Old May 23, 2001, 11:38 AM
e-flyer is offline
Find More Posts by e-flyer
Stuck in my wizard suit
e-flyer's Avatar
Deale,MD,USA
Joined Apr 2001
What do I need to put a gearbox on my sky scooter??
I want to put a gearbox on my sky scooter but does the funtec gearbox come with the pinion gear for the motor or do you buy it seperate? if so where do you buy the gear? Thanks!
Alex
e-flyer is offline Find More Posts by e-flyer
Old May 23, 2001, 11:47 AM
Rferrante is offline
Find More Posts by Rferrante
Ravenna, Ohio
Joined May 2001
Yes the funtech gear box does come with a pinion gear. I was somewhat disappointed with the gear box when I put it on. the Sky Scooter was slugish and slow. I took it off and went back to the zagi (Gunther) props, and added a cell to the battery pack. That helped. Since then I have gone back to the gear box, but put on a 9x6 prop, and now with the extra cel and bigger prop the combo really works.
Rferrante is offline Find More Posts by Rferrante
Old May 23, 2001, 11:54 AM
e-flyer is offline
e-flyer's Avatar
Deale,MD,USA
Joined Apr 2001
so the funtec one comes with 2 gears?
Alex
Old May 24, 2001, 12:41 AM
e-flyer is offline
e-flyer's Avatar
Deale,MD,USA
Joined Apr 2001
where did you buy yours?
Alex
Old May 24, 2001, 11:06 AM
Michael Heer is offline
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
I bought one from Hobby People at the same price Hitec sells it for. I used a prop adaptor from Hobby Lobby for 4 mm that comes from Grauphner (SP?) and has 2 allen srews to hold it on. I used a 9 x 6 prop. Scooter no longer pulls to the left and it climbs like a different plane. Mike
Old May 24, 2001, 10:57 PM
aesop0 is offline
Find More Posts by aesop0
Joined Oct 2000
I'm using the Soarstar Motor and gearbox available from Horizon Hobby, 800-338-4639.
Motor / Gearbox (1.85:1??) part number SFM2032, $18.00.
Also, Prop part number SFM1003, $4.95. www.horizonhobby.com
Make sure you get the polarity right when you wire it up. The motor may have a red dot, but you may have to put a black (negative wire) to the red dot side to make the motor a puller instead of a pusher as on the Soarstar (a Wingo lookalike).
Also, I'm just using the 600 mah Sky Scooter Pro battery, didn't find a need to use anything else yet, if flys just fine.
I haven't ordered a replacement motor yet, but the original Soarstar motor I'm using came with a pre-soldered capacitor, a collar to contain / strengthen the magnetic forces, a decent gearbox, and a prop adapter and nut. The prop is an 8x7 I think and it works pretty well with the "stock" gearbox.
Also, put the prop shaft above the motor shaft when regluing the motor back in place.
I used hot glue and haven't had any melting problems yet, but others like silicone like is used around bathtubs that resists the heat of a hot motor better.
[This message has been edited by aesop0 (edited 05-25-2001).]
aesop0 is offline Find More Posts by aesop0
Old May 25, 2001, 12:45 AM
Greg Covey is online now
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
I gave a co-worker a Kyosho Ferias gearbox (2.5:1) and 9x6 prop for his Sky Scooter Pro. On 8-cells of 500A NiCd, it flys very well.
Remember when going geared to add the 8th cell on that 7.2v motor.
Greg Covey is online now Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
What do I need to use my 7C on FMS? Crazyrcer Simulators 1 Aug 01, 2005 01:13 PM
What happens if I put a BP21 on my Slow Stick? Cziltang Brone Electric Plane Talk 11 Jan 27, 2005 04:39 AM
What shall i do to my Sky Scooter Pro 2? saitrix Foamies (Kits) 14 Jan 10, 2005 09:06 PM
Do I need any downthrust on my wing? gouch Parkflyers 3 Jul 03, 2003 10:38 AM
Whoops, Landed my Sky Scooter on the Runway! mrebman Foamies (Kits) 2 Jun 27, 2001 04:21 PM
