This thread is privately moderated by Michael Heer, who may elect to delete unwanted replies.
Old Feb 18, 2006, 07:48 AM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Oh, I almost forgot....
My Sportster EP has less than 200 Watts!!!
Actual measured values while swinging the APC "SPORT" propeller and using the PRO-LITEs 2100 15C cells, in the 3S2P configuration Li-POLYs (12.54 Volts off the charger) is 24.7 Amps.
24.7 Amps @ Wide Open @ 10.3 Volts under load.
Therefore, 24.7 X 10.3 = 254.4 Watts
Lets say at best the Power System only provides 70 % efficiency....
254.4 X .7 = 178 Watts {Pretty Close to the P-Calc estimate}
guapoman2000 is offline Find More Posts by guapoman2000
Old Feb 18, 2006, 07:55 AM
Parkflyer4you is offline
Find More Posts by Parkflyer4you
Parkflyer4you's Avatar
kissimmee fl
Joined Jul 2005
Carlos,
Don't worry I myself and the rest of the Orlando, Florida (Orlando Squadron) knows you can setup a fantastic power setup no matter what it can be. I have seen you experiement until you get the maximum out of every power system for the model in question.
Here's the Sportster perform some neat inside and outside loops ...apologize for the Video Camcorder person, he was not familiar with the camcorder and zoom in and zoom out features.
http://www.rcgroups.com/gallery/show...cat=500&page=1
Anyways....
I do like what I am seeing with what GWS is coming out and watching carefully !!!
Juan.
Keep it in the air!
Parkflyer4you is offline Find More Posts by Parkflyer4you
Old Feb 18, 2006, 02:07 PM
kensp is offline
Find More Posts by kensp
kensp's Avatar
Darwin Australia
Joined May 2002
The meaning of the statement "Looses too much speed on the up lines" is simple.
When my Formosa II uses the APC 10 X 5 Thin Electric propeller its level flight speed is 37 MPH and when pulled into a vertical climb the model slows down untill the thrust equals the weight + the drag and this occurs at 20 MPH so the model slows down (looses speed) by 17 MPH.
When a GWS 10 x 6 HD propeller is used the then the level flight speed is 48 MPH and the vertical speed 13 MPH a difference of 35 MPH, twice the speed loss of the 10 x 5 propeller. This means that it is harder to do a perfectly round loop or any manouver that has both up and down lines.
Remember that when flying competition patern one is not just doing the occasional loop and roll just anwhere in the sky that takes ones fancy. Competition Patern requires that the manouvers be of a certain size and proportion and be compleated within a box of sky that has defined limits.
During the flight the aeroplane is flying in level flight for about 40% of the time, in upward vertical flight for about 20% of the time and downward vertical flight for 20% of the time. During the remaining 20% of the flight the model is changing direction betweet level, upward and downward flight.
When using an APC 10 X 5 Propeller my static input Watts are 237 and the static output watts are 183, giving an efficiency of 77%. The Static Pitch Speed is 42 MPH. The weight of my Formosa II is 887 Grams and the static thrust is 1320 grams so the aeroplane is no slouch.
Ken
kensp is offline Find More Posts by kensp
Old Feb 19, 2006, 01:54 AM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by RAY GWS
GWS has one more propeller for you. We just added a new size of propeller in the GWS HD Series: HD1260 Propeller. GWS HD Series Propeller with excellent performance is designed by GWS CEO, Mr. Lin. It provides you more thrust with less current draw. You are welcome to test and compare with other major brands in the market. This will be an excellent propeller for GWS Formosa II flyers to use.
Item Number: GWPRO001
with shaft attach rings -- will fit 3 mm, 4 mm, 5 mm, 6 mm shafts.
I use HD props in the 9 and 10 and 11 in. sizes, all on outrunners with 5mm collet adaptors. I'm really pleased to see the shaft adaptor rings on the 12 in..... any chance these other smaller HD props will be modified with these shaft adaptor rings as well?
Tom Frank is offline Find More Posts by Tom Frank
Old Feb 19, 2006, 03:30 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi Tom
I've been informed that more new propellers are being designed and tested for brushless motors. These smaller HD props would certainly be included, shaft adaptors as well.
GWS CHEN is offline Find More Posts by GWS CHEN
Old Feb 22, 2006, 11:07 PM
RAY GWS is offline
Find More Posts by RAY GWS
Joined Jul 2004
The price will be the same as other 12" GWS propellers.
