Old Jun 12, 2012, 05:09 PM
Xizor is offline
Find More Posts by Xizor
UK
Joined Jun 2007
Originally Posted by himagain View Post
Here is the S-3381-1C1 pinout i worked it out from
PIN# FUNCTION DESCRIPTION
1-8,37-44 RTN Power and Signal Return
9 SPARE Spare position (No connection)
10, 12, 14, 16, 18,20,22, +12V + 12V Output
24,26,28,30,32,34,36
11 RS RTN Remote Sense Return
13 +12VRS + 12V Remote Sense
15 PSON# Power-On Enable Input
17 HB Hard Boot Input
19 12LS 12V Load Share Bus
21 DCOK +12V Output OK Signal
23 PS KILL Power Supply Fast Shutdown Input
25,27 29 5VSB +5V Standby Output
31 -12V -12V Output
33 FANV Power Supply Fan Voltage Input
35 PRESENT# Power Supply Present Signal
David
Thanks David, much appreciated.
Did you try connecting the Remote Sense (pin 13) to the +12V o/p? May make it more stable. Probably stable enough for our use though as it is.
Cheers
Xizor is offline Find More Posts by Xizor
Old Jun 13, 2012, 01:25 AM
himagain is offline
Find More Posts by himagain
himagain's Avatar
United Kingdom, South York
Joined Aug 2002
Cheers
I tried all ways in the beginning, you can see the solder on 13 in the picture. Ive never found a problem with them without pin 13 and didn't see any difference when i connected it.
What I did wonder about is pin 33 the fan power supply voltage pin... Didn't get chance to mess with it.
Give it a go and see if you can discover something.
David
himagain is offline Find More Posts by himagain
Old Jun 13, 2012, 09:06 AM
Xizor is offline
UK
Joined Jun 2007
Yeah, I wonder if pin 33 controls the fan speed somehow?
I'll have a poke around and report back.
Thanks again for the info.
Old Jun 13, 2012, 12:03 PM
himagain is offline
himagain's Avatar
Joined Aug 2002
If you sort that you will be Mr Popular
Old Jul 26, 2012, 10:44 PM
Bmr4life is offline
Find More Posts by Bmr4life
30 RC's and counting
Bmr4life's Avatar
United States, GA, Tucker
Joined Mar 2005
So can anyone explain how to do the 24v series wiring? I see a couple members have successfully accomplished it.
Bmr4life is offline Find More Posts by Bmr4life
Old Jul 27, 2012, 07:41 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Depends on the power supply, suggest you search for your model number. In short you have to isolate the dc negative output on the supply which will be used for the positive side from the ac ground / metal case. So if you use a ohm meter you should measure no connection between the case and the negative output. Then you wire them in series the positive of the unmodified to the negative of the modified.
grimbeaver is offline Find More Posts by grimbeaver
Old Jul 27, 2012, 12:05 PM
Bmr4life is offline
Bmr4life's Avatar
Joined Mar 2005
Thanks. I two of the PS this thread was originally posted about. After doing this, its okay for the cases to touch?
Old Jul 27, 2012, 02:38 PM
United States, MN
Joined Feb 2011
As long as you can verify that there is no connection between the case and the negative output it is safe for them to touch.
Old Jul 27, 2012, 04:06 PM
Bmr4life is offline
Bmr4life's Avatar
Joined Mar 2005
So after I remove the chassis ground, can the PS still be used for 12v power?
Old Aug 27, 2012, 09:53 PM
jsaffer is offline
Find More Posts by jsaffer
Joined Aug 2012
charger stand and end cap.
I've been using an old DL380 PS for a couple of years to power my chargers, thanks for all the info.
If you have access to a 3d printer, I have an end cap and charger stand that might be useful.
End cap makes the wiring nice and clean
http://www.thingiverse.com/thing:29295
Simple charger stand that fits over the PS, designed around a Hyperion 720 duo3, but should work for most chargers.
http://www.thingiverse.com/thing:29298
jsaffer is offline Find More Posts by jsaffer
Old Oct 18, 2012, 01:32 AM
himagain is offline
himagain's Avatar
Joined Aug 2002
Fantastic. I really should get me a 3d printer.
Thanks for sharing
Old Oct 24, 2012, 01:13 PM
Helikopter is offline
Find More Posts by Helikopter
Joined Oct 2012
MT
The 4 outer pads are all negative and are wrapped top to bottom and connected with the white wire to a the negative. This is just to common up all the negs with suitable wire.
The activation wires are all servo leads and pass very little current, the sticking out connections are what I used to buzz out the psi when I first worked out how to power it up, I only showed them to make it easy to understand. In the finished psi they are all short and tidied away behind the mouldable plastic or glue gun goo
David
I have one of these supplies and have made your modifications soldering the three wires to the bottom on the pcb and the output cables on the opposite side. The thing i can not get is why you need to connect the four outer ground pads to each other? Those are at least on my supply already connected via the chassis thru a screw?
I will use an external residual current device as an extra protection.
Helikopter is offline Find More Posts by Helikopter
Old Oct 24, 2012, 02:28 PM
himagain is offline
himagain's Avatar
Joined Aug 2002
I did it initially that way because I hadn't taken it apart and wasn't aware of the internal wiring. So to be safe and prevent track heating at max load I connected them together.
Since then a lot of people have been removing the 2 screws to decouple the mains earth (case) and negative so they can wire the PSU's in series. I guess it then makes sense to couple them up.
I havent converted one without coupling them so I wouldnt know if its caused issues. Anyone got a comment on this one?
David
Old Oct 24, 2012, 03:00 PM
Joined Oct 2012
Ok, then i understand. Have you been using this supply for a while using the setup of 3 cables on the bottom? Just so it will work for a while...
Old Dec 10, 2012, 03:16 AM
M3Roc is offline
Find More Posts by M3Roc
Oy Vey...
M3Roc's Avatar
United States, OH, Akron
Joined Dec 2012
Ok so I have two of these ESP113 PSU's getting prepped for use with a Powerlab 8. According to all the knowledge and mis-knowledge in this forum, I would like to get a few things straight just to be sure im understanding it all..
*Isolating the two PSU's from each other will not require me to do the DC ground lift? As long as the two metal cases never come in contact, I should be ok..
*Combining the two in series, meaning joining the voltages to form 24v respectively, does not double my Amps? Am I correct in assuming that the Amps stays at 32?
*Lastly, has anyone confirmed a way to use a small switch in order to turn the power supplies on or off? If I break the circuit on any one of the three wires on the bottom traces, will this effectively and safely shut down the PSU?
Here are some pictures of what Ive done so far with one of the PSU's. I plan to do the same with the other.
Each PSU will be able to handle two chargers assuming obviously that they do no overdraw current.
M3Roc is offline Find More Posts by M3Roc
Discussion PC power supply need help youth must fly Batteries and Chargers 45 Feb 01, 2007 04:19 PM
Got a new 2.5amp wall Power Supply, Need Help! Suntzu Batteries and Chargers 24 Dec 15, 2004 04:51 PM
2 charger with 1 power supply..need help VR6 Batteries and Chargers 2 Sep 04, 2003 11:33 AM
Computer Power Supply Probs - Help!!! indyrcpilot Batteries and Chargers 4 Feb 16, 2003 10:11 PM
Question power supply recommendations... HELP torcgolf Batteries and Chargers 30 Nov 15, 2002 02:17 AM
