Not going to be cheap. Here is a good place to start looking for motor . Charles |
The sports plane forum has people with a ton of experience with these kind of conversions.
If you are aiming for 3D a geared motor spinning a big prop relatively slowly is regarded as a good way to go. Something between a Hacker B50 13S - B50 10L with around 4S-5S lipo cells spinning a 17-18 inch prop is typical for 3D planes in this size range, depending on weight. There are many other options but that could be a starting point. The motor with gearbox weighs around 250 g (say 9oz) and the battery pack will be around 18-20 oz. So add 30 oz to the weight of your plane without the glo engine and fuell tank. |
Joined Apr 2005
I've seen some of the bigger brushelss motors with planetary gear drives built on the motor. Would that be the way to go?
Local guy is telling me to get a big outrunner and swing a 12-14" prop on this model. I've always been of the mindset that RPM=power. So, I'd be more inclined to lean toward a motor turning higher RPM and then gearing it town to get the torque required for my prop. With that in mind-- then how do you select your reduction ratio? 4.3:1 or 5:1 or 6:1 or 2:1???????????? Relying on a direct drive with an outrunner kinda goes against that theory. But- then again-- I don't know beans about electrics. ![]() Thanks for the help with this. |
Joined Apr 2005
On the Watts/Pound ratio for my power requirements:
I was told to go MINIMUM 125 watts/pound for decent 3D and that 175--200watts/pound would be the kind of power I needed for 1/2 throttle hovering. Is 175watts/pound gonna cost me $1000? If so- then I got a .61 glow engine for this thing. It's sitting on the shelf in a box--out in the shop. I'm willing to spend $300--$600 for this powerplant, but thats even completely nuts when you consider that I have a NIB glow engine for it already. No way I'll spend $1000 for electric power on a $100 Fun Fly plane. |
Joined Apr 2005
Well, this thread is a waste of bandwidth.
Just priced the big hackers with gearboxes. They cost between $250--$350. 80amp ESC will run about $125--$150. And the batteries are gonna run another $200 Forget it. I'm just not that curious about the "cool factor" of an electric 3D plane this size. Sorry to waste everyones time. |
Either an outrunner or a geared inrunner will do the job. As a general statement in my personal opinion the outrunner will need more amps than the inrunner.
You should aim for 125 watts/lb or more more for hovering power. Again that is just my opinion. As for price there is no doubt it will cost. I'm in Australia so all I can say whatever it costs you it cost me more because I have to import all my gear. Just so you don't kid yourself about cost You need a motor, esc, charger, and batteries. Most people want two batteries to do the job properly. You can price thunderpower batteries at www.tppacks.com, and geared motors and esc at www.aircraft-world amongst vendors that I use personally. |
I've got this motor on a 3S and it flys a 4lb. Tiger Moth scale but nothing more.4S is needed to get the motor close to its potential Rcpilet If you change your mind check out Espritmodels.com they have lots of nice mounting options.FWIW minus the cost of the plane it cost me around $550 to get a 4lb. glow model converted to electric...well worth it to me anyway steve |
Yup. It can be done but not cheaply. You don't need to spend that much in te motors, but ESC and batteries are in the ballpark, sadly. |
| Thread Tools | |
| Article A Pair of Six Packs -- or -- How to Convert the Average Glow Trainer to Electric | jrb | Electric Plane Talk | 45 | Apr 13, 2010 11:14 AM |
| Discussion Best 40 Glow Size For Electric 3d | submarco | 3D Flying | 7 | Mar 25, 2006 02:24 PM |
| How different is glow flying from electric | chris8105 | Beginner Training Area (Fuel) | 56 | Aug 27, 2005 06:20 PM |
| Question on a 6.5lb 3D bipe conversion | 3d nate | Power Systems | 7 | May 11, 2005 11:13 AM |
| Electric 3D Hovers with Glow 3D | realglow | 3D Flying | 4 | Dec 18, 2004 03:39 PM |
