Old Apr 18, 2005, 10:37 AM
Quicker is offline
Find More Posts by Quicker
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
Build Log
Let's build a Skeeter! NEW UPDATED PLANS!
What's a skeeter? Well, After I trashed my Kat 30 prototype last Thursday after a mid-air and then flying it through my neighbor's swingset I needed a new plane to mount my 2015 on. I could have just whipped up another Kat 30, but I am always in need of a new design.
The cool thing is, I'm posting the plans for free download. Not everything I design is up for sale. Sometimes it's just fun building and sharing.
This is a VERY simple structure with no laser cutting needed. I did use a band saw for the nose, but you can use a blade very easily. I kept it extremely simple so that you guys would build it.
Specs:
Span: 30 inches
Length: 30 inches
Projected RTF weight: 13-14 ounces
CG: 3.75-4 inches aft of the LE.
This is what I'll be using:
Motor: Himax 2015-4100
Gear: 6.6:1
Battery: 3Cell ETec 1200
Prop: APC 11x4.7 and 10x4.7
Servos: Tower Pro 9 gram ( 4 of them )
Added March 15, 2008
Free download for AFP and AFPD sims.
http://kalteisen.com/skeeter_30.html
Here's the plans and bill of materials:
This is what I bought to build the plane. I had some stuff left over, but not much.
8 - 1/4x1/4 sticks
8 - 1/8x1/4 sticks
5 - 3/16x1/4 sticks
2 - 3/32x3x36 -- You will use all of these to make the ribs.
1 - 1/4x3x36 sheet -- You only need about 12 inches of this. This is what the nose is cut out of, and some reinforcement blocks.
1 - 1/16x3x36 sheet -- You only need about 15 inches of this This is only used for sheeting the wing center
3 packs of LiteSpan. You can use any lite covering. Monokote is too heavy.
2 packs of the Dubro Micro horns. Tower Part LXJGT5
1 pushrod wire. Cut and bend your own.
I did not put a lot of step-by-step procedures in the plans.
Quicker is offline Find More Posts by Quicker
Old Apr 18, 2005, 10:41 AM
Quicker is offline
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
Here's the fuse build
Old Apr 18, 2005, 10:43 AM
Quicker is offline
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
Some more
Old Apr 18, 2005, 10:45 AM
Quicker is offline
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
On to the covering
Old Apr 18, 2005, 10:48 AM
Quicker is offline
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
I used floppy disk hinges, which I really like for this size of a plane. Just rip open a 3.5 inch disk, and cut the hinges out of the disk material. It works great.
My RTF weight came in at 14 ounces. I put a much thicker airfoil on this plane than I have on any other little plane I've built. From what I see I like this. It makes it fly much bigger.
In 5-7mph winds it was very solid and a lot of fun. I was able to hold a hover and let the wind blow me to the other side of the field. In 7-10mph winds it was still a good sport flyer, but 3D was tough and no fun. KE is easily entered and it will hold it fine. I need to shift the CG back to get a better HAKE. With the CG at it's current position I go inverted and I just need to hold a little pressure on the stick. Not much, just thumb pressure. Flatspins are solid and tight. Harriers are good with very little wing rocking. The thicker airfoil makes it feel much bigger. I'm liking this a lot. This is a very good outdoor little plane.
I'll have it indoors Wed and hope to get some video.
Old Apr 18, 2005, 10:49 AM
Bill Bergman is offline
Find More Posts by Bill Bergman
Houston, Tx.
Joined Jan 2003
Very Nice!!!!
Bill Bergman is offline Find More Posts by Bill Bergman
Old Apr 18, 2005, 10:51 AM
Quicker is offline
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
The plans have a CAD file and a set of PDF's that are tiled. You can easily print out the PDF's and tape them together for the fuse and wing. The other parts all fit on a single 8.5x11 sheet, so you can just print them out and trace onto the wood.
You are free to build and fly as many as you want, but no selling them.
Old Apr 18, 2005, 10:53 AM
Boss248
Boss248
Guest
n/a Posts
Not everything I design is up for sale...you sell your designs?..wow that's great..I designed some good planes and I have to pay people to try them...hell I even offered free kits shipped to thier doors and not one taker. I must be in the twilight zone or something...beautiful plane BTW. I guess some got it..and some never will, and I am of the latter, and I have been designing planes for 35 yrs so I have a fair idea of what goes where but dang...
Boss
Old Apr 18, 2005, 11:06 AM
Jeffery is offline
Find More Posts by Jeffery
And You're Not
Timbuktu, Mali (Happy?)
Joined Oct 2002
Boss
He designs planes for an ARF manufacturer, but also sets out some free ones now and again.
Jeffery is offline Find More Posts by Jeffery
Old Apr 18, 2005, 11:09 AM
Quicker is offline
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
Hey, Auger, when you gonna build this one? You CAN'T be waiting on a motor this size also?
Old Apr 18, 2005, 11:24 AM
Jeffery is offline
And You're Not
Joined Oct 2002
Man, I got so many gosh durn* planes to finish now it's not even funny. This looks like a good replacement for when the EF Yak finally bites it..
*Wow, the censorware took out f r i c k i n !
Old Apr 18, 2005, 11:36 AM
DesertRC is offline
Find More Posts by DesertRC
DesertRC's Avatar
Tucson, AZ
Joined May 2002
Quicker-
Looks great. Thanks for the plan. I am going to build this one for sure
I dig the huge airfoil. The biggest airfoil I have flown was on my Super Hots.
One of my all time faves.
-Chris
DesertRC is offline Find More Posts by DesertRC
Old Apr 18, 2005, 11:48 AM
Boss248
Boss248
Guest
n/a Posts
Of course he does, and it shows..no wonder my designs never make it..some got it ..and some never will...but I am glad he is kind enough to post some freebies from time to time.
Old Apr 18, 2005, 11:51 AM
Jeffery is offline
And You're Not
Joined Oct 2002
Well, I did just plot the full sized plans...
Old Apr 18, 2005, 12:12 PM
Quicker is offline
kalteisen.com
Quicker's Avatar
Omaha, NE
Joined Aug 2003
Thanks, guys.
Well, that's step 1
Discussion Skeeter 30 got PHAT. Let's build a phatty Quicker 3D Flying 340 Aug 17, 2015 01:40 PM
Let's build a Winger Models One Design DR-107 Martin Hunter 3D Flying 153 Sep 11, 2007 07:42 AM
Rave Let's Build a GW-ezone 40" 330 SharksTooth Foamies (Kits) 248 Oct 09, 2004 09:29 AM
Let's build a Lil 3Der! Martin Hunter Parkflyers 136 Jan 26, 2004 02:28 AM
Let's build a plane - #2 hoppy Foamies (Kits) 37 Oct 14, 2001 06:21 PM
