Old Apr 20, 2005, 09:09 PM
lift off is offline
Find More Posts by lift off
HELL no you cant fly it!
lift off's Avatar
Joined May 2004
Help!
wacked up esc/motor... WHATS UP WITH MY MOTOR?
I got ine of the balsapr fiegao ips brushless motors w/ ips "A" gearbox and bp10 amp esc combos. I hooked everything up per the instructions for the first time and all i get when i power it up is a little pipping nose and the the prop starts spinning one way then the other and just keeps changing directions. I checked all of my connections and nothing is wrong! WHAT IS WRONG?!?!?!?!?
Matthew Zizzi
lift off is offline Find More Posts by lift off
Old Apr 20, 2005, 10:09 PM
Lomcevak is offline
Find More Posts by Lomcevak
It flies? I like it!
Joined Apr 2004
Sounds like a dead phase. Double check the speed controller to motor connections (all 3 wires). If that doesn't work, either the motor or the controller has a dead phase. My bet would be on the Feigao but that's based on 16 Castle Phoenixes without a single failure and 1 bad Feigao out of 3 not any industry-wide statistical info.
Lomcevak is offline Find More Posts by Lomcevak
Old Apr 21, 2005, 06:01 AM
lift off is offline
lift off's Avatar
Joined May 2004
so its my motor and not my esc that as the problem?
Question whats wrong with my motor? Call Me Jack Electric Plane Talk 2 May 13, 2007 12:30 PM
Help! Help whats up with my motor? scottypotty Electric Motor Design and Construction 2 Mar 23, 2006 11:44 AM
Cool E-flight brushless motor not working with my ESC? Bgarrett777 Power Systems 3 Mar 17, 2005 08:12 PM
Whats up with my new 1200 HP pack???? Speedfreak Batteries and Chargers 1 Jan 24, 2005 08:46 PM
What's up with Conversion Motor Works? jamesdh Vendor Talk 2 Oct 28, 2004 02:44 PM
