Go Back   RC Groups > Aircraft - Electric - General > Power Systems
Old Apr 05, 2002, 10:47 AM   #1
Angle of incidence question
Where do you measure the angle of incidence on a flat bottom wing?? I have Great Planes laser incidence meter and it appears to me that it measures the chord from a point higher up on the leading edge than what the chord across the bottom of the wing would be. This is because the 90 degree angle bracket of the meter sets around the curved leading edge, raising the line being measured up 1/4 to 3/8 inch above the flat bottom projected line.
Hope I've made myself clear. Thanks for help
dshly is offline Find More Posts by dshly   Reply With Quote
Old Apr 05, 2002, 11:16 AM   #2
Ascended Master
Sparky Paul's Avatar
Your wing isn't a true flat bottom. Most aren't.
It is generally done by presuming the flattish portion aft of the spar is the index for the angle the wing sits on the fuselage, for those planes where the true orientation isn't specified..
Like this:
  • Name: indicence.jpg
Sparky Paul is offline Find More Posts by Sparky Paul   Reply With Quote
Old Apr 05, 2002, 01:17 PM   #3
Ascended Master
Flat bottom...
Incidence...
  • Name: flatbottoms.jpg
Old Apr 05, 2002, 02:31 PM   #4
I "plant" trees (balsa)
Gary Retterbush's Avatar
Like Sparky said.
Just let the GP Laser do it's thing. It will be correct.
Gary Retterbush is offline Find More Posts by Gary Retterbush   Reply With Quote
Old Apr 06, 2002, 01:16 AM   #5
Sparky Paul,
Dude, you are a wealth of information with a ton of resources! I am always impressed with your replies; clean, concise, easy to understand, and usually with visual aids. You are a king.
--Rick
rsieminski is offline Find More Posts by rsieminski   Reply With Quote
Old Apr 06, 2002, 12:25 PM   #6
Thanks for help. Used the laser meter and it looks right. Apparently the chord is the important thing, regardless of the flatness of the wing.
Old Apr 06, 2002, 08:14 PM   #7
Ascended Master
Rick the praise is appreciated! <blush>
Discussion Angle of incidence question? - Long EZ Build Ralph_D Parkflyers 7 Jan 01, 2006 08:40 PM
Zero and Sukhoi Angle of Incidence cfossa Parkflyers 1 Apr 22, 2002 04:11 PM
Angle of Incidence HELP!! Bernie Wolfard Electric Sailplanes 13 Nov 19, 2001 02:04 PM
F-18 angle of incidence? gbruce Electric Ducted Fan Jet Talk 6 Nov 06, 2001 01:42 PM
k-a mig 15 incidence question Herb Electric Ducted Fan Jet Talk 2 Sep 10, 2001 01:22 AM
Congratulations SimpleM!
