| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#31 |
You fly that thing?
I'm also planning on Burgess Saturday. The weather is looking a little iffy but I will be there.
Option one there will be behind the Jr High next to the park as before. Option two will be the park itself. Option three is the elementary around the corner from the Jr High. See you there! Darren |
#32 |
Chad-o-rama
I'll be flying early tomorrow, around 8AM. That should be early enough that I can still fly at PG, which is closer for me.
Question for the battery gurus... Had a wreck the other day that bent the top of my battery (HP1200). I pulled the covering off and it looks ok - I think it was just the "tabs" at the top that bent over a little. I straightened them out and it looks like it did before. Do I need to do any special charging to make sure there was no real damage? How do I tell if it's "OK"? And... what should I cover it back up with since I pulled the nice wrapping off to get a closer look? |
#33 |
You fly that thing?
Bending over the top usually isn't a problem. Unless you can smell the strong "sweet" odor of the eletrolyte, I'm sure they are fine. An electrolyte leak will mean one of the cells in the pack is likely going to die pretty soon.
The two things to worry about damage near the top are shorting and ripping tabs. It sounds like you did neither, but watch for it. Darren |
#34 |
Chad-o-rama
It seems to have charged up ok. The voltmeter shows 8.04V (and that's what it's always shown when they're charged). Should I wrap the cells in electrical tape? or Monocote? A size 4 diaper?
#35 |
You fly that thing?
I use electrical tape. Just make sure not to squeeze the tabs together when wrapping.
#36 |
Utah Flyers
Did anyone see a voltmeter left at PG? I cant seem to find mine. I think I last had it last Saturday?
#37 |
PERFECT LANDING !!!
Nate,
My boys and I cleaned up after everyone left. We did not see a voltmeter. Lee |
#38 |
Corn-holio
I should be there tomorrow too. I have a new wing but I didnt have time to cover it so it has very ugly tape on it....10:30 burgess.
#39 | |
Divot Maker
Falcon?
#40 | |
Divot Maker
Scared Bovine?
#41 |
PERFECT LANDING !!!
The Burgess field in Alpine had 10 people per square foot. Little league has started with a vengence and they have used every square foot of grass. There wasn't even any parking. The whole city of Alpine must have coordinated to get that many teams on that little land.
After seeing the crowd at Burgess Jared, Darren, John and I went over to PGJH which was not in use today. We were the only ones there. Flying was good. Jared and I had a good solid hit. A quick note on Props. The EP5043 is the prop for the 2 cell on a Razor 400. Jared's plane's performance was greatly improved with a simple prop change. He had unlimited vertical with a three cell and outstanding performance with the two cell. Another note on props. Cut 1/4" off each end of the EP4040 (making it a 3540) and the amps drop and you might squeeze a few more flights out of you J250s. As the summer temperature goes up I predict that the J250s will overheat even more. Lee
#42 |
Corn-holio
Boy I'll say. I was using a 5.75x5.75 and a 3cell 1650 pack. The batteries always came down just on the verge of being too hot. I tried a 2 cell Kokam 1500 with the same prop and I could barely keep it in the air. then Lee gave me a 5043 prop and it was night and day in terms of performance! On the 2 cell Kokam it flew great and with the 1650 3 cell I have unlimited vertical. AND when the plane came down the batteries were barely warm!!!
I dont claim to understand it but man what a difference! This is the prop to use! EP5043! |
#43 |
Chad-o-rama
Prop choices like this are something to document. I'll have to write it down, 'cause I'll never find this thread when I finally go brushless.
I was at PGJH at 8:00 this morning - not a soul in sight (well... Darren drifted by). It was raining lightly, and I got to practice my low-deck flight. I was going to get a haircut on Monday, but don't need one anymore. What a rush to have the wing coming right at you "below ground level", then bring it up at the last minute. Haven't had that much fun since the wind was blowing 30MPH.
#44 | |
Flying Free
Now I have a reason to finish my Wild Wings.
#45 |
PERFECT LANDING !!!
I measure about 10.5 amps with the Razor 400 and a 2 cell 7.4 volt with the EP5043. Both my 28" and 35" perform very well with this combination. The performance is so good that I don't feel any need to go to the 3 cell.
Keeping the motor running on the 2 cell may extend the life of the motor. I have already broken 2 shafts with the Himax 2025 4100 with a stiff prop and don't want to do that to my Razor. Thses two reasons motivated me to try it in the first place. The EP5043 is a soft flexible prop so it's actual thrust may be misleading when compared to a stiff prop. It was just by trial and error not by any magical formula that we came up with this set up. I will probably be flying Thursday and Saturday this week. Lee
| Thread Tools | |
| Discussion Utah County Flying Sites | redgiki | Utah Flyers Organization | 6 | Mar 23, 2007 03:23 PM |
| San Diego County Flying | johnsloper | Slope | 5 | Oct 18, 2004 08:32 PM |
| Yippee! north county flying machines (positive) | smittydiditusa | Vendor Talk | 2 | Oct 29, 2003 11:58 AM |
| Article North County Flying Machines 60" M60 - EPP | Keitha | Liftzone Archive | 0 | Aug 30, 2003 01:00 AM |
| WTB: "The Moth" by "North County Flying Machines" | ajeepham | Aircraft - Electric - Airplanes (FS/W) | 0 | Jan 05, 2003 12:54 PM |
