Old Apr 04, 2002, 09:30 AM
rakm is offline
Find More Posts by rakm
rakm's Avatar
Pensacola Regional, Florida, United States
Joined Jan 2002
Is it safe to use single quallcomm 830 for a rx/2 servo pack?
Could I safely use a single cell quallcomm 830 (3.6v) mah to power a JR610m and two JR241 mini servos? I would like to power these for a Colibri MHLG. I know the usual pack recommendation is 4.8 volts but am trying to save weight and get a really good duration pack.
Are there any disadvantages to using the lower voltage cell?
What would the effects be of using a lower voltage pack? Would it just slow the servos down?
Could it cause the receiver/servos to fail in flight?
rakm is offline Find More Posts by rakm
Old Apr 07, 2002, 01:37 PM
Quacker is offline
Find More Posts by Quacker
ClearView rocks Phoenix& Dubai
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
I use a single Qualcomm 830 in my DLG. I can't answer for your particular choices in equipment, but I tested and passed some of my own. To do this, I first set a low battery limit above which the equipment MUST work. I then measured the total current (servo's moving). I then discharged and recorded the voltage of the single cell with this much current. I was amazed and delighted. The battery ran well above the "must work" voltage for almost it's entire discharge. Net--I get about 5+ hours with margin!
Equipment tested:
Hitec 555
FMA Extreme5 (best running and rated by FMA at 3.5V)
Hitec HS-50 servo's
Ikarus Micro Gyro
The low voltage affected only the servo motors. This means slower response and less torque. Still fine in a small ship.
Q
Quacker is offline Find More Posts by Quacker
9303 Programming for DLG 2 servo wing rpsmithii Hand Launch 11 May 24, 2009 12:20 AM
Discussion Can I use my own transmitter for Honeybee 2 crasher1339 Micro Helis 5 Jul 27, 2006 02:21 PM
Safe to use 300mA power brick for 7-cell NiCad? isaksp00 Batteries and Chargers 0 Mar 27, 2005 09:16 AM
Max current charge for my 2/3 A pack? rubychild Batteries and Chargers 5 Feb 15, 2005 10:46 PM
FS - 2M glider, Rx, (2)servo signal filter/boost extensions Skid Aircraft - Electric - Airplanes (FS/W) 6 Oct 09, 2003 03:53 PM
