Old Apr 24, 2005, 10:36 PM
Larren is offline
Find More Posts by Larren
Flying Is Fun
Larren's Avatar
Malaysia
Joined Sep 2004
Need help and advise on the Castle Creation's Phoenix -25 Governor Mode
Hi,
I am very tempted to get the above mentioned ESC for my Zap.
I have downloaded the manual and have 1 question regarding its setup under topic 9.4, Programming Setting 4 - Throttle Type.
If I choose the either the option 3 or option 4 which is the governor setting low or high, does it mean that whenever I power up my zap, it is already in governor mode when I move the throttle slightly or do I need to set the pitch curve to flat on my radio?
Currently my Stunt Mode ( Idle up mode ) in my JR 2610 TX is set up with throttle curve flat at about 70% to achive constant rpm through out as Align ESC does not have governor mode. I don't do 3d yet
Thank you in advance.
Larr
Larren is offline Find More Posts by Larren
Old Apr 24, 2005, 10:42 PM
Silverstreak328 is offline
Find More Posts by Silverstreak328
Really Cool User
Silverstreak328's Avatar
Tampa St Pete, Florida, United States
Joined Dec 2003
I beleieve the Hi and Low throttle type settings depict wether you are using a high or low RPM motor.
Silverstreak328 is offline Find More Posts by Silverstreak328
Old Apr 24, 2005, 11:50 PM
yodasands is offline
Find More Posts by yodasands
Phoenix Intl, Arizona, United States
Joined Feb 2003
Get the PHX 35. The BEC on the 25 is not rated for 4 servos and a gyro.
yodasands is offline Find More Posts by yodasands
Old Apr 25, 2005, 12:34 AM
Larren is offline
Flying Is Fun
Larren's Avatar
Malaysia
Joined Sep 2004
Thanks guys for your replys and advises.
Larr
Old Apr 25, 2005, 08:37 AM
skeppley is offline
Find More Posts by skeppley
2 Turbos...Nope 1 Big one
skeppley's Avatar
United States, PA, Lake Wynonah
Joined Aug 2004
Larr,
The 25 will work, but for a few bucks more, go to the 35 if you can.
Running Gov mode, you do want to make your throttle curves flat, or it wont work.
Examples
Normal Mode 0-90-90-90-90
Idle 1 90-90-90-90-90
Idle 2 95-95-95-95-95
You can use normal mode for flying around, and the zero at bottom stick will allow you to land, and cut the motor easily.
In idle 1, the motor will run constantly, no matter where the stick is.
Idle 2 will give you max rpms for 3D
In gov mode, the numbers do not represent the throttle amount on the speed control.
For example, in my setup, max throttle is 67 across the line. And normal mode is:
0-56-56-56-56, giving me 2250 RPMS
Idle 1 is: 58-58-58-58-58, giving 2350 RPMS
Idle 2 :60-60-60-60-60, giving 2450 RPMS
You make the numbers on the Tx equal to the headspeed you want on the heli.
skeppley is offline Find More Posts by skeppley
Old Apr 25, 2005, 11:52 AM
Larren is offline
Flying Is Fun
Larren's Avatar
Malaysia
Joined Sep 2004
Thanks skeppley.
Is it true that the CC25 governor mode does not work on all brushless motors and only works on certain brushless motors?
Thanks again.
Old Apr 25, 2005, 12:47 PM
skeppley is offline
skeppley's Avatar
Joined Aug 2004
What motor are you running?
CC has updated there firmware to version 1.12. It is said to work with MANY motors.
I still like 1.10 better so far. Still need to do some testing on high gov mode and advances in 1.12 before i can say for sure which version is better.
Old Apr 25, 2005, 02:29 PM
smittylube is offline
Find More Posts by smittylube
E-Flight Addict
Silicon Valley, CA
Joined Apr 2002
I found 'fixed mode' to fly better all around.. only takes more time to set-up.
JMO.
smittylube is offline Find More Posts by smittylube
Old Apr 25, 2005, 10:11 PM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Get the CC35 and order the Phoenix Link as well. Makes setting up the ESC very easy. I am running the latest Firmware on my TRex and Governor Mode works just fine. The Soft Start is also better. The new Firmware works with in and out runners.
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Discussion Cheap prices on Castle Creation Phoenix ESC jonnyjetprop Hot Online Deals 0 Jan 20, 2007 06:28 PM
Discussion Need some help please!! On Futaba receiver's DanT Mini Helis 2 May 19, 2006 05:29 PM
Discussion Need help and advice on Electronic's niterdr Dock Talk 8 Jan 07, 2006 04:10 AM
Need help deciding on an aileron thermal e-sailplane PDX Slope Pilot Electric Sailplanes 3 Jul 09, 2002 03:05 AM
Need help quick! 450 turbo wiring ?'s slowflyer Foamies (Kits) 7 Jun 09, 2001 07:53 AM
