Old Aug 05, 2011, 02:34 PM
Cereal Killer.
branflake12's Avatar
USA, IA, Iowa City
Joined Jun 2009
Originally Posted by himagain View Post
Looking at your picture it looks like you didnt common up all the negatives (top and bottom)
David
New to this...how is his picture different than yours? I've stared for a few minutes and im not following
branflake12 is offline Find More Posts by branflake12
Old Aug 06, 2011, 12:37 AM
himagain's Avatar
Sheffield, England
Joined Aug 2002
Hi Guys
Ive managed to get one of these power supplies powered up and working ok.
Its rated at 32A and I've had it running at 20A without it getting warm at all
Heres the solution ,
- Simply connect the 3 pins in the photo to ground. There are 4 grounds/negs, these are the ends of both sides of the boards.
- The 12+ is the long middle section on the top
- Connect all 4 grounds together and this is your negative
- Cover the pcb with "Magic Plastic" to prevent any shorts
And your done
Any questions give me a shout
Enjoy
David
Branflake
All the commons are connected together, i.e. all 4 ends
It isn't too clear in the the picture but the thick white wire wraps round top to bottom
http://www.rcgroups.com/forums/showp...92&postcount=7
good luck
David
himagain is offline Find More Posts by himagain
Old Aug 06, 2011, 09:44 AM
Cereal Killer.
USA, IA, Iowa City
Joined Jun 2009
ahhh, there is enough exposed to wrap around the "blades" to touch both sides of the neg...i get it. Im going to try this on mine tonight.
Thanks for the clarification!
Old Aug 07, 2011, 01:08 PM
Cereal Killer.
USA, IA, Iowa City
Joined Jun 2009
Success! 12.26v and charging now. Gotta find me some silicone to cover all this up with
Thanks everyone!
Old Sep 01, 2011, 10:44 PM
Joined Sep 2011
Has anyone worked out if it is possible to turn on / off these via a switch? Like with a regular atx PSU, put a switch between the green and ground and it will turn on / off at a flick of a switch. Is that possible with these?
I want to use one of these to power the motor on my barley mill, and would be good to be able to controll via a switch!
kjparker is offline Find More Posts by kjparker
Old Sep 11, 2011, 06:18 PM
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
Sure glad I found this thread.
I bought 2 of these for less than $9.00 each.
I was to a point I thought I may have to throw my 2 power supplies out because no way I was going to figure out the pin outs.
They are not very noisy, fairly compact and works great.
Thanks someone for doing all the work.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Jan 20, 2012, 04:16 AM
Canada, BC, Kelowna
Joined Apr 2010
In reference to this article http://ohiopacket.org/files/docs/Powersup.pdf ,blade #10 (interlock 1) sould be connected to +12v blade on other side of board. Is there a reason this has been omitted in the instructions in this thread? Just wondering if there is some important feature that isn't enabled.
On page 1, looking at himagain's photos, it looks like he might have pin 10 connected to 12v. Maybe he forgot to mention it in his instuctions.
guitarded is offline Find More Posts by guitarded
Old Jan 20, 2012, 10:03 AM
Got Thermals???
Fishjunky's Avatar
Syracuse, UT
Joined Apr 2008
guitarded, from looking at the article and the pictures in this thread, it looks like he may have soldered something on that pin but took it off. I have not actually performed the conversion yet, so I cannot say if it's necessary or not. himagain, is calling that pin 13 while the article is calling it 10.
Fishjunky is offline Find More Posts by Fishjunky
Old Jan 21, 2012, 04:08 PM
Winter Garden, FL
Joined Aug 2003
Just finished mine today. Wired it exactly as described and it worked like a champ. Astro charger read 12.23V and did a quick charge of a 3s 2200mAh Turnigy at 2C. So far so good.
jroot is offline Find More Posts by jroot
Old Jan 21, 2012, 09:27 PM
RC Helicopter Pilot
Joined Mar 2010
What ever the pin numbers are, it works perfectly just the way it is shown on page 1 of this thread.
Old Jan 21, 2012, 11:57 PM
Canada, BC, Kelowna
Joined Apr 2010
Exactly my point,
The pin in question is #13 according to himagain's picture on page 1.
Notice the solder on this pin?
According to the pdf. article this pin should be soldered to the +12v pin which is located directly underneath pin 13 (on the other side of the board). It looks to me that himagain has done this but made no mention of it in his instructions.
Notice that this part of the mod is missing by everyone who has copied it using himagain's instructions.
Good to hear jroot! How noisy is it?
Has anyone tried running this PSU 25-30A ?
Old Jan 22, 2012, 03:29 PM
Where's my beer, and my pants!
mt_100's Avatar
United States, MI, Holland
Joined Dec 1996
I have run one up to 28 amps with no problems.
I actually have eight of them around here from pulling them out of servers.
mt_100 is online now Find More Posts by mt_100
Old Jan 22, 2012, 11:41 PM
Canada, BC, Kelowna
Joined Apr 2010
Thanks mt 100 for verifying. I guess I'll just mod using himagain's instructions. No sense in fussin over 1 stupid little pin.
Old Jan 26, 2012, 01:52 AM
himagain's Avatar
Sheffield, England
Joined Aug 2002
Originally Posted by guitarded View Post
Exactly my point,
Hi
Sorry for the delay, been Skiing
Ive not seen this paper before. Do be honest I worked out the pin configurations from a HP spec document and by buzzing out an old server. I've never used pin 13 and the solder you mention on the diagram is probably from me messing about on my 1st one.
As per my diagram works fine, loads of people have built them and I've done loads.
The fan is does make a bit of noise but doesn't drown out my radio in the shed.
Good luck
David
Old Jan 26, 2012, 02:04 AM
Canada, BC, Kelowna
Joined Apr 2010
Thanks David!
Discussion PC power supply need help youth must fly Batteries and Chargers 45 Feb 01, 2007 04:19 PM
Got a new 2.5amp wall Power Supply, Need Help! Suntzu Batteries and Chargers 24 Dec 15, 2004 04:51 PM
2 charger with 1 power supply..need help VR6 Batteries and Chargers 2 Sep 04, 2003 11:33 AM
Computer Power Supply Probs - Help!!! indyrcpilot Batteries and Chargers 4 Feb 16, 2003 10:11 PM
Question power supply recommendations... HELP torcgolf Batteries and Chargers 30 Nov 15, 2002 02:17 AM
