Old Apr 16, 2005, 11:00 PM
Foamaholic is online now
Find More Posts by Foamaholic
Electric since 1990
Foamaholic's Avatar
East Central Ohio, United States
Joined Jun 2004
PHX-Link works on one computer and not on another
My friend just bought a PHX-Link and it doesn't work. When he plugs it in the light comes on but won't recognize his esc.
We plugged his link into my computer and the same esc and it works fine.
Must be a setting on his computer that's stopping it from working.
Anyone know why it would work on my computer and not on his?
Thanks.
Foamaholic is online now Find More Posts by Foamaholic
Old Apr 17, 2005, 06:52 AM
toragi is offline
Find More Posts by toragi
Glenn0
Newcastle Williamtwn, Australia
Joined Aug 2004
Probably the usb drivers on his comp. Is he using Win 98SE?
Glenn
toragi is offline Find More Posts by toragi
Old Apr 17, 2005, 07:44 AM
Electric since 1990
Foamaholic's Avatar
Joined Jun 2004
He just bought the computer a few months ago.
Running Windows XP Home.
Thanks.
Old Apr 18, 2005, 04:52 AM
toragi is offline
Glenn0
Joined Aug 2004
Did the PHX Link software, and the usb drivers install ok on your friend's computer?
Old Apr 18, 2005, 08:12 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Thanks.
Dell PC?
WimH is offline Find More Posts by WimH
Old Apr 18, 2005, 08:58 AM
Electric since 1990
Foamaholic's Avatar
Joined Jun 2004
Emacines.
The software and drivers are installed and everything seems okay except that when he runs the software with the link plugged in the two boxes remain red. One should turn green when he plugs it in and the other should turn green when he plugs in the esc.
Old Apr 18, 2005, 09:15 AM
Bernie Wolfard is offline
Find More Posts by Bernie Wolfard
Castle's Chaos Corner
Bernie Wolfard's Avatar
Olathe, KS (next to the Castle)
Joined Jun 2001
If the box in front of the statement 'USB PHX-Link Connection, on the software page with the link plugged is not green the Link driver is not installed correctly. If this is the case try the following instructions to get it installed. Remember, you need to tell windows where the driver is, it will not find it unassisted.
1.Click ‘Start’ and go to 'Settings' then 'Control Panel'
2.Double click on 'Add Remove Hardware'
3.Let windows know the hardware is already installed (make sure the link is plugged in), click Next
4.Find the PHX-Link on the hardware list and select it, click next
5.Windows will tell you the hardware has a problem, click 'Finish' to start the Driver Installation Wizard
6.Select 'Include this Location in Search' and type in this location [c:\program files\phx-link\driver], or use the browse button to brows to this location. Click Next
7.Windows will tell the driver is not certified, click Continue.
8.Click Finish
Bernie
Bernie Wolfard is offline Find More Posts by Bernie Wolfard
Old Apr 18, 2005, 09:17 AM
Electric since 1990
Foamaholic's Avatar
Joined Jun 2004
Thanks Bernie. I'll pass this along to my friend.
PHX-Link works with Ph25 but not Ph35? solouk Castle Creations 7 Jan 17, 2005 03:18 PM
Auto LVC works on one but not the other mjdoz Castle Creations 13 Oct 12, 2004 04:11 PM
Reversing one servo on a channel, but not the other? astroboy Radios 13 May 20, 2003 03:57 PM
