Old Apr 22, 2005, 10:25 AM
eightwgt is offline
Find More Posts by eightwgt
eightwgt's Avatar
Florida
Joined Jan 2002
Apogee build thread
Guys,
I have been posting all over about the Apogee and now that i have my parts made Im going to consolidate the rest of my efforts / questions posts here I hope !
Thanks Dr. D for answering so many of my questions.....
I am making a jig tonight to hold the boom and fuse at the proper angle so I can glue them
I am making a jig to glue the wings together.... BUT I have to figure out how I want to attach them and make a strong joint...
I will be machining my tail wings for the 2nd time tonight - the first ones I didnt like....
I am still debating on the reciever, and antenna issue - I have a 555, and a GWS.... I was only worried about saving some weight so I can see the planes true ability.....but worried about the GWS reciever....
Most work will be fuse work tonight....Im trying to figure out how I want to cram ll that stuff in there...
eightwgt is offline Find More Posts by eightwgt
Old Apr 22, 2005, 10:45 AM
rdwoebke is offline
Find More Posts by rdwoebke
Panda Panda Panda Panda Panda
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
Hello,
I have a GWS 4 channel receiver in my Pocket Combat Wing. It has worked great for me. I have heard it does not handle rejection too well, so if you fly with a lot of other pilots you might not want to consider it. But for the price, I found it great.
Ryan
rdwoebke is offline Find More Posts by rdwoebke
Old Apr 22, 2005, 11:12 AM
stjobs is offline
Find More Posts by stjobs
Gainesville, Florida, United States
Joined Sep 2001
The GWS Rx should be fine... I haven't had any glitches with the 2 that I own. Plus, the 555 may have a hard tiem fitting in the fuse.
Gluing the wings together - just use 5 minute epoxy and add a patch of FG over the joint, top and bottom. It should be quite strong. On my DLGs I've also used a light ply "arm" that's cut to the dihedral and extends about an inch in either direction. A vertical slot is cut in each half, and this arm gives some glue surface to bond on to each wing.
stjobs is offline Find More Posts by stjobs
Old Apr 22, 2005, 11:35 AM
eightwgt is offline
eightwgt's Avatar
Florida
Joined Jan 2002
Dr D ? Are you listening ? What did you do with your antenna on your Apogee ??
Some say solder it on the wire push rod but what about the rest of it ??
Old Apr 22, 2005, 12:50 PM
markdrela is offline
Find More Posts by markdrela
Cambridge, MA USA
Joined May 2001
I used one of the pushrods as the antenna. It's shorter than the ideal length, but you don't need all that much radio range with a plane this small.
markdrela is offline Find More Posts by markdrela
Old Apr 22, 2005, 01:01 PM
eightwgt is offline
eightwgt's Avatar
Florida
Joined Jan 2002
So you cut off the extra lenth I assume ?
Thanks Mark...
Old Apr 22, 2005, 02:45 PM
eightwgt is offline
eightwgt's Avatar
Florida
Joined Jan 2002
Well here we go........
Here are the 2 wings - my 'test wings' since this glider is my 'experimental'
You can see my boom - a kite boom from AVIA - The SkinnyUL
and my first painted fuse... I painted the mold with Krylon and did a normal layup... it added a gram though....
I am already heavy.... wings are 69 grams
But I will use a single cell lipo to save weight and maybe a GWS reciever (maybe)
Old Apr 22, 2005, 03:49 PM
stjobs is offline
Joined Sep 2001
The parts look great. How much does your boom weigh? I was recently doing some research for my 40" DLG and I went with the G-Force UL which is around 12 grams at 32.5". I'll cut it down to around 24", so it will probably be under 10 grams. I understand the Skinny is much lighter, but I wasn't sure if it would be stiff enough.
Old Apr 22, 2005, 04:04 PM
eightwgt is offline
eightwgt's Avatar
Florida
Joined Jan 2002
ST...
The boom skinny end weighs 3.2 grams..... its a little soft for a DLG though but Im only going to jav launch it so Ill be fine..... and Im tryin anything to keep weight down since Im not the pro at UL construction that Mark Drela is !
Old Apr 22, 2005, 04:18 PM
eightwgt is offline
eightwgt's Avatar
Florida
Joined Jan 2002
Question for Mark D.
Just out of curiousity...... What would you consider to be the limit as far as weight goes for a 40" Apogee ?
I am curious - I have seen you post about it but never a limit...
Old Apr 22, 2005, 07:15 PM
macman01001 is offline
Find More Posts by macman01001
macman01001's Avatar
Joined Jan 2004
Lookin nice. Oh, and where did you end up getting the boom? The avia distributor site?
macman01001 is offline Find More Posts by macman01001
Old Apr 22, 2005, 08:55 PM
stjobs is offline
Joined Sep 2001
What layup did you do on the wings? Also, are you using any spar or reinforcement other than the glass?
I just cut the cores for my 40" DLG, and they weigh 27.7 g. Did you write down how much yours weighed? I hope that I can keep my finished wing with peg under 60 grams. I plan to glass with a single layer of .75 oz fabric and WBPU. My objective for AUW is under 5 oz for this glider.
Old Apr 22, 2005, 09:07 PM
eightwgt is offline
eightwgt's Avatar
Florida
Joined Jan 2002
stobs
I didnt and cant really weigh the cores due to how I do it....
But my finished wings do not have spar caps / spars - nothing... Its only my 'test' p[lane before I really get serious !
My next will have carbon spars caps.....
Old Apr 22, 2005, 09:16 PM
stjobs is offline
Joined Sep 2001
I might try going without a spar on my wing. I made sure to orient the foam with the stronger grain running along the span, and it seems pretty rigid even without the glass. With glass, maybe I can save 5-6 grams and leave out the spar...
Old Apr 23, 2005, 09:54 AM
eightwgt is offline
eightwgt's Avatar
Florida
Joined Jan 2002
Here is the fuse with the top cut open so I can start the task of cramming everything in.... YUou can see I cut it open all the way so the wing sits down on it....
I reinforced the top (near the cut) with carbon tow but wished Id have added just a lil more.....but Im sure I am ok after a bulkhead goes in for the wing bolt
The bulkhead you see is what I will glue the boom end to... will be pretty strong I assume...
Discussion 100" Hollow Molded Dynamic Build Thread joe manor Slope 74 Dec 07, 2007 04:47 PM
Build Log New ECM Apogee 400 R/E !!!!!! Build Thread Stocker Hand Launch 542 Jun 12, 2007 04:06 PM
Apogee (wannabe) build thread Ricardo RW Hand Launch 21 Feb 15, 2005 02:28 PM
Mountain Models Tantrum Partial Build Thread.. Tram Parkflyers 142 Apr 03, 2004 10:41 PM
Hollow molded sloper build Q's Mattebox Slope 4 Apr 28, 2003 06:06 PM
