Old May 18, 2001, 10:58 PM
jdmartin8 is offline
Find More Posts by jdmartin8
New Haven, Indiana, USA
Joined Apr 2001
Can you help me with stabilizer design?
What is the proper (recommended) ratio of wingspan to horizontal stabilizer span for a conventional tail?
I would like to use a 50" wing that I have, and also a set of tail feathers that have a horizontal stabilizer span of 14". The wing chord is 7" and the horizontal stab chord is 2-3/4", with a 2" elevator.
The length of the fuse from the trailing edge of the wing to the leading edge of the stab is approximately 10".
Are these numbers in the ball park or totally out to lunch?
Thanks....
Jim
jdmartin8 is offline Find More Posts by jdmartin8
Old May 19, 2001, 12:12 AM
sal is offline
sal
Find More Posts by sal
sal
NSP (Vermont)
Joined Aug 2000
The tail moment is a bit short. It would fly a lot better with a longer tail momnet. I would go to 14 inches. The tail should then be more than adequate.
sal is offline Find More Posts by sal
Old May 19, 2001, 06:07 AM
Joined Apr 2001
Sal,
The shorter tail moment will cause an increase in pitch sensitivity, correct? Does it appear that this design is not flyable, or will just be on the difficult side?
Old May 19, 2001, 08:41 AM
flailing is offline
Find More Posts by flailing
Houston, Texas
Joined Oct 2000
On free flight models I generally use 20% of the wing area.
flailing is offline Find More Posts by flailing
Old May 19, 2001, 11:29 AM
sal is offline
sal
sal
NSP (Vermont)
Joined Aug 2000
Use a longer tail moment. The aircraft will not respond well.
Old May 20, 2001, 10:53 PM
Der Zip is offline
Find More Posts by Der Zip
Der Zip's Avatar
Port Orford, Oregon, USA
Joined Mar 2001
Leave it off. We don't use them any more.
He He Der Zip
Der Zip is offline Find More Posts by Der Zip
Can you help me with my power supply, please? Flybyguy Batteries and Chargers 3 May 23, 2004 12:36 AM
Can you help me with my power supply, please?! Flybyguy Power Systems 0 May 22, 2004 09:18 PM
Mr. Lin--can you help me with my Chinese, please? Carter GWS (Grand Wing Servo) 12 Mar 01, 2004 11:49 AM
Can you help me with this? raythomas Racing Boats - Electric 1 Jun 29, 2002 11:19 AM
Can YOU help me? tenover Electric Sailplanes 8 Nov 21, 2001 05:26 PM
