| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Hacker A20-34S performance
To complete the series available to me, (22L, 26M, 34S) here are some figures for the 34S.
You can draw your own conclusions, but it certainly seems from the low temperature figures that, at least on small props, this motor can cope with far higher amps than the specs would suggest [2A-6A continuous, 8A max]. One comment I would make is that it seems bizarre that the Hacker Spec Sheet only mentions one prop (8x3.8 APC SF) for this motor. They imply that this is the ideal prop on 2s, yet at anything above 6v it is in their "red zone" [DO NOT USE] because the amp draw (9.6A @ 7v) is well outside their 8A maximum recommended draw!!!!! Worse is that I measured 10.70A @ 6.9v with this prop - so it is even further outside their recommended comfort zone. Now Gary Wright will probably say - "I would prop for 12A and it would be fine" - and after running this little beast, I might be forced to agree with him! I wonder how/why Hacker arrived at the modest 6A continuous/8A max limit???? I imagine the "small combat wing" boys might show an interest in 81mph pitch speed with a 5.25x6.25 APC E, and if we allow that >9A on 3s is still okay, how about almost >18oz with a 7x3.5 GWS HD! Enough of my rambling - here are the numbers [which, dare I say it, are statistically not significantly different (students t) from those I measured using the ExtremeFlight Torque 34T]. I could post the graph, but it seems hardly worthwhile. Cheers, Phil Last edited by Dr Kiwi; Dec 18, 2008 at 01:28 PM. |
#2 |
Do it for fun
Good data Phil.
This motor looks like being a good direct speed 400 replacement on 3s. Similar prop sizes and I would think similar or better power output for 40% of the weight. Hacker could perhaps do with a lower KV motor in the A20-XXS size. Aidan |
#3 | |
Cheers, Phil |
#4 |
Moths do not fly inverted
Phil,
Thanks so much for the info, I recently bought a 34S to but on a Blitz bipe and I was not all that happy with the performance and I thought it might have been the motor but as it turns out I am seeing some substaintial sag in my 2S E-tech 700HP pack. At a little over 6A I am down to 6V. With the numbers you are showing my 6.7oz blitz should be an animal with this set up, guess I have to get myself a TP730 GII pack to check that out. Cheers, Jim |
#5 |
TP 730 and TP 900 seem to hold their voltage pretty well - especially once the packs heat up to ~35C - they are lousy when cold!
#6 |
Thanks Dr Kiwi looks like my new blitz may be getting one of these baby's with a 2 cell and 8 x 4 HD.......thanks!
Mac |
#7 |
seven ounce 3D model - 9x3.8 APC prop or 8x4 GWS- 3 cells 480 TP yellow stripe
absolutly great outdoor setup . For someone who is trying to fly a heavy model or run it flat out - NOT a good setup. This setup is a 14 amp burst amp draw setup! Our flying is typically pulling 4-6 amps unless we poke it . That's when this setup really takes effect. |
#8 | |
14amps out of a 8amp burst battery? Mac |
#9 | |
Cheers, Phil |
#10 |
So dr. Kiwi is there a better choice in your opinion other than this motor for a EPP Blitz?? Also what battery would you recommend?
Mac |
#11 |
I just maidened my Blitz today with an AUW of just a tad over 7oz with this 34s motor swinging a 8 x 3.8 SF prop, in Dr. Kiwi tests yielded over 14oz of thrust. This should give me a 2:1 ratio which is what I was hoping for. I need to use 3/4 stick to hover and pullout is barely OK. I'm using a 2s 900mah pack which I know should deliver over 10amps. I'm using these same cells in a 3s pack that I have measured 12 amps coming out of them. I guess a need to throw a meter on my setup later tonight to see whats going on. Also I'm barely getting 8-10 minutes of flying with the 900mah pack.
Mac Last edited by cmacclel; May 16, 2005 at 11:00 AM. |
#12 | |
Remember that the Hacker web site says 6A continuous/8A burst max for that motor. Last edited by Dr Kiwi; May 16, 2005 at 04:46 PM. |
#13 |
Know of any good dealers that carry the GWS props on the east coast?
Mac |
#14 | |
#15 | |
Perfect.....I hate wating 5-7 days for shipping from the west coast! Mac |
| Thread Tools | |
| For Sale F/S Hacker A20-34S | Ted U | Aircraft - Electric - Airplanes (FS/W) | 5 | May 30, 2005 09:42 PM |
| AXI 220454 vs Hacker A20-34S? | JeffAaron@aol.com | EFLIGHT Mailing List | 1 | May 12, 2005 09:11 AM |
| LensRC 17T VS. Hacker A20 /34S | LJH | Power Systems | 9 | Mar 29, 2005 02:53 PM |
| hacker a20-34s powered delta! | jacob_zurasky | Electric Plane Talk | 2 | Mar 25, 2005 03:59 PM |
| Hacker A20-34S measurements | Mike Wizynajtys | Power Systems | 5 | Mar 02, 2005 09:47 AM |