Item Number: GWPRO001 --- 2 pc in a bag
Item Number: GWPRO001A --- 6 pc in a bag
Item Number: GWPRO001B --- 100 pc in a bag
RAY GWS is offline Find More Posts by RAY GWS
Old Feb 23, 2006, 09:46 AM
RAY GWS is offline
Joined Jul 2004
GWS has many different type of propellers.
HD series is much stronger. It looks like GWS direct Drive Propellers but much stronger.
Some flyers may not know this. Welcome to check it out at GWS dealers.
Welcome to test and compare with other brands.
Old Feb 23, 2006, 10:02 AM
GWS4CEO is offline
Find More Posts by GWS4CEO
Houng-wen Lin
GWS4CEO's Avatar
Shijr, Taiwan. DungGwan, China. City of Industry, California.
Joined Sep 2001
See GWS web about props:
http://www.gwsus.com/english/product.../propeller.htm
http://www.gwsus.com/english/product...peller_edp.htm
GWS4CEO is offline Find More Posts by GWS4CEO
Old Feb 23, 2006, 07:57 PM
RAY GWS is offline
Joined Jul 2004
Add new photos of GWS Brushless ESC Programming Cards
http://www.rcgroups.com/forums/showp...&postcount=114
Old Feb 23, 2006, 08:19 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
How does this card work? If I have to open up my plane and plug the ESC into this card, that is not a workable solution. Not all programmable ESC require being plugged into a PC. Most, in fact, can program basic functions with a series of throttle stick movements without disturbing the model. This is an essential part of any programmable ESC I would buy. Will this also be an option (I hope)?
Old Feb 23, 2006, 10:12 PM
RAY GWS is offline
Joined Jul 2004
Hi Tom,
Ours do have those features also.
Ray
Old Feb 24, 2006, 11:02 PM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
Hi Tom
GWS ESC programming card does not need to work with
a PC at all, it could be applied on a field/park or in a room,
anywhere, anytime. It has 12 tiny switches on its board,
all you have to do just turn on/off few switches by using a toothpick and push/pull throttle stick when setting desired functions with GWS new ESCs.
Old Feb 24, 2006, 11:15 PM
GWS CHEN is offline
Taipei, Taiwan
Joined Oct 2005
Hi Tom
I forgot one thing, you would need to connect ESC with the programming card for seconds after setting made on it, then
disconnect them after the setting datas being transmitted from the programming card back to ESC.
Old Feb 24, 2006, 11:24 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by GWS CHEN
Hi Tom
Yes, I was aware it does not need a PC to work. The info given previously stated that, and seemed to imply others do need a PC. My question really is how do you attach the card to the ESC? And also, this would require having access to the ESC, meaning you'd have to open up a plane with a full fuselage to get at it... not very user friendly. All my existing ESC that are programmable can be set with the just the throttle stick without attaching anything to the ESC. If you have to move a throttle stick to get it to work, the only value I can see with the card is it saves some throttle stick tweaking in lieu of flipping some tiny switches. But if I have to disassemble my plane to plug it into the ESC, I'd much prefer the throttle stick tweaking.
Maybe if you could post the instructions on how the card is used, it would make more sense.
Old Feb 25, 2006, 01:48 AM
kensp is offline
kensp's Avatar
Darwin Australia
Joined May 2002
Chen
Are you saying that with the programing box we will have two different methods of programing the new GWS Brushless ESCs.
The first method being not to use the box but instead to use the normal method of switching on the radio equipment with the throttle in the high position and using the throttle on the Tx to program the ECS.
The second method being to disconnect the ESC from the Rx to connect the Program Box and then use the box to change the programming in the ESC.
Am I correct in assuming this.
Ken
How to tell new gws 9x7" from old? DeaninMilwaukee Parkflyers 11 Aug 31, 2007 06:01 PM
FS: Factory New GWS Slow Sticks Shipped UPS with Tracking Number and Insurance gbagley Aircraft - Electric - Airplanes (FS/W) 11 Oct 11, 2002 06:55 AM
New GWS A-10 picture Basketcase Parkflyers 32 Nov 07, 2001 08:56 AM
NEW - gws Tiger Moth -vs- Bleriot III - Will pico Pack work? mrebman Parkflyers 1 Jul 01, 2001 12:24 AM
New GWS/Wattage Plane & Hitec gnofliwr Parkflyers 6 Jun 06, 2001 01:10 PM
