Old Apr 10, 2005, 12:17 AM
Stan Myers is offline
Find More Posts by Stan Myers
No Little Rock Arkansas
Joined Feb 2003
Evo, am I jumping out of the frying pan into the fire?
Wasn't sure where to post this question. I have been using a 8103 and have never felt comfortable programing this radio, almost always needing help from someone from JR or a knowledgeable radio "geek".
I've always heard that the Stylus is the "sailplaners radio" for ease of programing, however, when I downloaded a pdf file of the operators manual, it didn't look easy to me.
Some of my more knowledgeable radio folks at our Saturday morning get together suggested an Evo or 9303.
This is where your help comes in, which if these 3 radios has the least sharp learning curve? Which has the best tutorial help i.e. Edberg?
TIA
Stan
Stan Myers is offline Find More Posts by Stan Myers
Old Apr 10, 2005, 02:29 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
What kind of planes are you flying?
Full house gliders?
Sport electric or glow?
Aerobitics?
Scale?
What kind of mixing are you typically using?
Why do you think you are having trouble programming the radio you have now?
aeajr is offline Find More Posts by aeajr
Old Apr 10, 2005, 08:29 AM
Joined Feb 2003
Add'l info
I'm flying full house electric 3.1m,sailplane 3m+,Grand Esprit, 70%Brooklyn Dodger electric, hand launch.
I'm alright with basic functions, but I'm lost when trying to flaps/crow. Get the flaps to come down the same number of degrees, etc.
Stan
Old Apr 10, 2005, 08:51 AM
ejett is online now
Find More Posts by ejett
TLAR Black Belt
ejett's Avatar
Athens, LA, United States
Joined Apr 2002
Stan:
Generally you will have to set end points or travel volumes for each flap servo separately.
I'd have to say that the basic Stylus radio with a memory card will do all of the things you need to do. The EVO and the JR 9303 are "newer" and thus seem to be getting all the press, but the JR 9303 sailplane version is much like the old Vision sailplane version in that it is more specialized toward sailplanes than other types of planes.
Any of those radios are going to be fine. But, it will take time with the manual, and a plane and some determination to learn the programming functions of each of the radio systems. For all of the radios currently available, the most important element in the system is your knowledge of the programming and your dedication in setting up the plane and radio. Unfortunately, none of these radios will let me punch up Grand Esprit and be done. Some will be easier for this function or that function. Someone that has used them all, and that would not be me, might say this one or that one is easier to program. However, even this is subjective and what is easy for one person might be difficult for another. For instance, both the EVO and the JR 9303 are very good radios, but the programming approach is significantly different.
The 8103 that you have is very capable of providing the necessary functions for the type planes you mentioned in your post. If you get a new radio, you will have to be prepared to spend a significant amount of time with it learning the new programming.
Good luck with your project.
EJ
ejett is online now Find More Posts by ejett
Old Apr 10, 2005, 08:55 AM
ejett is online now
TLAR Black Belt
ejett's Avatar
Joined Apr 2002
Oh! and be sure to get a radio that the group of guys you fly with are using as they will be your experts and your best resource if you get stuck.
EJ
Old Apr 10, 2005, 11:16 AM
aeajr is offline
LI, New York, USA
Joined Mar 2003
Stan Myers
If you have the itch for a new radio, fine. All good choices.
But so far ti sounds like you have not spent enough time with the manual if getting the flaps even is one of the big challenges you are facing. Getting a new radio is not likely to help wit that.
Let's get detailed.
Pick a plane that is giving you trouble.
Provide the info on the plane, how you have the channels selected. Ie: ailerons on ch 1 or 1 and 7. Understand?
What mixes are you trying to set and most most importantly, why.
Then give us the problem.
I don't know the JR line so I can't help with specifc keystrokes, but I might be able to help you through the logic, if that is the problem.
That is a VERY capeable you have. Should be able to meet most of your needs.
Old Apr 10, 2005, 01:11 PM
Hanagar is offline
Find More Posts by Hanagar
Dave
Redmond, Washington, United States
Joined Feb 2004
Have you tried any of the number of "Programming sailplane" guides? My personal favorite is the one written by Sherman Knight:
http://www.seattleareasoaringsociety..._info/tech.htm
There's a word doc about how to program your JR8103 for a six-channel sailplane. Well written, all you have to do is follow the steps. It's simple enough even for me, who doesn't understand the programming modes of the radio.
Hanagar is offline Find More Posts by Hanagar
Old Apr 10, 2005, 07:25 PM
talonxracer is offline
Find More Posts by talonxracer
talonxracer's Avatar
fishs eddy n.y.
