Go Back   RC Groups > Aircraft - Electric - Jets > Electric Ducted Fan Jet Talk
Old Apr 17, 2005, 05:57 AM   #1
oldpilot's Avatar
Jet Design Contest. Jedi Star Fighter.
I decided to build this model after seeing Alfredo Delgardo's tractor prop design a couple of years ago.
Basically it is built out of 1" thick small cell Styrofoam, which is pretty stiff.
The DF's are two K & P microjets, in series on a Kokam 3S 340 Li Poly pack.
Total thrust with proper entry and exit additions should be 6 oz with an appropriate exit velocity.
All standard GWS small electronics are planned as I have that stuff kicking around in my "Ditty Box".
Cutting out and sanding to shape the basic airframe is the easy part. These major parts took me two hours. The fairing of the motors is more tricky. This first one took over an hour to dope out. the second one should be quicker.
1, The plastic model.
2. The basic parts.
3. The styrofoam forms around the basic DF to smooth the intake airflow to the fan, and the tailcone to increase the exit velocity. Adds 2 oz thrust to each unit
Cheers. Paddy.
oldpilot is offline Find More Posts by oldpilot   Reply With Quote
Old Apr 17, 2005, 07:17 AM   #2
Bristol Ascender EDF Project
Rocketman1092's Avatar
Hope it gets finished in time!
Rocketman1092 is offline Find More Posts by Rocketman1092   Reply With Quote
Old Apr 17, 2005, 08:46 AM   #3
oldpilot's Avatar
SO DO I.
Took a sheet of butchers wrapping paper tonight and drew up the full scale lines to establish the theoretical CG position. I then taped an eraser to the nose at a position which gave me that CG. Flew beautifully in the living room!!! Theres hope yet.!
Cheers. Paddy.
Old Apr 23, 2005, 09:41 PM   #4
oldpilot's Avatar
Drawing out the lines to calculate the theoretical CG position
The parts taped together while the glue sets. "Kipper" RPA. Sets in 25 min.
Rear view. The twin jets sit under the wing, at the back. So I guess I am going to need a heavier battery to balance at the correct CG position.
Seven days to go. !!! Patrick.
Old Apr 25, 2005, 09:21 AM   #5
oldpilot's Avatar
NO !!! They are not a pair of binoculars, they are the Ducted Fan units, primed and ready to got into the lower "Keel" of the airframe.
Finishing with lightweight filler and acrilic paint will make them look better.
All electronics are installed and the jets are glue drying overnight. Will be able to have a static test run tomorrow. The Elevons have been installed, hooked up and tested. So far so good.
Five days to go, Finish and painting is going to be the time comsuming bit!!!!
We are having wonderful weather right now.
Wanna bet it's going to be raining when "Maiden" time comes around.
Cheers. Patrick.
Old Apr 25, 2005, 09:36 AM   #6
oldpilot's Avatar
UH ! OH !
Preliminary weight and balance trial shows this model is going to be MEGA tail heavy. I shall have to use a heavier battery.
I have a 3S 2600 Li Poly, but am wondering if that is going to be overkill.???
Cheers. Patrick.
Old Apr 25, 2005, 06:30 PM   #7
This Place Blows
netmechanic's Avatar
It will balance better once you get your R-2 unit installed, there pretty heavy
netmechanic is offline Find More Posts by netmechanic   Reply With Quote
Old Apr 26, 2005, 01:18 AM   #8
oldpilot's Avatar
Well.----
The glue dried overnight alright. Only prob was it was RPA and it expanded to include my right elevon pushrod.
Now I have to waste time dismantling it and cutting it free. DOH !!!!!
More haste less speed. Patrick.
Old Apr 26, 2005, 09:31 PM   #9
oldpilot's Avatar
FIXED the Glue blooper in about 10 mins and rigged up the whole system. Ran the fans on a 6 cell NiCad to test. Got 50 Watts at WOT and the fans song was a joy to hear.
The complete plane( not painted) weighs 16 oz with the 3S 2600 Li Poly. So I really wanted 100W of power, although I would have settled for 80W.
THEN DISASTER. It was 10pm and I was tired and should have known better, but I thought I would just try the 3S Li Poly. I got 50 Watts at 1/2 throttle, then I thought "what if" ? and went to full throttle.11.5V, 11A & 125 W.
That was it. Two seconds and the motors were killed. Now it's really a race against time to see if I can replece the motors and get this bird in the air before I paint and decorate it for flying pics.
I need LOTSA LUCK this time.
Cheers. Patrick.
Old May 01, 2005, 04:04 AM   #10
oldpilot's Avatar
Gee I forgot to post on this thread and put stuff on the Stickythread instead.
Well Laurie Kelsall to the rescue. Phoned him and had two replacement motors in my hand by 10 pm the next day. A bit of cut and fit and I was in the game again.
Fri at 4 pm got out and flew it "In the Buff". See pics.
Now for painting, decorating and flying,to qualify in the contest.
Cheers. Patrick.
Old May 01, 2005, 06:59 AM   #11
oldpilot's Avatar
HERE IT IS fully painted up and decorated ready for the Fully Finished Flights.
And here is a sneak preview of one of the flight pics.
All details now posted to ARBO. Cheers. Patrick.
Old May 01, 2005, 02:27 PM   #12
GRE99's Avatar
Fantastic job! My son and I are avid Star Wars fans and love the fact you chose this suject to build. If it flies as good as it looks I hope you win.Tell me you made plans and drawings please. May I be the first to beg for a copy so i can build one for my sons 7th birthday. Please please please.
GRE99 is offline Find More Posts by GRE99   Reply With Quote
Old May 01, 2005, 02:48 PM   #13
Way to go Patrick! Very nice.
Steve
U812 is offline Find More Posts by U812   Reply With Quote
Old May 01, 2005, 03:10 PM   #14
EDF rules... :)
AirX's Avatar
Hey that is pretty neat looking, and great timing too with the new movie opening soon.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX   Reply With Quote
Old May 01, 2005, 06:36 PM   #15
Gimme the whole 12 blades baby
stumax's Avatar
Excellent stuff, Patrick!!! But where are the usual "photo accessories"?
Stu.
ps. how 'bout flying this week? Wed?
stumax is offline Find More Posts by stumax   Reply With Quote
Reminder: Electric Jet Design Contest Andy W Electric Ducted Fan Jet Talk 15 Oct 14, 2002 12:44 AM
Electric Jet Design Contest - 2002 dave_lilley Electric Ducted Fan Jet Talk 93 Jan 19, 2002 10:53 PM
Electric Jet Design Contest - 2002 Travis Site Chat 2 Jan 14, 2002 03:22 AM
Electric Jet Design Contest - 2002 dave_lilley Site Chat 0 Jan 10, 2002 02:52 AM
Electric Jet Design Contest - 2002 dave_lilley Electric Plane Talk 0 Jan 10, 2002 02:52 AM
Congratulations SimpleM!
