Old Apr 27, 2005, 08:29 AM
fatboy999 is offline
Find More Posts by fatboy999
fatboy999's Avatar
Canada, ON, Tillsonburg
Joined Feb 2005
electric motor sizing
Can someone tell me what the different sizes of electric motors are? I see 380's,400's,480's,500's,etc. What do these numbers mean or relate to? Is there a chart that I can download on these motors? Thanks,fatboy999
fatboy999 is offline Find More Posts by fatboy999
Old Apr 27, 2005, 12:06 PM
CG Bob is offline
Find More Posts by CG Bob
KC8WPF
CG Bob's Avatar
Euclid, Ohio, United States
Joined Sep 2004
Generally the motor sizes relate to the diameter and length of the motor can.
280/380 size motors have cans that are just under 1" in diameter and 1.25" long.
400/480 motors are about 1.2" diameter and 1.75" long
540/05 motors are about 1.5" diameter and 2" long, they generally have a 1/8 inch shaft.
There are other motor considerations to make besides the size of the motor.
# of turns - the number of turns of wire on each leg of the armature, plus the wire size or gage. Generally, "stock" 540 size motors have 27 turns of 22 AWG wire on three or five arms.
RPM @ Voltage - when comparing motor speed (RPM), it is important to compare them at the same Voltage.
CG Bob is offline Find More Posts by CG Bob
Old Apr 27, 2005, 05:12 PM
Ghost 2501 is offline
Find More Posts by Ghost 2501
no wings any more, just dust!
Ghost 2501's Avatar
stoke on trent
also, there are "385" motors, which look externally identical to a 380, but inside they have 5 poles, not 3, and so are slower turning, and less prone to over heating, better for scale ships, rather than fast electrics
Ghost 2501 is offline Find More Posts by Ghost 2501
Old Apr 27, 2005, 09:44 PM
CG Bob is offline
KC8WPF
CG Bob's Avatar
Joined Sep 2004
I got this from the Mabuchi Motors web site. Most of the motors we use for R/C propulsion are the RS series.
Old Apr 28, 2005, 05:31 PM
patmat2350 is offline
Find More Posts by patmat2350
Vita ex Machinis
patmat2350's Avatar
Motor City
Joined Dec 2004
If u clik on the link "search by designation", you can more easily look at their stock range and then at individual can dimensions. Most motors will be similar, but may vary by can and shaft length.
PM
patmat2350 is offline Find More Posts by patmat2350
Old Apr 29, 2005, 09:02 AM
fatboy999's Avatar
Joined Feb 2005
Hi Bob, tnx fer the info on the electric motors, very interesting. I noticed KC8WPF under your name and thought it was an amateur radio call sign. I checked it out on QRZ.COM and sure enough, you are a fellow ham. I am VE3JFB/VE3MZ. Home QTH is Tillsonburg, Ontario..........73's.....Dale
Old Aug 20, 2005, 10:58 AM
Kg4ceo is offline
Find More Posts by Kg4ceo
Amateur Radio N4FOX
Cumberland Furnace, TN
Joined Apr 2005
Hey thanks for this info. I have been looking for it.
Kg4ceo is offline Find More Posts by Kg4ceo
Electric motor break in DaleM Power Systems 12 Jun 13, 2014 03:06 AM
Comm Drops on electric motor e-sailpilot86 Beginner Training Area (Aircraft-Electric) 11 Apr 21, 2009 12:32 AM
Question Electric Motor Sizing sadamspmp Power Systems 1 Jan 02, 2006 09:23 AM
electric motor direction foamman01 Electric Plane Talk 1 Oct 11, 2001 09:30 PM
Electric motor & prop for a HLG Butch B Electric Sailplanes 3 May 30, 2001 12:58 AM
