Old Apr 25, 2005, 12:35 PM
T-Fly is offline
Find More Posts by T-Fly
T-Fly's Avatar
Jacksonville FL
Joined Feb 2005
So-long T-Hawk....(for now)
Well it was a nice day, charged up two packs and headed out to my pasture. There was a nice wind so I figured I'd get up high, real high and play around. I was around 600 ft up when I figured I'd do some loops. I started to do my loop and then it started to fall. I knew I was still in range so that wasn't the issue. As the plane fell some I noticed that the wing had folded. The wind helped carry my plane to the top of a 75 foot Pine tree in a neighbors yard. Now I have to figure out how to knock it down and get permission from the neighbor. The bad thing is that I THOUGHT the wing was still rather sturdy. I guess I'll have to use carbon rods if I ever get that plane back.
T-Fly is offline Find More Posts by T-Fly
Old Apr 25, 2005, 02:33 PM
Travy is offline
Find More Posts by Travy
Bellevue, WA
Joined Feb 2005
I believe the folded wing thing that people see (I've been at a field when it happened to someone with an ABC, but I didn't see it) is because of gusts of wind when they attempt a manuver. The added stress on the wing is too much. I've never had this happen to my ABC or any of my planes so I don't have first hand experience (Knock on wood) but that would be my guess.
Travy is offline Find More Posts by Travy
Old Apr 25, 2005, 03:05 PM
mdchris is offline
Find More Posts by mdchris
Joined Mar 2005
I've been getting really comfortable with my thawk now, and i do a lot of loops, hammer heads turns, and snap rolls. Usually in a wind to get more speed.
Anyway i've only had my hawk out maybe 6 or 7 times, and I can see a crease developing in the wing right at the end of the brace that comes on the wing, and another smaller crease about 4 inches farther out. So I think mine is probably grounded too until I get that wing supported.
Hope your's is still fixable and your neighbour is good about helping you get it down!
chris
mdchris is offline Find More Posts by mdchris
Old Apr 25, 2005, 04:06 PM
T-Fly is offline
T-Fly's Avatar
Jacksonville FL
Joined Feb 2005
Still no T-Hawk. I used some duct tape and two 30 foot lenghts of PVC only to come 10 feet away from my plane. Let me say that trying to hoist up 60 feet of 1 and a quarter inch PVC isn't easy. After that I tried trowing various objects but there's just enough branches to get in the way. So it looks like I'll be waiting until Huricane season to get my plane down now. The real tragedy is that I have a good battery in there that I was planning on using for the Stryker I'm going to buy. Guess I'll be back on FMS for a while.
Old Apr 25, 2005, 04:27 PM
Red 61 is offline
Find More Posts by Red 61
Outcast outlaw
As far away from RCGroups and the AMA as possible!
Joined Aug 2004
Well, two things:
1) At least the tree broke your Aerobird's fall!
2) Pine trees are REALLY easy to climb, if you don't mind the sap...
Red 61 is offline Find More Posts by Red 61
Old Apr 25, 2005, 04:38 PM
T-Fly is offline
T-Fly's Avatar
Jacksonville FL
Joined Feb 2005
Originally Posted by Red 61
Well, two things:
It's definately broke now but I sure won't be climbing up there. Maybe 15 years ago I'd have gone up there.
Old Apr 25, 2005, 04:56 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Maybe a helpful idea here:
Getting Planes out of Trees
I don't know if trees and planes are attracted to each other like magnets, but
somehow we seem to be pulling someone out of a tree every few weeks.
Fortunately it is not me these days, though I am sure I will find one again.
I can see them reaching for the plane as I fly by. The guys tell me it is the
wind, but I think they are calling my plane.
So, how do you get your plane out of a tree? Here are some methods I use, or
have seen used. Some are simple and cheap. Some are complex and some are
expensive. You have to decide which to use and when.
In my book, chain saws, axes and things that will kill the tree are not an
option. Call me a tree hugger, but I just can't see cutting down a tree to
get a plane. There is usually a better option.
I am going to list the ones I know, roughly in effective range. I hope you
can provide some others, preferably before I need them.
8-12 Feet (2-4 meters) -
Good old hand reach combined with anything to stand on and maybe a local stick
or branch - Cost $0
10-30 Feet (3-10 meters) -
When I fly I bring a 6 foot extension pole for a paint roller that I purchased
in Home Depot for $14. It extends to 12 feet. I have seen 4, 8 and 10
footers that double as well. I also saw an 8 footer that almost triples to
about 22 feet. If you use some tape you can tape 2-3 of these together to
reach higher.
15-50 Feet (5-16 meters) - ( I have too much experience at this height)
I carry a spool of 130 pound test mason's line in my field box that has an 8
ounce rounded fishing weight attached to it. Costs about $5 total. With a
good throw I can usually get it up and over the branch holding the plane so I
can shake it free. Hitting the branch can take lots of throws and hitting the
plane is a real risk, but it is better than leaving it there. If your plane
is sitting on a very strong branch, use the lighter line to pull up a heavier
line.
