Old Apr 06, 2002, 01:22 AM
thelocust is offline
Find More Posts by thelocust
aka ben wilson
thelocust's Avatar
louisville, ky, usa
Joined Mar 2001
fan-fold wing forming -- on the cheap
hey all -- i'm currently working on some wings for a fan-fold edf plane, and i'm wondering about how to form different wing foils, or if you need a "foil" at all with some designs. I really don't have the time or materials to make a proper jig (like the ez-bake design in the big ol' "so i bought..." thread).
so -- what household items can be used to make uniform (reasonably) wing foils? do you normally use heat? also, the more pics and details the better! thanks a bunch in advance.
thelocust is offline Find More Posts by thelocust
Old Apr 06, 2002, 01:59 AM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
for me i dont believe there is a better way than baking em locust.. try it ya may like it.. Take Care and Keep Em Flying.. Vyceroy
Vyceroy is offline Find More Posts by Vyceroy
Old Apr 06, 2002, 07:25 AM
emoone is offline
Find More Posts by emoone
emoone's Avatar
La Grange, Georgia, United States
Joined Nov 2001
I made a jig out of fan fold and zapped it with my hairdryer. Took a LONG time to get any kind of true foil shape that would stay. I tossed the same setup in the oven on a disposable aluminum baking pan and it did much better in 5-10 minutes at 175 degrees.
The jig only lasts a few times this way because the heat of the oven deforms it over time but I got 3 sets of matching wings out of it before it was retired. I basically just took a flat base sheet od foam and taped a spar to it to fold my wings over. I also ended up cutting out a cover sheet to place over my wing. I simply use dollar store spring clamps to hold everything down.
I'd still like to make a real jig though ......
emoone is offline Find More Posts by emoone
Old Apr 06, 2002, 05:53 PM
Topeka Tom is offline
Find More Posts by Topeka Tom
Topeka, KS
Joined Mar 2002
You can get a pretty good airfoil on the fly with a hobby heat gun and a mailing tube. Heat the foam and hold it over the tube until you get about the shape you want. You need to be careful with the hot foam or wear gloves (or both). Apply a little patience along with the heat. I think my first wing took ten minutes, longer than it would have with a jig.
BTW, my first wing took on a nice dihedral without any effort on my part, apparently as a result of shaping the airfoil.
Although I was totally satisfied with the trial wing, I intend to build a jig someday. A concern is whether one size jig will fit all wing applications. I can see how it might fit most. I really don't want to build a jig for every plane.
Topeka Tom is offline Find More Posts by Topeka Tom
Old Apr 06, 2002, 07:57 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
dont have to build a jig for every wing type.. the ribs used to get airfoil are removable for changing .. take care.. Vyceroy
Old Apr 06, 2002, 09:07 PM
epoxyflyer is offline
Find More Posts by epoxyflyer
Cleveland,Ohio.
Joined Mar 2002
I would love to see some of those jigs you guys have made. Any pics? Getting ready to make a fire in the wifes stove
epoxyflyer is offline Find More Posts by epoxyflyer
Old Apr 06, 2002, 09:49 PM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
I've really had good luck just gently hand forming an airfoil using a heat gun and a foam vise. My Black & Decker Workmate makes a dandy vise, but two pieces of dowel in a two 2" x 4"s will allow you to bend foam pretty uniformly with a heat gun. With a little practice you can get some repeatability. OK, you guys are gonna make me post a design.....
CenTexFlyer
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Apr 06, 2002, 10:15 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Epoxy here is the thread that has pics of my jig and Hippos jig..
(credit where its due) hippo is the one that got me interested in the jig.. and gave me the dimensions and all.. you will have to sift through the pages .. but trust me its well worth reading the thread and rereading it.. i still go back through and look at it and all the progress made..the best thread on the zone IMHO.. Take Care and Keep Em Baking.. Vyceroy
http://www.rcgroups.com/forums/showt...6&pagenumber=1
Old Apr 06, 2002, 10:23 PM
Near Austin
Joined Dec 2001
OK, I'll have to post this in three pics, but here goes....
Old Apr 06, 2002, 10:24 PM
Near Austin
Joined Dec 2001
At least they're really small pics....
Old Apr 06, 2002, 10:26 PM
Near Austin
Joined Dec 2001
And this gives you a "form" to bend your wing over while you heat it. All materials readily available from your friendly Ace Hardware man and your wife doesn't get P.O.'d when you accidently forget about your wing in the oven and polystyrene drips all over the rack and the bottom.
Old Apr 06, 2002, 10:30 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Umm centex .. did ya forget a wing and leave it in oven?? lmao .. i left one once.. but no drip.. just a very brittle wing.. hard as heck but very brittle.. Take Care and Keep Em Flying... Vyceroy
Old Apr 07, 2002, 12:24 AM
aka ben wilson
thelocust's Avatar
louisville, ky, usa
Joined Mar 2001
dowel idea
wow! i love that dowel idea! 'cause i'm thinking about making some wings that aren't just the rectangular type -- more towards regular plane-type wings. though, i may just go the wal-foamie way.
thanks a bunch for all the tips!
Old Aug 12, 2002, 06:16 PM
mayday911 is offline
Find More Posts by mayday911
Joined Jul 2002
Veceroy
Man, that has got to be the longest thread. I searched for your pics on the wing jig but was unsuccesful. Honestly, i couldn't bring myself to search the entire thing. All i can say is "Holy Moly" that thread is out of control. Any way, found some miscellaneous tidbits about you using .020 aluminum for top and bottom and how you mentioned changing ribs in jig for airfoil to compensate for building entirely new jigs. Can you please display how you achieve this. Or point me out to what page specifically demonstrates it so i can skip ahead. ( I quit on pg50something) Is the aluminum flimsy enough on the top that it will sandwich the foam on the airfoil you have chose and not have to make a new top aluminum peice for each wing?
I may be on entirely the wrong track here but would like to build one of these jigs that wil work for all applications.
mayday911 is offline Find More Posts by mayday911
Old Aug 12, 2002, 08:08 PM
Hippo is offline
Find More Posts by Hippo
The effect is sadly temporary
Hippo's Avatar
Ann Arbor, Michigan
Joined Oct 2001
Latest wing jig design...
Hey,
I've had really good luck working with my original jig design. Here's some pics of it.
With the help of Vyceroy, and some listening skills, I've come up with the latest design. I don't have pictures of it yet, but I think it's going to be really big. The new Jig has FULLY INTERCHANGEABLE AIRFOILS. It still comes with the standard Frog, and Mini-Wing airfoil installed, but I'll be selling "airfoil packs" on the site: www.FoamFly.com once I find out which airfoils people actually want...
Enjoy, ask questions if you got 'em.
-Dan
Hippo is offline Find More Posts by Hippo
BluSloWing a nice and slow Fan Fold Wing Gene Bond Foamies (Scratchbuilt) 36 Jan 19, 2009 09:08 PM
Building up a Fan Fold Wing. JasonJ Foamies (Kits) 49 May 18, 2008 02:52 PM
Fan Fold wing for Slow stick.. anyone ever made one? moter Parkflyers 2 Jul 14, 2004 12:26 PM
Vacuum forming Fan-Fold zbrubaker Foamies (Kits) 4 Apr 29, 2002 11:23 PM
fan-fold wing construction thelocust Foamies (Kits) 9 Mar 28, 2002 09:31 AM
