Old Apr 27, 2005, 08:11 AM
Hanzepanzekevertje
Hanzepanzekevertje
Guest
n/a Posts
Electronic or mechanical speed control?
Which is better for off-road backyard bashing with my old Tamiya Blitzer Beetle (27t Corally and 3000 Nimh)): the standard mechanical Tamiya speed control, or a cheap electronic speed control (with reverse)? I know the latter will deliver some longer runtimes, but will it also take some of the speed and thus fun away?
Old Apr 27, 2005, 02:11 PM
Jack Conley
Jack Conley
Guest
n/a Posts
Re: Electronic or mechanical speed control?
if electonic speed controls took speed away then nobody would be racing with them. an esc is by far the best way to go. there are no draw backs to it. novak is a very reliable name brand and would have a "cheap" speed control that suits your needs. just do a little research. but get rid of that old mechanical speed control.
"Hanzepanzekevertje" <pans03@zonnet.nl> wrote in message news:59980$426f7b2e$52ac08a8$27584@news.versatel.n l...
Hanzepanzekevertje
Hanzepanzekevertje
Guest
n/a Posts
"Jack Conley" <jconley@cableone.net> schreef in bericht
news:116vj55o81jadf9@corp.supernews.com...
Does it matter much if it is high frequency or not??
Old Apr 27, 2005, 06:11 PM
Techpriest
Techpriest
Guest
n/a Posts
For bashing, just get a cheap reversible. Don't worry about freq, steps,
adjustable braking, etc. That stuff is for racing.
Another big advantage to the ESC is that when your battery drains the
vehicle simply stops, with the manual the servo stops in it's poisiton and
the vehicle continues to run until you catch it and unhook the battery, or
force the servo to neutral.
news:ea23a$426fde1f$52ac08a8$15616@news.versatel.n l...
with
Old Apr 28, 2005, 06:11 AM
TyBreaker
TyBreaker
Guest
n/a Posts
This is only a problem with nitro cars - the electric Beetle will slow
down and stop as the battery drains. I've also heard the extra run time
ESC's deliver is only 10-15% so ideally you'll get an extra minute or
two if your normal runtimes are 10 mins. Time tends to fly when bashing
so it's hardly noticeable. The biggest advantage I find in ESCs is the
more realistic (smooth) acceleration compared to the 3-speed MSCs.
Old Apr 29, 2005, 08:11 AM
Jonathan Hodgson
Jonathan Hodgson
Guest
n/a Posts
The runtime improvement will be greater if you drive at part-throttle a
lot. If you're flat out all the time, there'll be very little
difference in that respect.
Jonny
Old May 12, 2005, 06:11 PM
Techpriest
Techpriest
Guest
n/a Posts
I have had a Tamiya Striker and Tamiya Blitzer Beetle with manual
speedos and both would drive off into the sunset when the battery got
to low. I would have to chase the vehicle down and either pull the
battery or move the servo to N manually. At a certain voltage the
reciever quits working but there is still enough juice to power the
motor slowly. The servo stays in the last position it was told to go
to (forward usually). While not a high speed chase by any means, if it
is far enough away when it happens it is still a pain. I had one hit
an object and stop, but voltage kept going to the motor. By the time I
got it shut down the motor was cooked.
Some do have off switches, but that is only for the reciever. It will
not stop juice from going to the motor.
Old May 14, 2005, 04:11 AM
the_atomic_punk
the_atomic_punk
Guest
n/a Posts
"drive off into the sunset" LOL! ha! ha! ha!
Now that is funny! When i read that i could definately envision some
chump racing after a R/C vehicle! LOL! I have been there with nitro
early on.Only to run for a while,then see the crash,dust cloud and then
unfortunately the tears.Packing it all up and going home.
Then you start the tally,how much was broken and how much is this going
to cost.
Worst case scenario is when the parts are on backorder or a serious
break(chassis bent,motor cracked) :_( (thats a tear)
I definately use ' failsafes' ! This definately brought back some sad
memories.
the_atomic_punk
the_atomic_punk
Guest
n/a Posts
to cost.
I definately use ' failsafes' ! This post has definately brought back
some sad memories.
Old May 14, 2005, 06:11 AM
TyBreaker
TyBreaker
Guest
n/a Posts
I find this hard to believe - a receiver requires a tiny amount of
voltage compared to a motor - it is always the motor that will die first
unless you've managed to change the laws of physics. Or you had a
separate battery pack running the two items? The symptoms you describe
would only happen on a nitro vehicle where the on-board battery pack
powering the receiver goes flat while the nitro fuel keeps the engine going.
Old May 15, 2005, 06:11 PM
Jonathan Hodgson
Jonathan Hodgson
Guest
n/a Posts
It *is* possible to get a (low-speed) runaway with an electric vehicle,
using a single battery pack.
What happens is the servo moves the speed controller to 'forwards',
which connects the drive motor to the battery, which causes enough
voltage drop in the drive battery that the Rx/servo can no longer return
the speedo control to 'off'.
You can get similar symptoms with an ESC, but it's generally only a
temporary loss of steering - releasing the throttle cuts drive to the
motor in all situations I've come across.
Jonny
Old May 16, 2005, 06:11 AM
TyBreaker
TyBreaker
Guest
n/a Posts
Hmmm, this sounds like a job for Mythbusters! I think if the battery
has insufficient charge to perform that action, how is it possible to
turn an electric motor? Motors draw a significant current to spin their
armature, I would imagine a lot less than a receiver would need.
My old Frog always slowed to a crawl and never experienced this issue.
In fact, I think even the steering servos remained functional (if I
lifted the vehicle off the ground to remove the burden of weight) for a
perod after there was insufficient strength in the battery to propel the
vehicle forward any longer.
Old May 17, 2005, 04:11 AM
Michael Christie
Michael Christie
Guest
n/a Posts
> Hmmm, this sounds like a job for Mythbusters! I think if the battery has
> insufficient charge to perform that action, how is it possible to turn an
> electric motor? Motors draw a significant current to spin their armature,
What Jonathan describes does happen - I've seen it myself.
The RX and servos have a minimum voltage that they require in order to
operate. I don't know exactly what this voltage is but I would suspect it
would generally be around about 5V. It doesn't matter how much current the
battery can supply, if the voltage is below the required minimum, the
electronics within the radio gear will simply not operate.
In contrast, the motor doesn't have any electronics (that will only operate
within certain voltage ranges), it is just a simple electical device.
Therefore, it will continue to operate at a lower voltage than the radio
gear. It may not go very fast, but it will still spin.
Michael
WTB: Phoenix 35 or similar speed control skeppley Aircraft - Electric - Airplanes (FS/W) 2 Mar 24, 2005 10:50 AM
WTB: 8 amp or higher speed control pc_pilot Aircraft - Electric - Airplanes (FS/W) 7 Mar 23, 2004 06:25 PM
