Old Apr 03, 2002, 09:37 AM
JonB is offline
Find More Posts by JonB
Gladstone, NJ. USA
Joined May 2000
Pager motor retract servo, how to build?
Hi guys:
Just wondering if I can build a full action servo from a pager motor. Perhaps canibalize some components from other servos? Perhaps just the pc board components from a some what "larger" servo? My intention is to explore the possibility of using a pager motor to activate each of 2 retract units...Yes, I know that it would take considerable gear reduction to achieve the desired torque level. I envision a "Linear" acting servo somewhat like the Wes-Teknic 2.4 or 3.0's.. Could these be "re-geared" to increase the torque out put...Servo speed is not of the utmost importance here...actually scale speed would be better! Also I need to enable a stop the motor at the end of the up and down cycle...so as not to stall and add additional drain to the battery system.
All input is welcome!
Sincerely,
Jon B. Shereshaw
JonB is offline Find More Posts by JonB
Old Apr 04, 2002, 01:29 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
How about using a worm drive with limit switches?
Lots of power and no high tech.
Otherwise I would just use a micro servo for each retract unit. Combine that with the GWS units.
Fred Bronk is offline Find More Posts by Fred Bronk
How To Reduce The Weight Of A 4mm Pager Motor... ALOT! TimayTheToolman Scratchbuilt Indoor and Micro Models 20 Jul 03, 2006 05:27 PM
Question How to mount 2508 on pager motor PlanesRcool Scratchbuilt Indoor and Micro Models 3 Mar 19, 2005 07:47 PM
How to build a strong plywood motor mount? [Propwash] Power Systems 23 Aug 04, 2004 05:45 PM
How to build a good looking pager motor plane! gbarc Scratchbuilt Indoor and Micro Models 9 Jul 04, 2004 06:09 PM
Separate battery for a retract servo? How? tim hooper Electric Plane Talk 17 May 05, 2003 06:15 PM
