Old Apr 20, 2005, 07:04 AM
turbolover is offline
Find More Posts by turbolover
loving turbos
turbolover's Avatar
Switzerland
Joined Jun 2004
Question
T-Rex 450 or Ark X-400
After beeing offline/off-air for half a year I want to go back to heli-business and looking for a big brother for my aerohawk.
1) What's the difference betweekn T-Rex 450 and T-Rex 450X V2 (like90)?
2) Will you take the T-Rex or the X-400 if money isn't the issue?
3) Helihobby has the "Trex 450X Explosive Brushless Combo" - any good?
4) Should I wait for the CCPM? (my TX is graupner mx-22 10-channel)
5) Do I need 4-ch or 6-ch RX? CCPM needs 5? EP 4? Did I miss something?
6) Receiver and servos still run on BEC?
turbolover is offline Find More Posts by turbolover
Old Apr 20, 2005, 07:52 AM
skwidd is offline
Find More Posts by skwidd
Stupid Newbie
NOLA
Joined Feb 2005
1. V2 has the improved swash
2. I'd take both
3. Dunno
4. Nah.
5. 6
6. yes
skwidd is offline Find More Posts by skwidd
Old Apr 25, 2005, 07:24 AM
loving turbos
turbolover's Avatar
Switzerland
Joined Jun 2004
Getting back to my questions. I am still very unsure if I should wait and go for the X-400 or if you guys recommend the T-Rex.
I can start right now but I can also wait a month and get an eCCPM. Anybody take a look at the helihobby offer? http://www.helihobby.com/html/trex_helicopter.html
Explosive brushless combo for $625:
- KX015013TA Trex Heli 450X Pro kit
- CASTLE-PHX-35 Phoenix 35 Brushless Sensorless ESC
- ACN16-15-4 Mega ACn ACN16-15-4 Brushless Motor
- HRC31055 HS-55 Hitec Standard Feather Servo
- HRC31050 HS-50 HiTec Servo
- HRC25272 Hitec Micro Electron 6 receiver Futaba/Hitec dual Shift
- FUTM0809 Futaba GY240 Gyro with Heading Hold
- TP2100-3SJ 3C LiPoly Pack 2100 mAh 11.1V
- EM007 T-Rex 450X Aluminum Battery Extension Plate (Blue)
- EM008 T-Rex 450X Aluminum Fin Set (Blue)
The pack contains all I need but if you guys tell me that there are better parts out there at approx. same cost, I will rather put a basket together.
Old Apr 25, 2005, 07:59 AM
Tonystott is online now
Find More Posts by Tonystott
Its all fun
Tonystott's Avatar
Australia, NSW, Forster
From what I hear on this forum, I would want someone to inspect the package before you took delivery.. seems like sometimes the order gets "confused".
Tonystott is online now Find More Posts by Tonystott
Old Apr 25, 2005, 09:39 AM
labmaster is offline
Find More Posts by labmaster
good old germany, near munich
Joined Jan 2005
should be V2, i would not buy an old kit, there are so many small improofments made on V2
Governor mode makes somethimes problems and BEC migth be a problem
as on all other brushless controller except Kontronik JAZZ.
look here
As i know the 16-15-4 should be used with 4 cell lipo, for 3 cell setup the 16-15-3 is better. On 4 Cell setup BEC on CC PH. 35 can not be used at all (with 4 Servos).
Thats ok
no clue, as long at it's a somewhat inteligent receiver, means that it has a
processor for filtering glitches ... it ok for that job.
pretty good, but for a couple of bucks more you will get a GY401
good battery
that or another solution is needed to provide a good way to fix the battery
only optical tuning but i would like it
labmaster is offline Find More Posts by labmaster
Discussion T-Rex 450, or MX450? edge5foamy Mini Helis 7 Aug 05, 2007 05:45 PM
ARK X-400 VS Trex 450 XL for newbie malkekoen Mini Helis 38 Sep 19, 2006 04:33 PM
Question MX 400 or T-Rex 450 X CDE w/25G esc and 430LF brushless motor ? Al P Mini Helis 2 Jun 21, 2006 01:27 PM
T-Rex 450 or ARK X-400 roundthebend Mini Helis 11 Aug 25, 2005 08:48 PM
New T-rex 450............The X-400! skyhawk Mini Helis 73 Mar 16, 2005 07:52 AM
