Old Apr 14, 2005, 02:36 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
F/A-18 Hornet Foam Parkflyer--Part 2
Several folks have asked to split the F/A-18 Park Jet thread due to the difficulty of navigating such a large thread. So here's Part 2.
Here's a link the original thread:
For convenience, here's a link to the plans:
F/A-18 Park Jet Plans
Here's a link to the illustrated construction guide:
F/A-18 Park Jet Construction Guide
And here's a link to a VERY handy index to the first thread put together by LiftVsGravity (thanks LVG!):
F/A-18 Park Jet Thread Index (Part 1)
Post away!
Steve
jetset44 is offline Find More Posts by jetset44
Last edited by jetset44; Jun 15, 2008 at 12:20 AM. Reason: Changed link to newly updated plans
Old Apr 14, 2005, 03:10 PM
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Steve!
I just want to say that I have flown my Hornet a few times the last two weeks and I like this bird better and better. Again thanks for a beauty. If I should be so unlucky to destroy it I have a F-15 about 80% finished so it won't take long to get in the air again....
When will you show us more of the TomCat? (Desperatly want one you see!)
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Apr 14, 2005, 03:36 PM
Maryland, USA
Joined May 2004
Originally Posted by jetset44
Hey Spinner,
These photos are for you--thanks to your prompting, the F-14 Park Jet now has rudders! I was able to reduce the weight hit down to only 0.5 oz total, which is well worth the added control they should provide. I'm really looking forward to testing them out in high alpha!
Steve
Hi Steve,
I am very very slow, so just started on my F-15 3dfoamy kit this week. Can you comment on the rudder for the F15? Or is it something with the design of the F-14? I originally wasn't going to add one, but I defintely want to fly it slow. What do you think? Do you have rudders on all your parkjets?
-Kwok
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Apr 14, 2005, 03:38 PM
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
I hate to say it but "Thank God" that was the Mother of all threads, perhaps we can clip these off at 1,000 post intervals. On with the Show!!
RCParkflyer is offline Find More Posts by RCParkflyer
Old Apr 14, 2005, 03:43 PM
Joined Mar 2005
Hey Im sorry if anybody get mad at me for posting this in here. But I need some help and the foamie thread isnt helping. I was earlier in this thread talking about building a foam cutter and need some help. Here is my original post in the foamie thread.
Hey I have a quick question for you foam cutter guys. I am currently building one and just went to walmart and bought a Schumacher Speed Charger that has variable amps. But it is computerized and it wont catch because my wire isnt a battery. Is there any way to get around this? Also I have a einstine nicd charger it works for about 5 seconds then the two lights both come on and it automatically turns off. Is there any way I could use either of these to work for a foam cutter? Thanks a ton for any help
Pleeaaase somebody help. I hate cutting out all of these jets with just a xacto knife that I can never get straight. If neither of those chargers work how should i go about getting one that does. Thanks lol.
brianu.16 is offline Find More Posts by brianu.16
Old Apr 14, 2005, 04:26 PM
Joined Nov 2003
This should set you in the right direction. You need a transformer, not a charger. Even a toy train, or slot car transformer would work.
If you have a Radio Shack by you this will give you a parts list, and directions. Once you have the basic set-up you can make a cutting bow, or built a table and make a cutting "Band-Saw" Your options are endless, well almost
http://www.charlesriverrc.org/articl...amcutterps.htm
Old Apr 14, 2005, 05:55 PM
Maryland, USA
Joined May 2004
If you are planning alot of questions, then its best to start a new thread and post the link here. I could go into plenty of detail with pictures and diagrams, but not here. This will be my only reply.
But briefly, you just don't need that kind of power to cut sheet. The wire only needs to be a few inches long. For example you can buy this cutter for $8. It uses 2 D cells for power. Your local craft store should carry it. And you can also use it to free hand sculpt the nose.
http://www.unitednow.com/detail.asp?PRODUCT_ID=CFC-601
Also, don't expect it to be that easy to hotwire foam straight. To do that you need a template. Granted it will give you a good 90 deg along the width, but it is going to be wavy and jagged length wise. On the other hand, cutting with an exacto knife should be much easier to get straight lengthwise cuts.
-Kwok
Mighty Dane
testpilot's Avatar
Copenhagen, Denmark
Joined Dec 2003
Cant wait for the F-14.. looks absolute stunning with the wings..
testpilot is offline Find More Posts by testpilot
Old Apr 14, 2005, 06:05 PM
Yorktown, VA
Joined Oct 2000
F-14 Rudders
Way to go, Steve! I'm going to be very interested in your comments regarding rudders vs. differential tail at high alpha Do you have an ETA on maiden?
Great job!
Joe
Spinner is offline Find More Posts by Spinner
Old Apr 14, 2005, 09:53 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Originally Posted by Kwok_Yu
Hi Steve,
-Kwok
Hi Kwok,
I personally like to have rudders on my park jets because I do a lot of high alpha flying and the rudder adds a lot of manueverability in high alpha flight. In fact, on the Gripen and F-18 the rudder is about the only way you can get the airplane to turn during really high alpha. However, the F-15 park jet has more sedate handling qualities than the other two designs, and it actually handles quite well in slow flight without a rudder. That's probably because it has the largest vertical tails of the three and also doesn't have either strakes or a canard which reduce directional stability. I didn't put a rudder on my F-15 (it's the only one without) and have rarely missed it. Having one on the F-15 would certainly improve low speed handling a little bit, but probably not enough to be worth the extra weight and effort. Thus, I think you'll be just fine if you don't put a rudder on your F-15.
FYI, I put rudders on the F-14 because it has tailerons--which probably won't provide good controllability at high alpha. That's just a known characteristic of tailerons.
Steve
Old Apr 14, 2005, 09:55 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
Spinner and Ben,
If all goes well, I'm hopeful to test fly the F-14 this weekend. Depends on the weather and my ability to finish the last few bits...
Steve
Old Apr 14, 2005, 10:05 PM
Joined Mar 2005
Rcparkflyer could you help me out a little bit with that foam power cutter supply? I think I messed it up a little bit. Here is a link to the thread http://www.rcgroups.com/forums/showt...49#post3606720
Thanks.
Old Apr 14, 2005, 11:35 PM
Professional Goofball
OCModels's Avatar
United States, WA, Port Orchard
Joined Dec 2000
Spinner and Ben,
Steve
If you don't have video for us all to drool over, a mob carrying fan fold foam pitch forks and axes will be at your door the next morning...
OCModels is offline Find More Posts by OCModels
Old Apr 14, 2005, 11:37 PM
Joined Nov 2003
Thanks.
http://www.rcgroups.com/forums/showt...ht=foam+cutter
Old Apr 14, 2005, 11:59 PM
Park Jet Guru
jetset44's Avatar
Seattle, WA
Joined Jun 2002
hee hee...good one!
New Product Park Pilots Foam F-18 Hornet 44"WS carl rich Electric Ducted Fan Jet Talk 2 Jun 25, 2006 01:43 PM
F/A-18 Hornet Foam Parkflyer jetset44 Pusher Prop Jet Models 3262 Apr 14, 2005 02:38 PM
2 Seater F-18 Hornet Canopies... gbruce Electric Ducted Fan Jet Talk 8 Oct 06, 2003 01:39 AM
F/A-18 Hornet Plan Built daladiesman Electric Ducted Fan Jet Talk 1 Oct 29, 2002 10:40 PM
Hornet CP .... finally ... part 2 cyhyam Electric Heli Talk 90 Aug 05, 2001 09:40 PM
