Old Apr 21, 2005, 06:27 PM
cratfy1 is offline
Find More Posts by cratfy1
Joined Jan 2005
Fokker D8 ,Span 57, Power ?
I built a Fokker D8 scratch Earl Stahl, 57 span, weight 26 ounces less battery,
Thinking of using a, Mayhem reverse wound, 8 cell sub C 1700,gearbox 2.3 :1 ,12x6 prop.
Or maybe ,7 cell sub c, 11x6 prop. Geez dont know could be dangerous.
cratfy1 is offline Find More Posts by cratfy1
Old Apr 21, 2005, 07:21 PM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
I'm flying my 72" Morane Saulnier with a MM and a beltdrive (2.33:1) on 8 cells and a 12x8 prop. Your D8 ought to be just fine. The MM is a really versatile motor that provides a lot of bang for the buck.
Dave
dottney is offline Find More Posts by dottney
Old Apr 21, 2005, 08:50 PM
Gravity Fighter is offline
Find More Posts by Gravity Fighter
Houston, TX
Joined Apr 2003
Thinking of doing the same Fokker D8
Do not have arecommendations, since so what new to eletric, but hope you get an answer that works. I am thinkg of building the same Fokker D8 from the same plans.
Gravity Fighter is offline Find More Posts by Gravity Fighter
Old Apr 21, 2005, 10:12 PM
Martin Irvine is offline
Find More Posts by Martin Irvine
Martin Irvine's Avatar
Canada, ON, Kingston
Joined Aug 2000
Keith Shaw has been flying this plane for decades (!), first with a SuperTigre .23 and then with an Astro 15 geared on 12 small cells. It works very well. Keep it as light as you can while still maintaining the design CG. I don't think you are going to need much more than 150W so you can prop for modest amps. If you use 8XGP3300, you will add 16oz. to your 26 for a very light 42oz. At 20A, (160W) you've got 60W/lb - sufficient for good sport performance.
Martin
Martin Irvine is offline Find More Posts by Martin Irvine
Old Apr 22, 2005, 10:09 AM
Houston, TX
Joined Apr 2003
Martiin not sure what 8XGP3300 means??
Old Apr 22, 2005, 11:02 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
8x GP3300 sub C cells?
I comncur that 8 cells/MM/2.3/12x8 is good, or 3s LIPO and 11x7...
Old Apr 22, 2005, 11:47 AM
Joined Aug 2000
Yep, 8 of the GP3300 or 3700 NiMh cells. Or to keep the weight really low, 8 of the GP2200 NiMh cells, (I think that would be about 10oz.!) I didn't recommend LiPos as their cell voltage is either too high, (3S) or too low, (2S), for that motor setup, and you will likely need a little weight in the nose.
Martin
ben buckle fokker d8? nathant Vintage & Old-Timer Designs 5 Jun 27, 2005 04:12 PM
Fokker D8 56 span : gearbox MFG? cratfy1 Power Systems 0 Apr 29, 2005 07:49 AM
Fan Fold Fokker D8 centex pilot Foamies (Kits) 30 Apr 26, 2005 11:46 AM
Herr Fokker DVII 24" Span Rubber Power to Electric RC Conversion help. EGB Scale Kit/Scratch Built 10 Feb 26, 2003 12:35 AM
13 oz, 38" span Cub power? tim_j-rome Parkflyers 1 Jul 10, 2002 01:58 PM