Joined Apr 2003
I had both the Evo 9 and the 9303. I had major problems with the Evo, in fact I got a replacement and had even more problems with that one(all were RF problems). I love the 9303, and would recommend it to anyone, with one caveat, get the heli version. I tried both a sailplane version and the heli and found the switch layout better on the heli. With the 9303 you can download a sailplane additional manual that walks you step by step how to set it up for a full house glider. After useing the 9303 and a 9c I also found the Evo not to be comfortable in the hands. But I know of many guys who have had zero problems with their Evo's and love them. But as EJ said it will be easier to have a Tx that is familiar to the guys you fly with to help when you get stuck on something.
Good luck with whatever your future purchase will be!
Doug
talonxracer is offline Find More Posts by talonxracer
Old Apr 15, 2005, 04:47 AM
glide is offline
Find More Posts by glide
85 degrees and sunny
glide's Avatar
Hawaii
Joined Apr 2003
I have a Evo 12 synthesizer/scanner and it is great. People talk about the global mixer issue but that is not an issue for me at the moment. I like the approach that MPX has taken in programming the Evo and it finally gelled in my brain after I setup my simple two channel Climmax sailplane. I then setup a 3D electric parkflyer and that was easy also.
I have a JR9303 on backorder for a couple months now (the ham band RF module is hard to come by I guess) and I got word that I should be receiving it by next week. The Evo does not come on the ham band I have several receivers on six meters. I went with the 9303 because I wanted a transmitter that was specifically made for sailplanes. The thumb wheel on the JR9303 is an interesting feature and the styling is pretty cool.
glide is offline Find More Posts by glide
Old Apr 16, 2005, 08:19 PM
Hostage-46 is offline
Find More Posts by Hostage-46
Hit my smoke....
Hostage-46's Avatar
United States, TX, Highland Village
Joined Jan 2003
What EJ said !
EJ
I didn't factor this in when I bought my EVO. I thought I was kinda special being the only one in the club with one... then I got lonely
The EVO is a superb radio, don't mistake my comments as critcal of the Multiplex product. I however decided to take the advice of others like EJ and ordered a Sylus, quite a few in my club seem to fly Airtronics and have since the beginning of time. With the family, job and two contests to fly a month, I figured I need more time flying and less time trying to figure out the programming. It was a tough decision for me, because I really do like that EVO, I'll own one again one day I suspect.
Today I bought an Artemis from one of the guys in the club, he has a stylus which he let me fly with. We flew a bit, tweaking the setup and saved to the card, and we'll drop that config onto my Sylus when it arrives next week. As a new contest pilot, I'm always looking for pointers, guys are more likely to lend me a hand when they are confortable with my equipment.
Joedy's tutorial is an excellent resource. Check out this thread as well, there are lots of folks who will assist. http://www.rcgroups.com/forums/showthread.php?t=321734
My $.02
Hostage-46 is offline Find More Posts by Hostage-46
Old Apr 16, 2005, 09:03 PM
glide is offline
glide's Avatar
Hawaii
Joined Apr 2003
Stylus is a great transmitter but very dated. I've owned a couple of them but sold my last one a couple months ago. The card system is susceptible to catastrophic failure and then one day all your setups could be lost. The 9303 does not have a way of saving data like the Evo so the JR transmitter has that potential problem unless you could order from over the pond (in Europe) that Data exchange system. for the 9303. Now the Multiplex system is pretty good in regards to saving data to a PC via the cable link. But Multiplex seems a little slow in doing updates (the system is already a few years old and we are only at version 1.40).
As for setting up the Evo, many thanks to Joedy for doing the job of composing the tutorial. It is an excellent resource in understanding how to program the Evo. The flowchart is something that helped me immensely. Of course the Evo has a few shortcomings which could be addressed by future updates (remember that it didn't have the option of setting it to positive or negative shifts when it first came out). I hope to have my 9303 by next week and I will see if it will be easy to program (like my old Vision transmitter) and I hope that it is a capable sailplane transmitter.
Question Why am I burning out 350's? Brycew Parkflyers 23 Feb 29, 2004 11:41 AM
tooo many planes in the market. i am getting out of control.. please help someone special Parkflyers 40 Sep 24, 2003 08:18 PM
Big getting out of airplanes, getting into helis sale. reznikvova Aircraft - Electric - Airplanes (FS/W) 19 Jul 12, 2003 12:18 PM
A Few more Planes I am Blowing Out! Dani Z Aircraft - Electric - Airplanes (FS/W) 35 May 31, 2003 10:05 AM
motor still glitching. tossing AM radio out !! jerry55 Foamies (Kits) 2 Apr 28, 2003 11:21 PM
