Old Apr 16, 2005, 07:29 AM
australia
Joined Apr 2003
I want to make a computer power supply to run my field charger??
HI
I have my old pc and was thinking of using the power supply to run my chargers so i can charge batterys at home with out opening the shed and car bonnet every time.
I know this can be done but am not sure. I know that there is a 12v output and a 5 volt output and i trhink that i need to load one side ( 5v ???) to help the 12 volt side. I don,t need much more than 2 amp power output.
Can this be done and any advice??
I don't want to damage my chargers or expensive li-polys.
Thanks Rob
robertjusher is offline Find More Posts by robertjusher
Old Apr 16, 2005, 09:10 AM
Canada, NB, Fredericton
Joined May 2002
Put a 10 ohm resistor between the 5v and gnd of one of the hard drive connectors. The resistor needs to be 5 watt or better.
Measure the 12v output, and check that it's reasonably stable the first time you use it. Also check the rated output of the power supply, and make sure you're within it.
D.
darkith is offline Find More Posts by darkith
Old Apr 16, 2005, 09:11 AM
Western KY
Joined Sep 2003
http://web2.murraystate.edu/andy.bat...mpledriver.htm
Andrew0820 is offline Find More Posts by Andrew0820
Old Apr 17, 2005, 09:58 PM
RockDragon's Avatar
Joined Jan 2005
R/C 12 Volt Power Suppy Conversion from AT Computer Power Suppy
A 12 Volt Power Supply
RockDragon is offline Find More Posts by RockDragon
Question Can I use an old computer power supply as a DC source for my charger? tangel Batteries and Chargers 8 Jul 02, 2007 11:41 PM
Power supply for my Swallow Charger? ontheweekend Batteries and Chargers 4 Nov 10, 2005 03:02 PM
Do I need a Power Supply for my Triton charger? Shekhat Batteries and Chargers 6 May 02, 2005 10:26 PM
computer power supply for dedicated lipo charger power Batteries and Chargers 1 Sep 16, 2003 10:55 AM
Using a computer power supply for DC power for charger... T-Bo Electric Plane Talk 13 May 11, 2002 01:45 AM
