| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
Full fuse printed P40
In a effort to hide the electrics on a printed warbird (t1mux prints are to good looking to cover up), I want to come up with a semi full fuse for these little fighters.
Just kind of thinking out loud at this point. Looking for advice and/or ideas on how to make this work. Heres what I have so far. WS is 30". Sides are 2mm. Perimeter is 6mm square. Formers are 3mm. Overall width is 1 1/4". Wing will be 5mm with print on both sides with CF spar. Tail will be 3mm with print on both sides. Front bottom will be left open for bat cooling. When building the real thing, I think I would round the corners before putting on the print. Of course, the next step would be to cap the tops and some of the bottom. May have to install electrics before the side goes on. Could be a problem for service. Any tips or ideas will be appreciated. Disreguard this post and move to the bottom of the page. Lee Last edited by ldammann; Apr 09, 2005 at 11:12 PM. |
#2 |
Sponsered By My Wallet!
Looks very good!!!
Duane
#3 |
G G Ghost Pirates !!!
Nice .. like it better than a single layer profile ..
#4 |
zagnutz fiend
That is TOO SWEET!!!
#5 |
Mocking Birds
P40 Full Fuse
Following Lee's last example of a simple box fuse, I put this together. The part labeled Mid Fuse Former is the top cowl surface. However where the cowl meets the bottom of the front window it former goes directley back torwards the elevator slot on the tail. I included flat wing additions for both low and mid fuse. Mid wing would obviosly give more room for gear. Skins are included for the cowl and front canopy window and should be centered and trimmed to fit your setup. The rest of top from the front of the canopy to the front of the stab should be joined together by holding the two surfaces together and cutting a V in the foam from both sides of the skin. Next work the foam between your fingers until they join easily and connect them with some contact cement pinching the sides together. I figured this out by accident when I forgot to cut angle surfaces into my elevator when I made my BD, and they look great. The Bottom fuse spacers overlap following the steps in the bottom of the fuse. This gives the option of having piece #2 function as the fuse door attaching with velcro to piece #3. All of the skins are 1.58" and should be trimmed to fit. Everything should line up and is as close as I could get it without a test build. Who wants to be a tester? Link To Full Size File 29"x49"
#6 |
Tim
WOW!!! Just what I needed. To bad I leave for Florida in the morning. Your killing me. Lee |
#7 |
I was thinking...is there a particular reason why you wouldn't just use one and 1/4 or 1 and 1/2 inch EPP foam from like lowes or Home depot? Looks great though...wish I could finish one of my projects so I can get to flying more than building...
Brass |
#8 | |
Lee |
#9 |
Ok guys. Disregard the first photos. Build it like Tims prints and discription. I started playing with it when Tim posted and its going to look better, be easyer to build and stronger. I'll do a build from Tims prints when I get back from Florida in a week. In the meantime, heres some pics of the wing and tail.
Lee |
#10 |
Location: Grand Rapids Kent Cty, Michigan, United States
Here is what I have so far on my full fuse P40 build. Went together very nicely and everything lines up well. I might suggest a piece to go in the front to wrap the shark mouth around as it is on actual plane.
I am planning on mounting the motor high in the front, again as it is in the actual plane. Will this have any effect on the flight characteristics or does the thrust line have to be down the middle of the plane? I am planning on using R/E. Any suggestions on how much dihedral I will need to put under each wing? I was thinking about 2 1/4 inches. Airframe as it stands weighs in at about 4.5 ounces.
#11 |
AMA CD# 5957
I would suggest sanding the bottom of the cowl as round as possible, and wrapping the printed cover around, to give it more of a scale appearance.
As far as dihedral, 2 1/4" on a 30" span should be OK, the low wing gives less goofy looking yaw in flight than a high wing will for some odd reason. Put the thrust line on about the same plane as the horizontal stab and it'll be fine. At the Reynolds numbers that we deal with on these little planes, the aircraft flies more on the prop than on the wing, the control surfaces more redirecting the airplane than flying it, if you take my meaning. |
#12 |
Looking good Tdevil.
Don't know for sure of the thrust line. I'm going to keep mine about even with the exhaust. Dihedral, the more you have the more stable it will be and the better it will turn. Is there a reason you didn't go alerion/ elevator with no dihedral. Did you do a cambered wing? How bout some pics of the bottom. Lee |
#13 |
Mocking Birds
Tdevil, That looks great! I will put together the nose pieces and post them in the morning. I don't know how I missed that. Thanks.
According to a recent post by Gene Bond these are the rules of thumb for dihedral: 1-3 degrees total for a high-wing (.5-.75in/ft) 5-8 degrees total for a mid-wing (1-1.6in/ft) 10-13 dgerees total for a low-wing (2.1-2.8in/ft) If you printed full size you have a 36" span = 6.3-8.4in/ft. I will let an expert field your motor question. |
#14 |
OK I'm finially back and building. To build to T1mux suggestions, bevel the top edge of the fuse from the tail to the windshield.
#15 |
AMA CD# 5957
Lee, You and I must have been typing at the same time... |
| Thread Tools | |
| GWS J3-f full fuse cub: GREAT PLANE | cheapflyr | Parkflyers | 13 | Jun 10, 2001 09:43 PM |
| Full Fuse stik center of Gravity Problems. | kist2001 | Parkflyers | 3 | May 30, 2001 04:45 PM |
| New Pico Cub full fuse AND GWS Tigermoth! | Jason M | Parkflyers | 9 | May 15, 2001 11:43 PM |
| What's better Regular Litestick of Full Fuse Lite Stick? | mrebman | Parkflyers | 1 | Apr 27, 2001 02:23 AM |
| modifying Full Fuse lite stik for Ailerons | PunkerTFC | Parkflyers | 5 | Apr 21, 2001 03:34 PM |
