Old Apr 20, 2005, 12:10 PM
romaink is offline
Find More Posts by romaink
Joined Jan 2005
Maximum voltage charge in NiMH battery Pack
I am a newbe to RC flying and battery charging. My ICE charger charges my new 8 cell pack of SC3500 NiMH batteries to 11.1V(the batteries will power a Mega motor on a Corona Heli). I am using a Pyramid PS14KX with an input voltage of 14.1V to the ICE. I thought an 8 cell pack should not be charged to a voltage above 9.8V(1.2V per cell).
Will this higher voltage damage the batteries? According to the ICE manual I can't set a specific charge voltage for NiMH or NiCad batteries. I can only set the number of cells in the battery and ICE will charge to the correct voltage.
romaink is offline Find More Posts by romaink
Old Apr 20, 2005, 12:30 PM
SilverFoxCPF is offline
Find More Posts by SilverFoxCPF
Bellingham WA
Joined Jan 2005
Hello Romaink,
Even though NiMh cells are rated at 1.2 volts per cell, they are charged up to around 1.4-1.5 volts per cell.
Tom
SilverFoxCPF is offline Find More Posts by SilverFoxCPF
Old Apr 20, 2005, 06:52 PM
50+AirYears is offline
Find More Posts by 50+AirYears
United States, SC, Irmo
Joined Jul 2004
1.5 V/cell would be pushing the upper limit for the chemistry. For any rechargeable battery chemistry, there is a specific Voltage difference range between the battery to be charged and the charging source. For most types of batteries we use, the difference is about 0.2 Volts/ cell minimum. For NiCad and NiMh, the Automatic Peak Detect or Delta Peak detect chargers are the best, if a bit pricier than the simple timed chargers that come with some cheap outfits.
50+AirYears is offline Find More Posts by 50+AirYears
Sunny Boy with NiMH battery pack ETutor Foamies (Kits) 0 Jun 24, 2002 07:48 PM
Suggested plane for a 8 cell 2100mAh NiMh battery pack ? ARE Electric Plane Talk 1 Apr 28, 2002 01:51 PM
Anyone please help - Can a 7.2 volt charger charge a 9 volt Battery pack? Jamie- Electric Plane Talk 5 Jul 29, 2001 07:49 PM
What Nimh battery pack should I get for my Skat to get long flights? Ryan Nau High Performance 15 May 21, 2001 05:32 PM
