Old Apr 25, 2005, 06:42 PM
AirWarriorBelgy is offline
Find More Posts by AirWarriorBelgy
Captain Carnage says......
AirWarriorBelgy's Avatar
Seminole (St Pete.), Florida/ Seminole Crash Fest
Joined Jun 2002
Mountain Models ETana build thread
First
Congratulations to Doug Binder for winning the "Best New Product" award at SEFF 2005. As most of us already know Mountain Models has produced quite a range of parkflyers over the past years. Most notably the Switchback, Dust stick, Mini Flash, Cessna, Tantrum, to name a few.
So when I cornered Doug and Matt at SEFF on Thursday evening after he had pretty much just arrived i asked him about the top secrete plane.
He explained that, after seeing my Mini- Funtana, that I would just want to throw it away after seeing the "ETana".
He explained that his goal was to truly create a full fuse sport 3-D aircraft that was a little more scale in nature to the true Kitana, but not exactly the same.
When I saw the prototype early Friday a.m. I knew 4 things right away.
1) it ws not going to be difficult to build / assemble
2) it is big @ 44" wingspan
3) it will fly as designed (after all its a Mountain Models kit)
4) I had to get one
so without further ado..............
I opened the "box" (no bag this time) and shook out the kit.
Then came the fun part........
after gluing up the bottom and sides I couldn't help but note that Doug has manages to create 14" of surface joint in a 3" span of balsa to create the spliced two piece slabs. (Good job Doug, see me about a cabinet building project )
TIP:
The directions that came with these preliminary SEFF kits were by Dougs own admittance a little rough in some spots, and he relocated the landing gear mount back one former space after creation of the directions.
set the blind eye screws in the Gear mount plate and set the plate in the bottom of the fuse prior to setting in bulheads 2 and 3...you'll thank me later for this one.
Then the Bulkheads are pushed into place. As always with Mountain Models kits, the laser cutting is so precise that any misalignment tends to make one think "oops I need the sandpaper here" but don't do it...just recheck your alignment and the parts lock right together.
Next your directed to fit the sides on, I would suggest you fit one side then install the bulkhead formers shown in the pictures for step 4,5,and 6 , then install side two. for me this was easier than trying to manipulate fragile balsa and my fat fingers between the two sides. Then pop in the plywood crutch, and the canopy magnet support.
Once all the formers and crutch are in place......and everything looks good.......when your really sure all is ready......Let the CA flow and make smoke!!
After the smoke clears install the wing spar supports making sure alignment is perfect (I did this with drill bits), then set the front fuselage former and glue into place....Epoxy is recommended, since I will be using an AXI 2820/ 12, I took this advice to heart ( Goog Lord 400 watts on a 200 watt design)
After the fron former is in i installed the tailwheel support and rear former at the same time (watch out not to twist he tail before you glue the 2 pieces in....its easy to do )
next its time to set up the turtledeck, sheating, rear turtledeck blocks . its then time to add, the only thing you can add to plane, that doesn't increase the overall weight.....yup....you guessed it......Sandpaper it took about 20 minutes to get her the way I wanted her.
Tip: If you have ever turned wood on a lathe you know you saw the corners off to get a more rounder chisel friendly shape, I did the same with the Turtle deck blocks using a #11 blade very carefully and proably saved about minutes of sanding.
and here is the fuse so far............
next post will be wings
AirWarriorBelgy is offline Find More Posts by AirWarriorBelgy
Old Apr 25, 2005, 06:44 PM
Joined Jun 2002
a few more to finish the fuse pics
Old Apr 25, 2005, 06:50 PM
heliguy1232 is offline
Find More Posts by heliguy1232
heliguy1232's Avatar
Dallas Texas
Joined Dec 2004
HHAAA very very nice this might be my first balsa 3der
heliguy1232 is offline Find More Posts by heliguy1232
Old Apr 25, 2005, 07:19 PM
SkyPyro is offline
Find More Posts by SkyPyro
Burnin' holes in the sky!
SkyPyro's Avatar
Gilbert, AZ
Joined May 2003
Looks awesome! I can't wait to build mine .
