Old Apr 21, 2005, 09:46 PM
mikefaith is offline
Find More Posts by mikefaith
3dmp "It's Magical"
mikefaith's Avatar
Richmond, VA
Joined Jul 2004
Question
Hitec Eclips 7 Radio Question
Is there a way to associate 1 of the 2 control knobs on the TX to a channel at the RX. I know that channel 5 is variable by the internal gain setting at the TX and that channel 7 is controlled by a switch but is the TX capable of assigning 1 of itís knobs to provide variable control settings to one of the channels at the RX. If so how do I set it up?
mikefaith is offline Find More Posts by mikefaith
Old Apr 21, 2005, 09:54 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
in heli mode, the two knobs are assigned to hover throttle and hover pitch control. in acro mode , vr2 is assigned to channel 7. you cannot reassign channels on eclipse. evo or jr 9303 on the other hand, you can program it any way you want.. I think my next radio when I need one will be an evo... not for couple years...
askman is offline Find More Posts by askman
Old Apr 21, 2005, 09:56 PM
3dmp "It's Magical"
mikefaith's Avatar
Richmond, VA
Joined Jul 2004
Does this apply to a FP heli?
Old Apr 21, 2005, 10:11 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
you can use either heli mode or acro mode with corona. I use heli mode, as it allows easier control of gyro gain. you could use acro mode with FP heli, if you want to control lets say channel 7 and VR2 for the co pilot. use flap channel for the gyro control.
in heli mode, channel 7 is assigned to toggle switch. so, if co pilot can be preset with on/off, channel 7 can be used.
Old Apr 22, 2005, 06:11 AM
3dmp "It's Magical"
mikefaith's Avatar
Richmond, VA
Joined Jul 2004
Excellent.... Thank you.
Discussion T-Rex or similar helicopter and Hitec Eclipse 7 Radio question jacob_chorid Mini Helis 4 Dec 12, 2006 09:30 PM
FS: Like New Hitec Eclipse 7 radio w/ Spectra module bdamons Aircraft - Fuel - Airplanes (FS/W) 1 Jan 05, 2003 08:28 PM
FS: Like New Hitec Eclipse 7 radio w/ Spectra module bdamons Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2003 07:45 PM
Hitec Eclipse 7 Radio with Helicopters? vkmaynard Electric Heli Talk 12 Aug 30, 2002 10:12 AM
Subject: Need help with CCPM and Hitec Eclipse 7 Radio. tom88 Electric Heli Talk 2 Aug 21, 2002 12:30 AM
