Old Apr 21, 2005, 08:56 AM
Magnum9 is offline
Find More Posts by Magnum9
Molded Hotliner Destroyer
Magnum9's Avatar
Perth, Australia
Joined Jul 2004
General rule on prop diameter vs pitch to maintain current?
As I have no test equipment to check amp draw, is there a general rule for maintaining the same amp draw? As a rough example if I am running a 12x6 prop on a geared brushless setup, would a 11x8 and a 13x4.7 both draw similar current, or are there too many variables for such a simple theory?
Magnum9 is offline Find More Posts by Magnum9
Old Apr 21, 2005, 09:18 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
From RCM years ago: 2 * D + P.
2 * 10 + 6 = 26 = 2 * 9 + 8 =
2 * 12 + 6 = 30 = 2 * 11 + 8 = 2 * 13 + 4
jrb is offline Find More Posts by jrb
Old Apr 21, 2005, 10:41 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
That is a fairly close quick and easy calculation and is most likely plenty close enough considering that props vary greatly.
A more accurate equation is Dia to the power of 4 times pitch.
10X6: 10X10X10X10X6=60,000
9 X8 : 9X9X9X9X8= 52,488
From MA many,many years ago.
Charles
Old Apr 22, 2005, 05:40 AM
Magnum9 is offline
Magnum9's Avatar
Perth, Australia
Joined Jul 2004
Thanks guys. Looks like my guess of go down 1 inch on my diameter and up 2 inches on pitch, or up 1 and down 2 was pretty close.
Old Apr 22, 2005, 06:05 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Yup. 7x6=8x4 as far as draw goes, more or less
Old Apr 22, 2005, 08:57 AM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
If you've got a tach, just make sure your new prop rpm is at least the same or higher than the old prop rpm. If its exactly the same, your amps are exactly the same.
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Question Maximum prop diameter vs wingspan or area? Popsflyer Power Systems 3 Apr 12, 2007 11:07 AM
Prop Diameter vs Model Size Joe Papa Power Systems 13 Mar 31, 2005 07:52 PM
Problem on EPS 400C Vs EPS 300C for Slow Stick?? Amount of Current Drawn... eta Parkflyers 1 Feb 23, 2003 09:24 AM
Questions on prop pitch neonbutterfly Electric Sailplanes 1 Jan 25, 2003 02:57 PM
prop rpm vs. static thrust/pitch speed opualuan Power Systems 2 Feb 19, 2002 07:48 AM