Dan
SkyPyro is offline Find More Posts by SkyPyro
Old Apr 25, 2005, 07:24 PM
aV8ter is offline
Find More Posts by aV8ter
aV8ter's Avatar
Alpharetta, GA
Joined Sep 2004
Looks great!
aV8ter is offline Find More Posts by aV8ter
Old Apr 25, 2005, 07:34 PM
mle2tie is offline
Find More Posts by mle2tie
what does this button do?
mle2tie's Avatar
Wilkes-Barre/Scranton Wyoming Valle, Pennsylvania, United States
Joined Sep 2004
sigh, now i have to buy a new tx w/ more model mem.
mle2tie is offline Find More Posts by mle2tie
Old Apr 25, 2005, 07:42 PM
RickC2009 is online now
Find More Posts by RickC2009
RickC2009's Avatar
USA, NY, Brookhaven
Joined Mar 2003
looks great!
Keep the pictures coming!
Rickc
RickC2009 is online now Find More Posts by RickC2009
Old Apr 25, 2005, 07:54 PM
mike3976 is offline
Find More Posts by mike3976
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
OOHHH BOY, Doug is going to have a winner on his hands! What is the WEIGHT?? This is going to be one nice bird.
mike3976 is offline Find More Posts by mike3976
Old Apr 25, 2005, 08:02 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
25 Oz is what I heard from the SEFF thread
BoneDoc is offline Find More Posts by BoneDoc
Old Apr 25, 2005, 08:05 PM
turbojoe is offline
Find More Posts by turbojoe
M0unt@in M0del$ minion
turbojoe's Avatar
United States, AZ, Mesa
Joined Jul 2002
Sadly I've only flown the early prototype Doug gave me at the Arizona Electric Festival one time. I didn't have the right power system on it and I was flying it without the cowling. Although those two things wreaked havoc on performance it still flew well. Doug assured me this plane was nothing like what the final release would be though. That's why I've kept my mouth shut about this plane until now. Knowing Doug won't sell anything until it's "right" the new plane should be nothing short of awesome. I just got a Himax 2812-850 outrunner that I plan to throw in mine. Hopefully it'll be better suited than the 2025 that was in it before. I also have the cowl for it now so that should clean it up quite a bit in the aerodynamics dept. I'll have to pick up one of the new kits soon though.
Joe
turbojoe is offline Find More Posts by turbojoe
Old Apr 25, 2005, 08:14 PM
fwilly is offline
Find More Posts by fwilly
Pro Bro #495
fwilly's Avatar
Farmington NM
Joined Apr 2002
Wow, thats a great looking plane!!!
fwilly is offline Find More Posts by fwilly
Old Apr 25, 2005, 08:56 PM
davidsons is offline
Find More Posts by davidsons
davidsons's Avatar
Joined Feb 2004
So when will the kit be available for purchase? I don't see it on their website!
Steve
davidsons is offline Find More Posts by davidsons
Old Apr 25, 2005, 09:09 PM
KillerAir is offline
Find More Posts by KillerAir
Plane dodger
KillerAir's Avatar
Stratford Sikorsky, Connecticut, United States
Joined Dec 2001
Nice, nice, nice. But AirWarrior, really a 2820-12? jeezumcrow man. Will the frame hold that kind of power? I would think a 2808-24 would be perfect at 25oz. Keep going and I am following this thread.
Killer
KillerAir is offline Find More Posts by KillerAir
Old Apr 25, 2005, 09:10 PM
Doctor Who is offline
Find More Posts by Doctor Who
Timelord
Doctor Who's Avatar
USA, IN, Muncie
Joined Mar 2002
Kits should be available by weeks end I believe. Doug and Matthew won't be back home till tomorrow.
I found out first hand at SEFF that not only do they make great planes, but they are both good guitar players as well.
Doctor Who is offline Find More Posts by Doctor Who
Old Apr 25, 2005, 09:15 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Congrats to Doug and Matt for a great looking new plane. The ETana looks like a must have.
Congrats to Chuck for getting one, the pics look nice, can't wait to see it fly in person.
Wayne
Basketcase is offline Find More Posts by Basketcase
Build Log Mountain Models ETana build thread - Part II SchiessCo 3D Flying 640 Sep 12, 2015 09:33 PM
Mountain Models Magpie build thread Rat Parkflyers 19 Dec 31, 2008 08:45 PM
Mountain Models Miniflash: Build question MikeTwain 3D Flying 17 May 11, 2005 09:05 AM
Mountain Models MiniFlash Build Question cubsflyer Parkflyers 4 Jan 01, 2005 07:40 AM
MY Mountain Models MiniFlash Build Aldur Parkflyers 44 Mar 15, 2003 12:49 AM
