Old May 27, 2001, 07:04 PM
chlee is offline
Find More Posts by chlee
chlee's Avatar
Atlanta, GA
Joined May 2000
Well, e-flyer,
Lift force varies when you are climbing or diving. However, for level flight, the net vertical force is zero, so lift is simply equal to the weight of the plane.
What exactly is your task? Are you just curious, or do you have a specific project for which you need a figure (say, estimating max lift to see if you can carry a payload)?
You can get a very rough idea of the lift at some angle of attack if your wing has an airfoil with published polars.
Check out this *kick butt* site: http://soaring.cnde.iastate.edu/calcs/frames.shtml
EDIT: Website no longer exists!
It allows you to enter in wing area, span, model weight, and a bunch of airfoils, and you can compare Lift coefficients and Drag Coefficients, etc.
G'luck.
-Lee
chlee is offline Find More Posts by chlee
Last edited by chlee; Aug 16, 2007 at 12:07 PM. Reason: cited website no longer exists
Old May 28, 2001, 12:57 AM
e-flyer is offline
Find More Posts by e-flyer
Stuck in my wizard suit
e-flyer's Avatar
Deale,MD,USA
Joined Apr 2001
How do you find how many OZ. of lift your wing gets?
Is there a formula?
Thanks!
Alex
e-flyer is offline Find More Posts by e-flyer
Old May 28, 2001, 11:58 AM
WoFlyer is offline
Find More Posts by WoFlyer
Santa Fe , N.M., U.S.A
Joined May 2001
HAY E-FLYER THERE ARE ALOT OF PEOPLE WHO THINK THAT THEY HAVE SOME FOGGY CLUE! THIS IS ONE AREA OF OUR HOBBY THAT YOU WANT TO BE CAREFULL OF WHO YOU ASK. GAT YOUR SELF A BOOK CALLED R/C MODEL AIRCRAFT DESIGN.IT IS WRITTEN BY ANDY LENNON,IT IS RELITIVLY POINTED AT THE LAYMAN. OR READ ALISTAIR SUTHERLANDS ARTICLES IN R/C MODEL WORLD, HIS E-MAIL ADDRESS IS Alasdair_S@compuserve.com .HE IS A GREAT GUY AND HE KNOWS WHAT HE IS TALKING ABOUT. UNLIKE SOMEONE WHO THINKS A PLANE IS EVER NEUTRAL WITH ITS WEIGHT. SERIOUSLY EDUCATE YOURSELF, BUT BE CAREFULL!!! WO
WoFlyer is offline Find More Posts by WoFlyer
Old May 29, 2001, 12:48 AM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Wo, "gat" yourself a spell checker.. and find the lower case key on the keyboard.
And then read the messages for content.
With a plane in unaccelerated level flight,
the lift equals the weight.
The -net- vertical force is zero.
Sparky Paul http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul is offline Find More Posts by Sparky Paul
How do you find your own posts? direwolf Site Chat 8 May 22, 2007 01:51 PM
Wing Warrior Flyers: How do you set up your motors? waltj2k Flying Wings 7 Mar 06, 2005 06:14 PM
How do you know how many amps your NiMH can draw? jacobn Batteries and Chargers 3 Feb 18, 2005 11:31 AM
What do you use as a weighted bar for your wing core cutter ? NetForce2K Foamies (Kits) 1 Jul 26, 2002 07:27 PM
How do you respond to by-standers wanting to buy your plane while you are flying? john mcm Parkflyers 17 May 04, 2001 12:15 AM