Monofiliment fishing line works very well too at it will slide down over the
branch more easily than the mason's line. I use 3-4 foot piece of rope with
weight on the end which I attach to the fishing line with a snap. The rope is
easier to grab to make the toss and it is easy to remove. Works very well.
Plumbing parts, big bolts, anything can be used to weight the rope so it will
go up to where the plane lies. 50 feet is about the max I have ever been able
to reach this way and it is hard to get the line up that high.
A spinning rod with a weight migh also work if you are talented with such
things, but 60 feet would be my guestimate on the limit on this.
Another way is to use aluminum downspouts, typically used for house gutter
system. Home Depot, Lowes and other home centers have them. They can be
taped together. Use something to bridge the joint to help keep them erect.
They are very light and fairly rigid. You can probably get up to 5 sections
reaching about 50 feet. Not sure if you can go much beyond that. Friends
have had good success with this.
30-100 feet (9-32 meters) -
A bow and arrow might work well at this height, but you'll have to develop
some skill
in order to get the needed accuracy. I estimate this at $50-$100 - One
problem is that you can get the arrow stuck on a different branch which only
compounds your problem. The line will have to be light, such as 5-10 lbs test
monofiliment fishing line, so use it to pull up
heavier line or so you can break it if the arrow gets stuck.
Other methods I have heard about but never used or witnessed.
Tree climber - Somehow every RC club has the phone number of a guy who climbs
trees for a fee.
Helo - I heard of one guy who used an electric helo to fly a line and weight
up and had some kind of release to drop it onto the branch. Sounds like a
good justification for a helo when I speak with my wife.
A really original idea
Control line kite - This one surprised me, but one of our members got his
plane stuck in the top of a high tree, over 100 feet up. He also flies the
large kites that look like arc shaped parachutes. He has two control lines on
the kite that let him direct it, dive it and move it around the sky. He used
it to attack the tree until the tree gave up the plane. I like the idea of
attacking the tree without actually hurting it!
A Wanger - A device specifically for getting planes out of trees
http://www.slopeflyer.com/artman/pub...rticle_6.shtml
aeajr is offline Find More Posts by aeajr
Old Apr 25, 2005, 04:59 PM
aeajr is offline
LI, New York, USA
Joined Mar 2003
chris
With the Aerobirds, the fold usually happens in the center because that is where the rubberbands hold the wing.
On the T-Hawk and Aerobird Xtreme, the folds happen at the end of the reinforcing rod.
Here is the method I developed for the Aerobird but it should work fine on the T-Hawk wing if it is developing a crease. Sooner or later that crease will fold.
FIXING WINGS AND TAILS
Repairing a CREASED wing with packing tape alone doesn't really work very
well. It works better on the tail because it encounters different forces, but
what I am about to explain works MUCH better on both the wing and tail and is
easy to do. It should also apply to the Xtreme, and all the Firebirds.
A creased taped wing might fly, but at the first real stress, its gonna fold
and you are going to crash. Tape alone has no body or stiffness of its own to
resist a fold since the wing's internal foam is compressed. Net Net, there is
nothing to resist the next fold. You need to stiffen and support the wing.
Here are things I have used for wings and the V tail with pretty good results.
Take a hobby knife or razor blade and open the vinyl covering at the crease or
stressed area
Get the wing set in the proper position, even bend it slightly the other way
to open up the gap.
Fill the folded area with Elmer's white glue or titebond yellow glue. I have
not tried Gorilla Glue, but that might work well. The white and yellow glue
will seep into the foam and bond with it and stiffen it.
Let it partially dry, at least 90 minutes, then fill it again. The first coat
will soak in. The second coat will fill the gap. Let it dry
at least 24 hours, then check it. If it is fully dried, apply a little clear
packing tape to help it resist pulling open.
Another approach I used for large folds, especially center folds is to bond a
thin but somewhat stiff strip piece of wood, like 1/32 ply, to the top of the
wing. You can use some contact cement or double sided carpet tape works well.
Then take a piece about 1-2 inches wide inch wide and at least 2 inch to
either side of the crack should work well. It is stiff enough to resist the
next fold, but will still flex with the wing. Then cover it with clear
packing tape stretched so that it forms a smooth finish with no sharp edges so
the air can flow nicely over the wing. You might not notice it at all. If
the repair is well out toward the edge of the wing, you may need to do the
same on the other side just to keep it balanced.
I have never had one of these fold. The bird can handle the weight of a light
piece of plastic or wood.
Embedded supports
If you want to get more aggressive, you can cut the covering on a new wing or
a damaged wing, remove or compress some foam and embed the plywood or a dowel
support piece into the wing and glue it into the foam with Elmer's white glue
or Titebond yellow glue. The wing does have to flex a bit. Then tape over
the top to cover it. I have not used this approach but I may try it if I
badly bend a wing.
