Old Apr 25, 2005, 10:29 PM
nxtdoor is online now
Find More Posts by nxtdoor
Tulsa Jones, Oklahoma, United States
Joined May 2002
Need Power Supply to run 2 chargers
I am in need of a power supply to run two Astro 109's from 120v.
Hopefully someone has done this with something at a reasonable cost.
Thanks.
Jeff
nxtdoor is online now Find More Posts by nxtdoor
Old Apr 25, 2005, 10:47 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Thanks.
Jeff
Depends on how many watts they will be operating at and your defination of reasonable. An astro Flight switching power supply will provide 13.5 volts at 12.5 amps.which is approximately 168 watts available here for $70 . A 12 volt battery being charged(maintained) with a charger will power a bunch of chargers depending on the size of the battery and the charger output. I use a 80 Ah deep cycle gell cell with a 45 amp. 13.8 volt power supply maintaing the battery. Six chargers,two Ham Radios all running at once and never a problem.
Charles
Old Apr 26, 2005, 02:15 PM
Skippy 1 is offline
Find More Posts by Skippy 1
Flint, MI
Joined Jan 2004
Hereís a couple of nice power supplies. I use the 45amp but depending on your charging requirements you could go with the 25amp. The power supplies have built in cigarette lighter for running other accessories and also power taps on the rear. After 2 years of service Iíve had no problems or concerns with it. They are not cheap but well worth the money.
http://www.mfjenterprises.com/products.php?catid=18
Skippy 1 is offline Find More Posts by Skippy 1
Question Can I Run 2 Chargers Concurrently On A 20 Amp Power Supply? cobull Batteries and Chargers 9 Aug 17, 2007 10:48 AM
Power supply with DC chargers G. Zod Batteries and Chargers 39 Oct 14, 2004 12:03 PM
Need power supply for testing motors mgdon Batteries and Chargers 8 Aug 20, 2004 04:14 PM
Need a power supply for my charger Ralph_D Parkflyers 12 Jun 05, 2004 01:33 PM
