Old Apr 14, 2005, 02:53 PM
philip noel is offline
Find More Posts by philip noel
Scale Aircraft Designer
philip noel's Avatar
Hertfordshire
Joined Apr 2005
Build Log
B-25 Mitchell & F7F Tigercat Build
Hi, i hope to show you the progress of the construction of these two models over the next few weeks.
Stats
B-25 Mitchell
Span 50"
Length 38.5"
Two 480 standard brushed motors
Two 3:1 gearbox's
One 25amp speed controller
two micro servos (ailerons)
one mini servo (elevator)
all up weight 2.5lbs (i hope)
F7F Tigercat
Same as above apart from
span 40"
length 35"
Also you might see some progress of my ME262
Keep your eyes peeled
Phil
philip noel is offline Find More Posts by philip noel
Old Apr 14, 2005, 03:03 PM
Hertfordshire
Joined Apr 2005
mitchell wings
Wings, inboard and outboard panels, 1/16" balsa ribs, front spars 1/8" sq spruce, rear spars 1/8" sq balsa.
Wing skins 1/16" sheet balsa, main wing and fuse former (two) 1/16" plywood.
Glued using cyno.
Old Apr 14, 2005, 03:04 PM
Hertfordshire
Joined Apr 2005
Tigercat wing
Same as mitchell
Old Apr 14, 2005, 03:32 PM
WillowPtarmigan is offline
Find More Posts by WillowPtarmigan
Lagopus lagopus
WillowPtarmigan's Avatar
Houston Hobby, Texas, United States
Joined Jul 2003
Looks like it will be a nice model. Keep up the good work.
WillowPtarmigan is offline Find More Posts by WillowPtarmigan
Old Apr 14, 2005, 04:04 PM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Very nice
Haldor is offline Find More Posts by Haldor
Old Apr 14, 2005, 04:12 PM
Hertfordshire
Joined Apr 2005
Old Apr 14, 2005, 09:03 PM
YEAP CHIN POH is offline
Find More Posts by YEAP CHIN POH
Penang, Malaysia
Joined Jun 2002
Doing 2 at the same time is some feat by itself. Nice work
YEAP CHIN POH is offline Find More Posts by YEAP CHIN POH
Old Apr 14, 2005, 10:37 PM
Tomokabear is offline
Find More Posts by Tomokabear
My Soul is High
Tomokabear's Avatar
Fort Payne, AL
Joined Mar 2004
Philip N,
I will be following the Tigercat with very much interest.
I like the fuselage former/wing spar arrangement, it
should be strong and light.
Barry
Tomokabear is offline Find More Posts by Tomokabear
Old Apr 15, 2005, 09:05 AM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
Philip,
I really like the way the spars, nacelle formers and fuse formers are all integrated. I've never seen that before. Its so obviously simple, strong and self aligning. Brilliant, as they say in the Guinness commercials. Can't wait to see more
Dave
dottney is offline Find More Posts by dottney
Old Apr 15, 2005, 09:08 AM
ericm is offline
Find More Posts by ericm
Vancouver WA
Joined May 2004
Very nifty, looking forward to watching these projects progress...
ericm
ericm is offline Find More Posts by ericm
Old Apr 15, 2005, 11:49 AM
Hertfordshire
Joined Apr 2005
Wing panel construction
Hi, just thought i had better let you see how the wing panel in made.
First photo:
Plan stuck down and False L.E & T.E stuck to building board, these are cut so that you get the correct wash out on the wings.
Second photo:
Inboard, and tip rib stuck to LE & TE and upper spars fitted (Note wing is built upside down - you will see why later)
Third photo:
All ribs fitted and lined up with top edge of LE & TE.
Fourth photo:
Lower spars fitted.
It is now ready to be rubbed down ready for skinning.
Old Apr 16, 2005, 05:26 AM
Hertfordshire
Joined Apr 2005
More progress to the wings on the Mitchell, now you will be able to see why i skin the lower side first, its so that i can cut the slots for the formers.
Phil
Old Apr 16, 2005, 05:28 AM
Hertfordshire
Joined Apr 2005
More photo's
Old Apr 16, 2005, 11:07 AM
Tommy T is offline
Find More Posts by Tommy T
Joined Sep 2004
Philip, very impressive design, inspirational really. I like the scale lines on your A-26, especially the tail section. Great job!
Tommy T is offline Find More Posts by Tommy T
Old Apr 17, 2005, 08:09 AM
Tempest is offline
Find More Posts by Tempest
Tempest's Avatar
Gaithersburg MD, United States
Joined Nov 2000
Very interesting design technique Philip. Integrating the nacelle and center fuselage formers into the spars should really help with ensuring everything is alligned.
I like it!
Paul
Tempest is offline Find More Posts by Tempest
B-25 Mitchell JR models surfer Scale Kit/Scratch Built 61 Aug 09, 2007 04:09 PM
Mini B-25 Mitchell scratch build zen4013 Scale Kit/Scratch Built 0 Jan 16, 2005 08:29 PM
Dare B-25 Mitchell (conversion) KSU Flyer Parkflyers 154 Jan 10, 2005 10:02 AM
Looking for a 3 view of a B-25 Mitchell! Willmsy Scale Kit/Scratch Built 3 Jul 15, 2003 01:51 PM
B-25 Mitchell Fraser Scale Kit/Scratch Built 1 Jul 31, 2001 10:31 AM
