Old Apr 11, 2005, 09:43 PM
RockDragon is offline
Find More Posts by RockDragon
RockDragon's Avatar
Joined Jan 2005
Idea
Mod 12VDC 32Amp Power Supply : Need Help!
I want to use this hp PS-3381-1C1 hot swap Server PSU as my 12vdc PS.
Is there anyone know anything about this unit, especially the output pin details?
Top Side output
Bottom Side output
RockDragon is offline Find More Posts by RockDragon
Old Apr 12, 2005, 12:08 AM
adamg is offline
Find More Posts by adamg
adamg's Avatar
Saskatoon, Canada
Joined Feb 2004
That looks like fun ;>
You will likely get better responses by posting this in the DIY Electronics forum a few blocks over.
adamg is offline Find More Posts by adamg
Old Apr 12, 2005, 12:35 AM
RockDragon's Avatar
Joined Jan 2005
Thanks adamg.
Old Feb 03, 2009, 02:33 PM
barry wilson is offline
Find More Posts by barry wilson
amherst,nova scotia,canada
Joined Nov 2003
No expert here and have not experienced your problem myself. I wonder if your supply needs a load on the five volt supply to turn on the twelve volt supply? Some computer power supplys apparently do.
Think I saw a ten ohm power resistor used for this function. Probably ten watt rated and heat sync mounted to the metal case.
In the battery threads probably as I watch them. Keep in mind you could have a bad supply as well unless you have personal knowledge it was really working when extracted from a computer. Thirty two amps at twelve volts. Quite impressive. In my opinion the way to obtain a healthy charger supply for free or very cheap.
Just thinking that if you hooked your meter up to monitor the 12 volt supply and hooked a small brush type hobby motor across the five volt supply it might test if the load is a requirement. Also give it a little time for someone more knowledgeable about these supplies to respond. Generally they are pretty straightforward.
barry wilson is offline Find More Posts by barry wilson
Old Feb 03, 2009, 03:21 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I realize that this is avery old thread however it seems like the surplus supply of IBM 235 hot sawpable PSs is drying up and the hunt is on for a replacement. I have recieved several emails and PMs wanting help with these I know as little about them as most others. Sure makes me glad I purchased all the 235s plus some spares while they were plentiful.
FYI The IBM 235 needs no load and is the safest / most self protected PS I have ever owned.
Charles
Old Feb 03, 2009, 04:36 PM
Joined Nov 2003
How did I lock on that post anyways? Old as the hills.
Old Jan 29, 2010, 04:02 PM
himagain is offline
Find More Posts by himagain
himagain's Avatar
United Kingdom, South York
Joined Aug 2002
Power supply startup solution hp PS-3381-1C1 PSU
Hi Guys
Ive managed to get one of these power supplies powered up and working ok.
Its rated at 32A and I've had it running at 20A without it getting warm at all
Heres the solution ,
- Simply connect the 3 pins in the photo to ground. There are 4 grounds/negs, these are the ends of both sides of the boards.
- The 12+ is the long middle section on the top
- Connect all 4 grounds together and this is your negative. (note the thick white wire wraps top to bottom at both ends
- Cover the pcb with "Magic Plastic" to prevent any shorts
And your done
Any questions give me a shout
Enjoy
David
himagain is offline Find More Posts by himagain
Old Apr 20, 2010, 10:34 PM
lklunder is offline
Find More Posts by lklunder
Joined Feb 2008
Originally Posted by himagain View Post
Hi Guys
And your done
Enjoy
David
David,
I have a this power supply (ESP113) and I want to use the 12V and 32A.
In your instructions to connect the pines to ground/negs I have a doubt because on the second and third pin there are .3v and 4.7v respectively, if I connect those pins to negative it may be cause a short circuit and damage the power supply ......Do you know if this may be a problem ???
Thank's in advance
lklunder is offline Find More Posts by lklunder
Old Jun 25, 2010, 12:54 AM
himagain is offline
himagain's Avatar
Joined Aug 2002
more detailed pinout details
Guys here is another image to try and made it clearer.
vlklunder the pins will have voltage on them but they are low current signal wires and its not a problem
Any problems give me a shout
David
Old Jun 25, 2010, 05:58 AM
cherokee180c is offline
Find More Posts by cherokee180c
KB3VOJ
cherokee180c's Avatar
USA
Joined Sep 2007
Thanks himagain! I think the remote sense return was not working right for me because I never attached the nuetrals from the top to the bottom. PS is putting out over 12V now.
cherokee180c is offline Find More Posts by cherokee180c
Old Jun 26, 2010, 02:42 AM
himagain is offline
himagain's Avatar
Joined Aug 2002
Cool
Enjoy the AMPs
David
Old Jul 02, 2010, 12:34 PM
Bmr4life is offline
Find More Posts by Bmr4life
30 RC's and counting
Bmr4life's Avatar
United States, GA, Tucker
Joined Mar 2005
I was able to get two of these, I want to wire them up to make a single 24V source. Anything I need to do special other than wire them up as shown and then connect them in series?
Bmr4life is offline Find More Posts by Bmr4life
Old Jul 02, 2010, 02:42 PM
Bmr4life is offline
Bmr4life's Avatar
Joined Mar 2005
David
I'm not sure I get whats going on in the picture with the Pins. What are the numbers for?
Where are the other ends of these wires going? OOOOOOH. I think I figured it out. Orange to Orange, Black to Black, Red to Red, lol. I can handle that.
Old Jul 02, 2010, 03:24 PM
himagain is offline
himagain's Avatar
Joined Aug 2002
Hi there
The numbers are the pin out numbers, the evens are on one side and the odds are in the picture. You don't have to worry about them, I just put them on for reference. Wire all three wires to the common (- neg), the negatives are the end contacts, all the negatives have to be wired together. The positive is the big one
Enjoy
Old Jul 02, 2010, 03:27 PM
himagain is offline
himagain's Avatar
Joined Aug 2002
WARNING........ If you make a 24v ps out of two of them make sure that the two cases don't touch each other or you will short them out...... Boooooom
Discussion PC power supply need help youth must fly Batteries and Chargers 45 Feb 01, 2007 04:19 PM
Got a new 2.5amp wall Power Supply, Need Help! Suntzu Batteries and Chargers 24 Dec 15, 2004 04:51 PM
2 charger with 1 power supply..need help VR6 Batteries and Chargers 2 Sep 04, 2003 11:33 AM
Computer Power Supply Probs - Help!!! indyrcpilot Batteries and Chargers 4 Feb 16, 2003 10:11 PM
Question power supply recommendations... HELP torcgolf Batteries and Chargers 30 Nov 15, 2002 02:17 AM
