Old Apr 23, 2005, 03:29 PM
What's my age again ?!
derogg's Avatar
United States, CA, Aliso Viejo
Joined Jan 2004
Foamy Factory Foamboard Ultimate Bipe
Built one of Tim's Ultimate Bipes 24" version. Used Foam board from a craft store ( 3mm )
  • Customcdr special edition motor 8-4HD prop
  • CC PH-10, GWS Pico 4 RX
  • Maxamps 3s 900mAh pack
  • HS-55 servos
Flys good, but I need to increase the control throws more for 3D. I also need to reinforce the fuse in places because the foam cracks easily. AUW is about 7.75 oz on a cheap food scale Next I am thinking of a mini 3DX with a littlescreamers motor to pull it around. - Dirk
derogg is offline Find More Posts by derogg
Old Apr 25, 2005, 08:58 AM
msm
Joined May 2004
Nice bipe! but did you took of the paper from the foam board?
msm is offline Find More Posts by msm
Old Apr 25, 2005, 12:00 PM
derogg's Avatar
Joined Jan 2004
Yes I did.- Dirk
Old Apr 25, 2005, 12:50 PM
msm
Joined May 2004
i have to do the same because i cant find depron in here, but foamboard works great! Did you increase the throws yet? how does it fly now.
Old Apr 25, 2005, 05:31 PM
derogg's Avatar
Joined Jan 2004
Needs more ruder throw. My CG is too far back (nose heavy), thrust line needs alot more down thrust. It is fun to fly, but takes a while to get things set up correctly. I will need to cut more space off the elevator, to get rudder throw. Oh, a bit of tail twist also. I don't know if it will ever be a true 3D performer, but it is fun anyway - Dirk
foamy 3dx verse ultimate bipe cjc1084 3D Flying 1 Oct 08, 2004 09:48 AM
Yippee! Foamy Factory 40" Ultimate Bipe - Thanks Tim defygravity01 3D Flying 35 Aug 03, 2004 05:05 PM
Foamy factory 40'' Ultimate/motor selection Jackspt28 3D Flying 0 Jan 30, 2004 04:01 PM
Foamy Factory 23" Ultimate Help?? Jason 3-danhakl 3D Flying 3 Jan 16, 2004 11:53 AM
Q's re. AXI 2808/20 and Lipo's/foamy bipe aerobatic design like the Ultimate bipe. bipeflyer Batteries and Chargers 0 Sep 12, 2003 04:36 PM
