This thread is privately moderated by jgmtens, who may elect to delete unwanted replies.
Old Jan 18, 2006, 10:12 AM
F86_sabre is offline
Find More Posts by F86_sabre
Joined Jul 2004
Try here for the MUSTANG GUNFIGHTER:
http://www.midwaysailor.com/photos/m...unfighter.html
Reuben
F86_sabre is offline Find More Posts by F86_sabre
Old Jan 18, 2006, 07:18 PM
FlyByMike is offline
Find More Posts by FlyByMike
Pittsburgh, PA
Joined Jan 2002
Gunslinger's Tail Stallion
Mark,
Here's what I did with the tail photo.
I've attached a jpeg image so it will have a blurred edge. If you can use it fine. If not I can send you bmp files as they won't have the blurred edge. I worked up three sizes as bitmaps ~3.5", ~6" and 10.5" tall.
If you want them, PM me with your email addy 'cause bitmaps pics are too large for RC Groups' pics.
-Mike
FlyByMike is offline Find More Posts by FlyByMike
Old Jan 19, 2006, 09:52 AM
Cary Reeves is offline
Find More Posts by Cary Reeves
On patrol.
Cary Reeves's Avatar
United States, UT, North Logan
Joined Jun 2004
Originally Posted by FlyByMike
Mark,
Thanks Mike, nice work. Here it is as scaleable vectors. This image just shows what's in the files. The Zip file contains a vector PDF and a vector WMF file both of which are clean and scaleable up or down to any size.
Cary Reeves is offline Find More Posts by Cary Reeves
Old Jan 20, 2006, 06:21 AM
buzzltyr is offline
Find More Posts by buzzltyr
Obviously I'm a "Minus Member"
buzzltyr's Avatar
USA, MA, Longmeadow
Joined Jun 2003
Mike and Cary, thanks so much! The mustangs are fantastic! I appreciate all of the work and effort that went into the pics. I hope the images can be used by a lot of ezoners, and not just me. Again, my sincerest thanks for some beautiful (and useful) images. My thanks also to Reuben, as I had not found that website with all of the Gunfighter pics. Very helpful, as well.
Mark
buzzltyr is offline Find More Posts by buzzltyr
Old Jan 23, 2006, 04:25 PM
Big_Bird is offline
Find More Posts by Big_Bird
Big_Bird's Avatar
Arlington Texas
Joined Oct 2005
Watson Propeller
Big_Bird is offline Find More Posts by Big_Bird
Old Jan 24, 2006, 01:32 PM
Big_Bird is offline
Big_Bird's Avatar
Arlington Texas
Joined Oct 2005
VMF-312 The Checkerboard Squadron
Marine Corsair Squadron South Pacific 1944
Old Jan 24, 2006, 09:20 PM
On patrol.
Joined Jun 2004
Pennzoil Logo
Old Jan 24, 2006, 09:40 PM
Big_Bird is offline
Big_Bird's Avatar
Arlington Texas
Joined Oct 2005
Bellanca
Old Jan 29, 2006, 06:29 PM
On patrol.
Joined Jun 2004
I had a request for flame paint templates at 75% of the last ones I posted and in left and right. BrunswickOH is this what you meant?
Old Jan 29, 2006, 06:59 PM
phillipwells is offline
Find More Posts by phillipwells
phillipwells's Avatar
FL
Joined Dec 2005
DeHavilland Vampire
phillipwells is offline Find More Posts by phillipwells
Old Jan 30, 2006, 10:17 AM
On patrol.
Joined Jun 2004
Originally Posted by BrunswickOH
Cary, FIRST--thank you very much for taking the time!!! what I was thinking is a slant at the top of the flame (I guess it really doesn't need to be a left and right because I can just cut out a mirror image) but it's going to be painted on the wing surface of a Stryker (Which is basically a foam flying wing) so the leading edge is tapered back at about a 45 degree angle. Does that make sense??
Jim
How about this? These should be exactly 45 degrees. I did a right and left strip so you can see what they will look like. Because of all the intricate cutting involved, I would suggest cutting 2-3 flames in one strip and carefully aligning them as you go with a straight edge. For the other side, just flip the template upside down.
**Edit**
I thought you originally asked for 75% of the original?!? This is the largest I can fit four flames on an 8.5x11 sheet. Check and see if your graphics software or printer driver allows you to adjust the scale also. If you could tell me the exact size in inches you want the flames, I could just make it that size. Give me the length and width of each flame so that it works out the way you want on your wing when they're all ligned up down the le. Also you can give me a precise angle as well 48degrees, 51 degrees or whatever and I can skew them to the correct angle to match your le.
**Edit**
Here are some colored flames for your devastator in case the painting gets to be too big a hassle. Just print on clear label stock, spray with some sort of clear coat (both the rustoleum spray lacquer and the Wal-mart $0.97 clear seem to work fine) for durabilty, then cut out and stick them on. If you cut a 1/2 inch or more in front of the leading edge you can wrap the le with the label material.
Old Feb 02, 2006, 08:25 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Correct link for Luftwaffe emblems
Vyceroy is offline Find More Posts by Vyceroy
Old Feb 06, 2006, 02:59 PM
Joined Jul 2004
FW decals
Mike try here :
http://www.rc-network.de/magazin/art...0040-01.html#1
go to the bottom of the list
Reuben
Old Feb 19, 2006, 04:31 PM
Big_Bird is offline
Big_Bird's Avatar
Arlington Texas
Joined Oct 2005
Here are two Hartzell propeller decals.
Whoops! "LIFT HERE" Decals for 1:12 scale Sopwiths B7270 Scale Kit/Scratch Built 4 Mar 13, 2008 08:29 PM
Decals for Quarter Scale Cub Ken Eddon Giant Scale Airplanes 2 Jul 25, 2004 02:30 AM
Decals for a 1/12 scale Tucano???? Mountain man Scale Kit/Scratch Built 15 Jun 07, 2004 05:06 AM
