Old Jul 02, 2010, 05:59 PM
Bmr4life is offline
Find More Posts by Bmr4life
30 RC's and counting
Bmr4life's Avatar
United States, GA, Tucker
Joined Mar 2005
Originally Posted by himagain View Post
WARNING........ If you make a 24v ps out of two of them make sure that the two cases don't touch each other or you will short them out...... Boooooom
Thank you for that information.
Bmr4life is offline Find More Posts by Bmr4life
Old Jul 02, 2010, 07:35 PM
Bmr4life is offline
Bmr4life's Avatar
Joined Mar 2005
Man, I don't think that could have been any easier.
One PS says 11.97V, other says 12.00V.
Here's a picture of the first one I did.
Old Jul 09, 2010, 07:15 PM
cherokee180c is offline
Find More Posts by cherokee180c
KB3VOJ
cherokee180c's Avatar
USA
Joined Sep 2007
re
Here is my final product. Works great. Anyone turn these into a 24V supply yet?
cherokee180c is offline Find More Posts by cherokee180c
Old Jul 11, 2010, 01:05 AM
Bmr4life is offline
Bmr4life's Avatar
Joined Mar 2005
Is that liquid tape?
Old Jul 11, 2010, 02:09 PM
KB3VOJ
USA
Joined Sep 2007
No, it was a type of electrically safe silicone that they sold me at the electronics store to cover the circuit board. I just waited till if fully cured to turn on as I thought if any moisture was still present might cause an issue. Works great though.
I have been following the 24V PS posts, but most seem to think it is a very bad idea to float the ground on the second PS in series. Just wondering if anyone has taken this HP PS yet and tried it. I have a second one sitting around and if I can do it safely, I would love to have the extra power to charge more 6S5000 packs simultaneously on my 3010B 1000W charger that can handle a 25V supply.
Old Jul 11, 2010, 03:16 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
If you have read the Threads(post) then you know it will work and the possiblle dangers. Any power supplies can be used in series if you prevent them from sahring a common ground. On the other hand a metal case without a true earth ground can become electricaly hot and deliver a most unwanted shock.
Charles
Old Aug 01, 2010, 10:12 PM
linw is offline
Find More Posts by linw
Wellington, NZ
Joined Aug 2006
Hi Guys
Ive managed to get one of these power supplies powered up and working ok.
Its rated at 32A and I've had it running at 20A without it getting warm at all
Heres the solution ,
- Simply connect the 3 pins in the photo to ground. There are 4 grounds/negs, these are the ends of both sides of the boards.
- The 12+ is the long middle section on the top
- Connect all 4 grounds together and this is your negative
- Cover the pcb with "Magic Plastic" to prevent any shorts
And your done
Any questions give me a shout
Enjoy
David
Thanks, David. I think I can get one of these so your info will be invaluable.
Lindsay.
linw is offline Find More Posts by linw
Old Sep 14, 2010, 03:06 PM
mt_100 is offline
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
Thank you for posting this, I just came across 20 or so of these getting tossed at work.
I love it when we retire servers.
mt_100 is offline Find More Posts by mt_100
Old Feb 23, 2011, 11:04 PM
Rogman88 is offline
Find More Posts by Rogman88
United States, LA, Monroe
Joined Mar 2009
Here's how I did mine. I wanted the wires soldered going into the case to minimize being pressed on in my storage box.
I've since covered with non-conductive silicone to seal the open blades.
I tested and get 12.2v under no load. Dropped to 11.7 under load charging 22.4volt battery at 11 amps (drawing 247 watts)
Rogman88 is offline Find More Posts by Rogman88
Old Feb 28, 2011, 02:31 AM
himagain is offline
Find More Posts by himagain
himagain's Avatar
United Kingdom, South York
Joined Aug 2002
Hi there
Mine doesnt lose its voltage under load at all. Looking at your picture it looks like you didnt common up all the negatives (top and bottom)
This might be help
David
himagain is offline Find More Posts by himagain
Old Apr 08, 2011, 10:44 AM
Richardmid1 is offline
Find More Posts by Richardmid1
Joined Jan 2010
How the hell are you guys figuring out which pins to jumper/short/link???
Richardmid1 is offline Find More Posts by Richardmid1
Old Apr 08, 2011, 10:51 AM
Southern Pride
Most take the easy way out and use ones which have already been hacked.
Thread here has a lot posted. Please note that the Thread is a reference thread with only proven how tos to be posted in it.
http://www.rcgroups.com/forums/showthread.php?t=1292514
charles
Old Apr 08, 2011, 03:46 PM
himagain is offline
himagain's Avatar
Joined Aug 2002
Richard.... Magic
I worked this one out from a pinout I found on the HP server site. Just a matter of understanding what the pins are, having a go at it and a little bit of luck
Enjoy
David
Old May 11, 2011, 06:01 AM
jointer is offline
Find More Posts by jointer
Czech Republic, Hlavní město Praha, Prague
Joined Oct 2010
I have 4 these units, any idea if they can be connected in series easily?
DC ungrounding preferred.
I did not looked inside yet, is there any pot for voltage adjustment?
Thanks.
jointer is offline Find More Posts by jointer
Old May 16, 2011, 01:38 AM
nydi is offline
Find More Posts by nydi
Joined May 2011
2 Server PS ESP 113 in serie
Here my solution for 2 ESP 113 in serie (not yet completed...)
Fix the power supply with plastic bolts, so you isolate the ground to the case.
The AC ground (110/230V) you can connect with the case...
nydi is offline Find More Posts by nydi
Discussion PC power supply need help youth must fly Batteries and Chargers 45 Feb 01, 2007 05:19 PM
Got a new 2.5amp wall Power Supply, Need Help! Suntzu Batteries and Chargers 24 Dec 15, 2004 05:51 PM
2 charger with 1 power supply..need help VR6 Batteries and Chargers 2 Sep 04, 2003 12:33 PM
Computer Power Supply Probs - Help!!! indyrcpilot Batteries and Chargers 4 Feb 16, 2003 11:11 PM
Question power supply recommendations... HELP torcgolf Batteries and Chargers 30 Nov 15, 2002 03:17 AM
