a plane!!
Brian Allen
Veni Vedi Volavi
I came I saw I flew
Brian Allen is offline Find More Posts by Brian Allen
Old Apr 30, 2005, 06:27 PM
MikeTwain's Avatar
Joined Sep 2003
Thanks for the confirmation Brian!
You're right about the kit...ther is a HUGE difference between this build and the Guillows Stearman that I just "finished" (ie stopped working on once it was assembled, covered, and painted).
The laser-cutting alone makes a gigantic difference and the design of the kit is really elegant.
Fun build! And to think I almost gave up on balsa after that Stearman!
Old Apr 30, 2005, 06:30 PM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
Do make sure after you build the plywood motor mount stick that you test fit your motor/gearbox onto the stick and do any needed sanding before mounting the stick to make sure your motor/gearbox will fit nice and snug but not so tight that you can't push it on.
Jim
BrunswickOH is offline Find More Posts by BrunswickOH
Old Apr 30, 2005, 07:07 PM
MikeTwain's Avatar
Joined Sep 2003
Jim
Too late.
I did have to sand it quite a bit to get it to fit in the motor mount holes though, so hopefully I'll be ok.
I also have another quesiton. The MM site says that the required battery is a KAN 650 or 1050 "4 over 4" configuration pack. What does this mean? I was not able to find this terminology anywhere...although maybe my Google-fu is failing me today.
There seem to be a few configurations that might match this:
Code:
4 batteries lengthwise in two rows (CheapBatteryPacks calls this a "double stick")
Code:
o o o o
o o o o
4 batteries side by side in two rows (CheapBatteryPacks calls this a "brick")
Code:
o o/
o o
4 batteries lengthwise in two columns (CheapBatteryPacks calls this a "2x2")
Also, I can't seem to find any mention of the weight of the receiver. I was going to go with a HiTec Feather (seems Balsaproducts is still selling a few) but is it ok to go with a larger size?
Old Apr 30, 2005, 11:22 PM
elfwreck is offline
Find More Posts by elfwreck
elfwreck's Avatar
United States, CA, Oakland
Joined Dec 2002
Hey now,
When my first one was new I used an eight cell "stick" pack, two rows of four soldered end to end. Since then I switched to a 3s thunder power 2100 pack, Lighter, more power, longer flight times. I think they mean two rows of four, soldered end to end, that would work anyway...
As to the feather reciever? No way would I use one of those in this model!
You will fly it high and far, it loves high and far and the seven grams you save over a caseless 555 isn't worth the pain of such a limited reciever.
Hope this helps...
RobII
elfwreck is offline Find More Posts by elfwreck
Old May 01, 2005, 09:20 AM
Matthew Binder is offline
Find More Posts by Matthew Binder
The Evil Twin
Garden City, GA
Joined Feb 2004
Mike,
Yes, the motor mount is plywood. I'll check the manual to see if the picture is wrong, thanks for bringing it to my attention. The KAN 650 works fine in the MiniFlash... depending on what motor you use. Contact me if I can be of any further help.
Matthew
Matthew Binder is offline Find More Posts by Matthew Binder
Old May 01, 2005, 07:58 PM
Mike1484 is offline
Find More Posts by Mike1484
Elyria, Ohio
Joined Sep 2004
elfwreck,
I have the same combo as you in my Mini. Your right about the feather receiver being a no-no on this plane . The 555 or a Berg would be a better choice, the Feather is more of a test stand receiver in my shop,would not trust it in a plane. The little Himax 2015-4100 and the T.P.2100 fit real nice in this bird and gives plenty of giddy-up and long flight times.
Mike1484
Mike1484 is offline Find More Posts by Mike1484
Old May 01, 2005, 11:46 PM
elfwreck is offline
elfwreck's Avatar
Joined Dec 2002
Hey now,
I'm running a Himax 2025-4200, GWS "C" gear set, and a 10-7 APC slow flight prop. Unlimited vertical, and with the oversized ailerons (see avatar) I get ten rolls a second on high rates Too much fun, two and a half years with the Mini Flash and I still can't wipe the grin off my face
RobII
Old May 02, 2005, 12:01 PM
Mike1484 is offline
Elyria, Ohio
Joined Sep 2004
Mike Twain
Don't forget to use a screw to lock your gear box /motor to the motor mount,there's a hole in the bottom of the fuselage for this.I forgot to do this and paid the price,ouch! A small block of wood slid into the area where the screw enters the motor stick/box gives the screw some added bite. What motor and esc are you going to use in your Mini ?
Mike 1484
Old May 02, 2005, 12:17 PM
Mike1484 is offline
Elyria, Ohio
Joined Sep 2004
elfwreck
2025-4200 ? Sounds dangerous ,I'll have to try that!! Maybe I better order up another Mini first just in case ,don"t want to be with out a Mini !! I thought those ailerons looked a little big, just how much big are they? What gear box are you using?
Mike 1484
Old May 02, 2005, 05:59 PM
MikeTwain's Avatar
Joined Sep 2003
Thanks for the tip about the screw.
I ordered a GWS EPS 300C-D (The recommended brushed motor.)
I don't think I've ordered an ESC yet...but I can't remember. Maybe a GWS 15A one?
Old May 03, 2005, 10:34 AM
elfwreck is offline
elfwreck's Avatar
Joined Dec 2002
[QUOTE=Mike1484]elfwreck
Hey now,
Dangerous? Naw, just too much power (and too much of everything is just enough)
I always keep a spare kit in the wings, thatt way I'm not without for more than a week or two, gottaa feed that jones...
They're about half again as big as stock, they give me *great* roll authority. The gear box is a stock GWS "C" drive (5:33-1), I've broken a couple of them over the years but they work pretty well and last almost as long as the airframe
RobII
Old May 03, 2005, 10:41 AM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
Just to reiterate ... Don't go with a feather Rx . Use the 555, E6, or a Berg (just about any Rx but the feather ) .
Also the 'brick' or offset brick works really well . I think you got the brink defined wrong above . Should be four (side by side) over four (side by side) .
XXXX-/
.XXXX
rclark is offline Find More Posts by rclark
Old May 03, 2005, 01:02 PM
MikeTwain's Avatar
Joined Sep 2003
Thanks for the tip about the receiver...I ended up ordering the Hitec HFS-05mg which seems a bit more sturdy than the feather and has a longer range. To be honest I never fly any plane very far away (I don't have very large areas close to me to fly in) so this seemed like a good compromise.
As for the battery configuration...I think you were reading the description above each code block rather than the one below.
Mountain Models MiniFlash Build Question cubsflyer Parkflyers 4 Jan 01, 2005 07:40 AM
Miniflash build question. Eyefly Parkflyers 5 Jul 04, 2004 05:13 PM
Free Shipping on Mountain Models MiniFlash Zhack Aircraft - Electric - Airplanes (FS/W) 0 Mar 27, 2003 01:53 PM
MY Mountain Models MiniFlash Build Aldur Parkflyers 44 Mar 15, 2003 12:49 AM
Mountain Models Miniflash Speed-Wing sukhoi26mx Parkflyers 21 Dec 09, 2002 01:38 PM
