Hoofddorp, Netherlands
Joined Sep 2004
When soldering connectors to wires I tend to use one of those little "extra hands" which has a clamp at each end of a bar. Some even come with magnifying glasses on a third arm. Usually put a connector into each clamp at the outset, pretin and then solder the male and female wires to their respective connectors. Of course this isn't a very good idea when soldering wires which at the other end already have a LiPo attached to them ;=)) Got a nice spark when I accidentally tried that once with a NiMH pack.
Answering the questions:
Battery: ThunderPower 730 mAh, 2 cell. battery had been used several times before, and was fully charged. Soldering: Radio shack 40 watt iron, radio shack solder. conical tip... I was replacing the stock jst connector with powerpoles, so I cut it off, cutting each wire individually and taping before cutting the next. This may have been part of the problem, the amount of wire coming out of the cell was skimpy - about 2 and 1/2 inches, so I was working pretty close to the cell. I was splicing in more wire to get a longer reach as well, so was doing a wire-to-wire solder. Don't know exactly how long I applied heat with the iron, but my technique has been improving and I was just congratulating myself on what a nice quick, compact connection I had made when the battery burst into flame. Rick |
Perth, Australia
Joined Mar 2004
If the Lipo pack was constucted without a header pcb, It is possible that enough heat flowed along the wire to the Lipo tab. The wires look thin but even the 16G wire has a fairly heavy cross section of copper conductor to carry the heat. Rick states that he wasnt sure how long it took to solder the joint. Its a fairly small pack with less ability to dissipate the heat
If the wire has a film of surface corrosion, it can take quite a few seconds before sufficient heat is transfered to the wire to allow the solder flux to break down the surface film allowing the solder to bond to the wire. However at the same time it is flowing along the wire to the tabs. I use resin cored solder, a non corosive liquid flux and a high powered Iron to solder power connectors and battery connections when making up packs. This results in much faster soldering and less time for the heat to travel. Supprisingly, I've found a lower power iron can cause more unwanted heating as it takes quite a bit longer to solder the joint. This also applies when soldering Nmhi cells together. Ron... |
| Thread Tools | |
| How to cool lipo while running cba test | bobf | Batteries and Chargers | 5 | Oct 08, 2005 04:03 PM |
| Heat removal while soldering lipo | Norman Greene | Batteries and Chargers | 8 | Apr 26, 2005 10:50 AM |
| Lipo pack soldering | rcnutt | Batteries and Chargers | 2 | Dec 01, 2003 11:31 PM |
| LiPo Tab Soldering Technique | Dave Hederich | Batteries and Chargers | 12 | Nov 04, 2003 11:58 AM |
| Building lipo packs?? soldering? | bcripe1 | Batteries and Chargers | 8 | Sep 26, 2003 05:35 PM |