While Epoxy is strong, it doesn't move with the foam the way Elmer's or
Titebond do so I have seen a tendency for epoxy to pull away from the foam
which weakens the area.
If you look at the Firebird XL wing, or the Aerobird Xtreme, they have a
support rod embedded into it when you buy it. Other similar planes, like the
T-hawk, have these supports in their wings when they are new. If you do this,
I suggest doing this so that is spans the body of the plane as many folds
happen where the rubber bands attach. Too often you make a hard off angle
landing on one side of the wing but see no damage to the wing. You think you
have a clean wing, but in fact the foam inside has been weakened. You fly and
the wing folds and you say "what happened?" What happened is 5 hard landings
ago you stressed this spot, compressed the foam enough to weaken it and boom
you have a fold.
Give it a try. The key message here is don't depend on tape to keep the
crease from folding again. Tape is good for closing up damage on the front or
rear edges of the wing and for reinforcement of a new wing by the prop area,
but it can't keep a creased wing from folding up again.
Old Apr 25, 2005, 05:09 PM
Hobie is offline
Find More Posts by Hobie
Hobie's Avatar
Central,Illinois
Joined Nov 2004
Damn T-Fly sorry to hear too bad you don't have my neighbor living next to you he is a pro at tree climbing and removal. Did you say 600 feet ? I don't even know if I could see mine that far away. You are pushing the t-hawk to the max to see how for it can go. I am still carefull and glad to just fly when I can. I am sick of the strong winds here I just want to get in some flying time so I feel more confident. It sucks taking up a new hobby and not being able to fly. If you had the winds we do your hawk would blow down on it's own.
Hobie is offline Find More Posts by Hobie
Old Apr 25, 2005, 05:12 PM
mdchris is offline
Joined Mar 2005
thanks aeajr, i have actually been planning on going with your last method of embedding a rod in the underside of the wing. The plan is for a carbon fiber rod, just have to get ahold of one.
I've heard that a carbon fiber strip can work also but haven't heard from anybody who has actually tried it.
Old Apr 25, 2005, 05:18 PM
T-Fly is offline
T-Fly's Avatar
Jacksonville FL
Joined Feb 2005
Hobie, I say 600ft by knowing how small my plane looks at the end of my pasture which is 550ft. Lets just say that the height I was, when overhead, the plane looked considerably smaller so it may have been a tad higher. I wanted to be SEVERAL mistakes high to go crazy but there is no recovery from a wing that folds the way mine did.
Old Apr 25, 2005, 08:49 PM
rumme is offline
Find More Posts by rumme
Joined Apr 2004
t-fly..if you have acces to a crossbow..they are effective..kust wrap the sharp end of the arrow with a tennisball..in a sock..and stick the arrow point into the ball..
rumme is offline Find More Posts by rumme
Old Apr 25, 2005, 10:12 PM
Matt Dziubinski is offline
Find More Posts by Matt Dziubinski
Twist n' Shout!
Matt Dziubinski's Avatar
Joined Nov 2004
How can you say its broken if you havent seent the thing yet?. use 6 sticks of conduit and some couplings and you'll get her down,; one sitck= 10 ft, its fairly easy to get up ther, worst is your kneck starts hurting from looking up so much..you beat me though, my bird got stuck up at 50 ft. when i started learning.
Matt Dziubinski is offline Find More Posts by Matt Dziubinski
Old Apr 25, 2005, 11:42 PM
philipnow is offline
Find More Posts by philipnow
S. Calif.
Joined Mar 2005
Too bad about your T-Hawk, T-Fly! Sounds like it's going to be tough to retrieve. Do have anyone who can climb the tree for you?
philipnow is offline Find More Posts by philipnow
Old Apr 26, 2005, 01:12 AM
Skyfish is offline
Find More Posts by Skyfish
Just One More
Skyfish's Avatar
United States, TN, Knoxville
Joined Feb 2004
Best of luck. Let me know what you need. I have a partial T-hawk if you need parts. The conduit/pvc thing works. It's the lightest, safest, least destructive solution I know of. Unless you have a monkey.
Skyfish is offline Find More Posts by Skyfish
t-hawk for sale with extras jim mathis Aircraft - Electric - Airplanes (FS/W) 7 Jan 02, 2004 08:42 PM
modified t hawk for sale greatplanes Aircraft - Electric - Airplanes (FS/W) 1 Apr 12, 2003 11:37 AM
3 ch t- hawk for sale greatplanes Aircraft - Electric - Airplanes (FS/W) 0 Mar 09, 2003 08:55 AM
T-hawk = toast, now what? jms336 Parkflyers 10 Mar 03, 2003 08:39 PM
T-Hawk for perspective newbie? Brewerpaul Beginner Training Area (Aircraft-Electric) 9 Sep 25, 2002 10:30 PM
