Old Apr 22, 2005, 10:39 AM
jswjimmy is offline
Find More Posts by jswjimmy
Whatever happens..Happens
jswjimmy's Avatar
Sanford, Maine, United States
Joined Aug 2004
need help with a gws v-tail mixer
ok i just got my gws v-tail mixer for my zagi. ive hooked it up and it works, but if i go down fast the right servo will go up, down, then up again. if i go in any direction then to the right both servos go crazy.
its not the radio, ive been using it im my slow stick for months. its not the servos, they were in the plane when i got it and i saw it fly that day. and im doing with the motors off so its not noise from the motors. so it has to the the v-tail mixer.
any idea what it is or how to fix it?
edit: changed directions. i had them wrong
jswjimmy is offline Find More Posts by jswjimmy
Old Apr 22, 2005, 11:19 AM
jswjimmy is offline
jswjimmy's Avatar
Joined Aug 2004
ok check out this video, this is what it does.
http://www.rcgroups.com/gallery/show...cat=500&page=1
Old Apr 22, 2005, 12:49 PM
Ron H is online now
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Try twisting the leads from the Rx to servo.
Ron H is online now Find More Posts by Ron H
Old Apr 22, 2005, 12:58 PM
jswjimmy is offline
jswjimmy's Avatar
Joined Aug 2004
rx to vtail or vtail to servos.
and um, what do you mean by twist?
Old Apr 22, 2005, 12:59 PM
fhhuber506771 is offline
Find More Posts by fhhuber506771
Deletedfor proving Nauga wrong
Joined Mar 2005
its an electonics system glitch for sure...
How old are the servos? That is a potential sign of servo pot wear-out.
Could be a "flaky" plug somewhere too... or a wire that is about to break in a servo lead
Could even be a bad mixer...
The short wire runs... I personally doubt its induced feedback (which is what the twisted wire is normally used to cure/reduce.)
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Apr 22, 2005, 01:11 PM
jswjimmy is offline
jswjimmy's Avatar
Joined Aug 2004
the servo thats twitching more is the newer one. they are hs81mg, but both twitch, it just the right one does it more. there both under a year old.
the mixer is a futaba plug the rx is a jr, i know there the same other than the plug but could that have anything to do with it.
Old Apr 22, 2005, 01:15 PM
Ron H is online now
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
fhhuber506771 ( is there a quick way to type that )? is likely right, but I like to troubleshoot the cheap stuff first. Even when I KNOW I'm wrong. What I mean to say is don't eliminate anything until you have tested it. I can only say what worked for me.
Old Apr 22, 2005, 02:13 PM
jswjimmy is offline
jswjimmy's Avatar
Joined Aug 2004
never mind.
Old Apr 22, 2005, 02:57 PM
jswjimmy is offline
jswjimmy's Avatar
Joined Aug 2004
i was wrong i tested every thing, it has to be the mixer. ive tested that servo on the rx it self and its fine. ill have to email gws. i think the mixer is no good, the wires for the AILE and ELEV are mixed up so the AILE is hooked up to the ELEV on the rx, so im guessing there is something wrong with it.
Old Apr 25, 2005, 06:52 PM
jswjimmy is offline
jswjimmy's Avatar
Joined Aug 2004
i emailed Richard on friday still no reply. eather he had the weekend off, or he is just behind.
i wanted to bump this to see if any one else had any ideas. ive tryed every thing i can think of, every thing leads to a bad mixer.
Need Help with a GWS P-51 spessx Parkflyers 6 Jan 19, 2004 09:49 PM
Need Help with GWS P51 spessx GWS (Grand Wing Servo) 0 Jan 19, 2004 11:17 AM
help with inverted v-tail trim corosplat Modeling Science 7 Jun 25, 2003 07:06 AM
Need Help with GWS ICS-300 Speed Controller. mrebman Parkflyers 13 Jun 07, 2003 08:04 PM
