Orange Beach, Alabama
Joined Feb 2005
hehe, what you see as a 'landing' is not a landing. like i said, the CG was off and i was basically at full up elevators during the flight. the motors were also at full speed the whole time. the crash came as i was turning, and the wind coming from behind the plane. whether it was a gust or just a stall from slow speed, the plane began losing altitude quickly. as i was cutting power to try to gently put it on the ground, the plane regained its lift, and i gave it full throttle again. the pictures are in sequence, so you can see how it was low, then began to climb again. i was hoping to get to bring it around for a safe landing, but once again, it stalled. this time i was not able to recover and it went into the ground. this was actually some distance from where i was standing, the picture has been magnified.
land between bridges
Joined Feb 2003
Hey there ABG,
It was a nice attempt. At least it got airborne and now youre armed with way more knowledge for your second build. I just got one of those Hasegawa model kits of a 777 at my LHS and put it together.. I totally recommend buying one of these models.. I think Revell has a 764. Just having the model to look at inspires confidence in building it.. G'luck with the 764. -adrian |
Joined Feb 2003
Its in the works.. I have alot of other priorities to deal with, so I'll make a build thread after Im done....whenever that will be. But basically its a 777 with hw-750's. I was thinking a step up using GE90's, but Im a little short on cash.
You could buy another model, glue the fuse together, and cut up the nose section into calamari rings, then scan or trace them, and then blow em up in a xerox machine. Or maybe another way is to take a 3 view, cut a side and top profile, glue them together, and improvise with the formers.
| Thread Tools | |
| Discussion SuperStar EP Maiden Flight - First time Pilot (Part III) | mrm1 | Beginner Training Area (Aircraft-Electric) | 2322 | Jun 27, 2011 08:11 AM |
| SuperStar EP Maiden Flight - First time Pilot (Part II) | mrm1 | Beginner Training Area (Aircraft-Electric) | 494 | Apr 02, 2006 08:03 AM |
| Yippee! SuperStar EP Maiden Flight - First time Pilot | mrm1 | Beginner Training Area (Aircraft-Electric) | 532 | Mar 09, 2005 09:16 PM |
| Tiger Moth 400 Build and Maiden Flight review | AirWarriorBelgy | Parkflyers | 180 | Aug 16, 2004 02:23 PM |
| DAh dahhhh....my first Plane/TM had its maiden FLIGHT! | rcwyant | Parkflyers | 17 | Jul 28, 2003 08:55 PM |
