Old Apr 03, 2002, 08:35 AM
Olivier is offline
Find More Posts by Olivier
Addicted member
Olivier's Avatar
France, RA, Yvoire
Joined Apr 2002
MF 480 rotor balancing
Hi all,
I have 2 MF 480 and both are showing a vibration around 24000 rpm...
With a HP200/20/6 the vibration dissapears at full power (+/- 30000 rpm) and I can fly without any problem
When i use a speed 480 race, the whole thing vibrates at full power (+/-24000 rpm).
Have you got any "secrets" to balance the rotors ?
Thank's a lot
Olivier
Olivier is offline Find More Posts by Olivier
Old Apr 03, 2002, 08:54 AM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
try rotating the spinner a few degrees. run it up and check for vibration. repeat as needed. that usually works if it still vibrates use a magnetic balancer..............gregg
gregg f is offline Find More Posts by gregg f
Old Sep 13, 2010, 01:00 PM
Bob Blackburn is offline
Find More Posts by Bob Blackburn
Bob Blackburn's Avatar
UK, Greater Manchester, Manchester
Joined Jul 2004
There is a thread here describing the unit I make to solve your problem and balance the fans.
The vibration never "goes away" the amplitude gets smaller at higher frequencies but the power sapping vibration is still present.
http://www.rcgroups.com/forums/showthread.php?t=1081834
Bob Blackburn is offline Find More Posts by Bob Blackburn
Balancing Mini fan 480 Rotor, hubs?? Plane Crazy Electric Ducted Fan Jet Talk 8 Oct 21, 2009 10:56 PM
MF/480 Balancing LJH Electric Ducted Fan Jet Talk 9 Nov 06, 2003 11:59 AM
MF 480 and Speed 480 question Sabrejock Electric Ducted Fan Jet Talk 12 Dec 11, 2001 12:18 PM
Rotor Balancing WKoltis Electric Heli Talk 4 Nov 02, 2001 12:05 PM
Mf 480 ducting henke Electric Ducted Fan Jet Talk 3 Jun 27, 2001 01:25 AM
